Re: Foil Profile [Re: mattaipan] #100354
03/20/07 07:21 AM
03/20/07 07:21 AM
I didn't think about rotating it. This should be 1:1 if printed on 8.5" X 11" paper (what size do you guys use down there?).
Re: Foil Profile [Re: mmiller] #100355
03/20/07 10:27 AM
03/20/07 10:27 AM
I
iansammis Offline
iansammis  Offline
I
Matt,
When do you expect to have the go ahead to race the Hobie 20 with the EPO2's?
Ian
Re: Foil Profile [Re: iansammis] #100356
03/20/07 11:02 AM
03/20/07 11:02 AM
Matt Miller doesn't have anything to do with whether the EPO2s are class legal on the H-20.
Depends on the HCA Rules Committee:
Jeff Alter (chair - Hobie Family Rep)
Doug Skidmore (Hobie Cat US rep)
John Dinsdale (Hobie Cat Europe rep)
Mal Gray (AUS)
Erik Olsen (DEN)
But Matt could give us an update since he shares office space with Skidmore . . . .
Re: Foil Profile [Re: Jake] #100357
03/20/07 06:17 PM
03/20/07 06:17 PM
ncik Offline
ncik  Offline
A4 is standard paper size here, 210 x 297mm.
A3 is exactly double the size, 297 x 420mm.
Re: Foil Profile [Re: ncik] #100358
03/25/07 05:47 PM
03/25/07 05:47 PM
Norway
Stein Offline
Stein  Offline
Norway
Concave sections were mentioned (in relation to the NACA 63 and 64-series).
I have heard someone say that Marstöm's Tornado rudders have concave surfaces in front of the trailing edge.
So I would like to know:
Are concave surfaces on symmetric foils of any advantage for high-perfomance 16-20-foot cat?
Which symmetric NACA-profiles have concave sections?
Or are concave sections/surfaces only useful in asymmetric profiles?
Stein
Re: Foil Profile [Re: iansammis] #100359
03/25/07 06:09 PM
03/25/07 06:09 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
Matt,
Ian
The IHCA rules committee contacted me about this a few weeks ago. I have never sailed a Hobie 20 so I've asked our Vice Chair Phil Collins to help out. He had some questions so he's going to test the EPO2 Hobie 16 blades on the 20 and let us know what he thinks.
Bob
Re: Foil Profile [Re: Stein] #100360
03/26/07 06:42 AM
03/26/07 06:42 AM
The only concave sections that I've actually seen are on some of the newer F18 rudders where the foil section is stretched out on the trailing edge leaving a concavity near the back. I have no idea as to what the performance advantage is supposed to be and I can't imagine why you would want a concavity on the leading edge.
Re: Foil Profile [Re: Jake] #100361
03/26/07 12:14 PM
03/26/07 12:14 PM
Tip loss?
Or one hell of a weed catcher?
Re: Foil Profile [Re: waterbug_wpb] #100362
03/26/07 12:31 PM
03/26/07 12:31 PM
the hollows are in the foil profile. for instance, with the rudder down in the sailing position, if you hold a straight edge horizontally on the trailing edge of the rudder to the high point of the camber, you will have space under the middle of the straight edge - this is the hollow.
0 registered members (), 930 guests, and 1,037 spiders.
