Re: New mast plug [Re: David Parker] #99354
02/24/07 10:09 PM
02/24/07 10:09 PM
Orange County, CA, USA
JJD Offline
JJD  Offline
The hoop for the spinnaker snuffer has a mounting bracket that is shaped to fit the 1.5" OD tube so whatever I use has to fit that.
I was able to obtain a 12' piece of 6061-T6 tubing to the specifications above and assembled a new pole. Should be back at it next weekend. Couldn't get anodized finish so will be intersting to see how it holds up.
Re: New mast plug [Re: JJD] #99355
02/25/07 04:55 AM
02/25/07 04:55 AM
In the 7 years that I had a spinnaker on my cats I have never had an anodised spinnaker pole. It will hold up nicely. What happens is that it will turn dark grey and loose its shine and when you rub it hard with your hand then some of that drak grey colour will stay on your hand but that is all. I used monel rivets and stainless steel bolts on my poles and didn't use any isolator but the galvanic corrosion is so slow that you probably can use it for 10 years before the bolt/rivet holes wear out and you have to reposition the fittings.
Re: New mast plug [Re: JJD] #99356
02/25/07 10:25 PM
02/25/07 10:25 PM
Central California
ejpoulsen Offline OP
Central California
JJD--I'm curious--how much did it cost?
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: New mast plug [Re: ejpoulsen] #99357
02/27/07 09:32 PM
02/27/07 09:32 PM
JJD Offline
JJD  Offline
Cost was $94 and change after taxes. A little pricey, but I only had to drive about 5 miles out of my way to pick up.
I later found the same section with clear anodize listed on the Rig-Rite spar site. Kenyon Marine offers that extrusion.
Didn't inquire about the price though as I'd already committed.
John
Re: New mast plug [Re: JJD] #99358
02/27/07 11:39 PM
02/27/07 11:39 PM
Central California
Central California
Thanks--I might need to get a longer pole to get my new kite to fit.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
0 registered members (), 19,222 guests, and 612 spiders.
Yesterday at 04:54 AM
