| Re: New mast plug
[Re: JJD]
#99355 02/25/07 04:55 AM 02/25/07 04:55 AM |
Posts: 9,582 North-West Europe | Couldn't get anodized finish so will be intersting to see how it holds up.
In the 7 years that I had a spinnaker on my cats I have never had an anodised spinnaker pole. It will hold up nicely. What happens is that it will turn dark grey and loose its shine and when you rub it hard with your hand then some of that drak grey colour will stay on your hand but that is all. I used monel rivets and stainless steel bolts on my poles and didn't use any isolator but the galvanic corrosion is so slow that you probably can use it for 10 years before the bolt/rivet holes wear out and you have to reposition the fittings. Wouter
| | | Re: New mast plug
[Re: JJD]
#99356 02/25/07 10:25 PM 02/25/07 10:25 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen OP
Posts: 1,037 Central California | JJD--I'm curious--how much did it cost?
| | | Re: New mast plug
[Re: JJD]
#99358 02/27/07 11:39 PM 02/27/07 11:39 PM |
Posts: 1,037 Central California | Thanks--I might need to get a longer pole to get my new kite to fit.
2,869
guests, and 168
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
