| Hobie Wave Turbo #100157 03/07/07 11:06 AM 03/07/07 11:06 AM |
Posts: 12 Decatur, Alabama | Does anyone here sail a Hobie Wave with the optional jib and traveler? I am wondering if my Wave with the above configuration is faster downwind by tacking when singlehanded. Or not. The question of whether to go straight downwind or tack downwind can be quantified if you have a gps, a bridal vane, and a hand held wind meter. This can be put to rest very easily by looking at the numbers. If you are on the water and want to know the wind speed, point your boat directly downwind according to your vane and check the wind meter. If it says 5 mph and the gps says 5 mph, adding them together gives the actual wind speed of 10 mph. If you want to head off 45 degrees downwind, it will only pay in reduced time if your boat speed is greater than 7.1 mph. The longer distance is a product of the square root of 2, which is 1.414. Multiply 5 mph x 1.414 and you get 7.1 mph. Some cats will sail faster than this speed and some will not, but under these conditions, 7.1 mph is the magic number. A Hobie 20 will absolutely beat that number. See page #7 here : http://www.hobiecat.com/support/pdfs/HobieU.pdf I understand my Wave is going to be a close call, and I am very interested in performing this experiment in a variety of wind speeds in order to see if any conditions are favorable. Whether the Wave will benefit is unknown to me at this time. I am hopeful that the addition of the jib and the traveler will make enough difference to merit their cost and make downwind tacks worthwhile, but I am betting it will be a close call in winds from 4-12 mph. I have 20 years experience in mono-hulls, but this is my first cat, so I appreciate any feedback from this group. Loren | | | Re: Hobie Wave Turbo
[Re: Loren]
#100158 03/08/07 07:27 AM 03/08/07 07:27 AM |
Posts: 6,049 Sebring, Florida. | Any increase in speed by sailing at 45 degrees must more than offset the increased distance sailed to be "faster" from A to C mark.
Blade F16 #777
[Re: Loren]
#100161 03/08/07 09:10 AM 03/08/07 09:10 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Best bet is to try sailing against other boats. We have big fleets of Waves racing twice a week in a number of clubs. Results: Sailing straight for the mark pays off almost every time (tacking off may get you in different wind where you could do better.., or you could do worse) Sailing slight angles downwind can be of moderate benefit, but not much. Angles of 45-degrees will lose you lots of boats. That is why the official class course is a triangle, windward leeward; thus giving you two upwind legs, two reaches and only one downwind leg. And we are toying with the idea of a course with no downwind legs. The optional jib system by Hobie is not functional. The reason is that there is no way to tension the luff of the jib. And the spinnaker also does not work. After a year or so of experimentation, I was able to get a lot more speed out of the Wave with the Hooter. You can go to www.waveclass.org where you will see a full story on it. I was actually able to make pretty good time downwind by tacking at angles with this configuration. Good luck, Rick | | | Re: Hobie Wave Turbo
[Re: warbird]
#100167 03/09/07 07:22 AM 03/09/07 07:22 AM |
Posts: 6,049 Sebring, Florida. | Did you know that Rick also has a Taipan 4.9, with a Hooter? And I remember his Taipan 5.7 with the Hooter from several years ago. Where is that now Rick?
Blade F16 #777
[Re: warbird]
#100168 03/09/07 09:09 AM 03/09/07 09:09 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Yep, still have the 4.9 and sort of sold the 5.7 on time. Both used the Hooter very successfully. Raced the 4.9 in the local club and had it honking really well. On the 4.9, I am only using a 12' pole and sheet the Hooter from the sidestay. In winds up to about 8 mph I can still hold it down going to windward. In very light air I sheet it in really hard and am able to outpoint and outrun my son's N6.0 and an I20 upwind. With both the 5.7 and 4.9 I did use a dolphin striker on the pole, attached wires to the bows from the striker and the tip of the pole.., it has been very stable. Rick | | | Re: Hobie Wave Turbo
[Re: RickWhite]
#100169 03/09/07 09:24 AM 03/09/07 09:24 AM |
Posts: 778 Houston | In winds close to 15 it will really haul and point just as high as the stock. Hiking in over 10 is a MUST. Add a trapeze and I believe it could be used in any kind of wind. I will have to try again. I can do that using an old Tornado jib but apparently the new hooter setup has not been completly debugged. To answer anouther question "bomb proofing" poles. I have not found a way. The best pole I have found is a 90% carbon windsurfing Wave mast. Don't drill any holes in it. I hold things in place by wrapping epoxy/fiberglass tape like a fishing rod. And always keep an eye out for a spare. | | | Re: Hobie Wave Turbo
[Re: warbird]
#100172 03/09/07 08:55 PM 03/09/07 08:55 PM | Anonymous
| Anonymous
Unregistered | Warbird:
What are the humps on front of hulls for? Did you put them there?
Doug | | | Re: Hobie Wave Turbo
[Re: warbird]
#100174 03/09/07 11:30 PM 03/09/07 11:30 PM |
Posts: 1,479 Thailand | Rudder stocks have also been modified? <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
421
guests, and 834
