What have Ullman done here? #100674
03/15/07 02:11 PM
03/15/07 02:11 PM
Rolf_Nilsen Offline OP
Looking at the top of the mainsail in the picture linked to below, there is some reinforcement running from the headboard to the leech of the sail. Anybody who knows what kind of reinforcement this is and what the point/theory/improvement is?
http://www.catamaranparts.nl/foto/g5.jpg
Re: What have Ullman done here? [Re: Rolf_Nilsen] #100675
03/15/07 08:52 PM
03/15/07 08:52 PM
ncik Offline
ncik  Offline
My sail has a strip of what looks like a kevlar uni tape(or carbon, it's been awhile since I've looked at it) in the same position as the top diagonal strip in the photo.
I assume that because the leech tension can't be transferred around the very top of square heads, the tension will pull along those lines. If extra tensile reinforcement (such as is already in the leech) wasn't there, it would stretch the un-reinforced material.
Re: What have Ullman done here? [Re: ncik] #100676
03/16/07 02:48 AM
03/16/07 02:48 AM
That is what I also thought, but why have we not seen it in other classes with square tops, like the F-18 and the Tornado? I always thought the heavy top batten was taking the loads going over the square top.
It can not be from lack of a suitable material, 10K denier spectra is available and not prohibited in the class rules. Hmm..
Re: What have Ullman done here? [Re: Rolf_Nilsen] #100677
03/16/07 04:23 AM
03/16/07 04:23 AM
Actually F18's and other have similar devices as well. It is very noticeable on this Ullman sail but since then I've recognized similar things in sails of many other designs. Pretty much the leech load on a large squaretop sail is about 400 kg. If all of that or most of it is taken up by the batten then you would simply push the batten through its cap on the luff and jam it into the luff rope and sail track. This is actually what happens on my sail when I use stiffer top battens to flatten the sail. I had to bolt the whole assembly up to repair this issue. Since then I've stopped used stiffer battens to flatten out the top and just found other ways (trim) to get a similar effect.
The Ullman sail has two of these tapes in the sail and overdid it. The top of the sail (squaretop) now just weathervanes even in sub trapeze conditions and now amount of leech tension can bring it back. Together with the owner of the boat we looked long and hard at it and even put the boat on its side and cranked on the mainsheet to see what happened there. The top 500 mm just flaps about in the wind.
Personally I think this setup may be regard both as a benefit and a serious drawback. For a novice sailors this sail is very easy to use as it is impossible to oversheet the mainsail which would make the boat feel really bound up and slow. Additionally the boat is mild mannered. The drawback is of course that a capable crew is blowing off power that they otherwise could use to become really competitive. Double trapezing upwind is extremely rare with this sail. It seems the experience is that it is surprising good for singlehanded sailing but a little underpowered for doublehanded sailing. Pointing with it is difficult as well. Probably because the leech falls aways too soon. Careful mast rotation control and really well adjusted downhaul can get it back up to speed and recover some pointing (when doublehanding) but it is difficult.
It is not a bad sail but it was expected that a renowned sailmaker like Ullman would have come up with a more convincing design. In my personal opinion the new Glaser sails are heaps better. And I would even go as far as to claim that the recent achievements by Matt and Gina McDonald are to a significant extend the result of switching to a Glaser main sail.
I think Ullman needs to look at the experiences with this design and develop a new F16 sail that adresses these issues. If it remains as it is now then it will not be comparable to competing designs from Glaser, Ashby and soon enough also Landenberger.
Re: What have Ullman done here? [Re: Wouter] #100678
03/16/07 10:58 AM
03/16/07 10:58 AM
I still can not remember seeing similar things to this done on other square top mainsails, and I really think I would notice?
The way you describe it, it sounds like a fickly thing to get right. Wonder what happens with the sailcloth around the reinforcement, as it would probably stretch more and create point loads in the cloth.
Hmm, if done like that, perhaps even a crosscut dacron sail can be buildt to give reasonable performance..
Re: What have Ullman done here? [Re: Rolf_Nilsen] #100679
03/16/07 01:19 PM
03/16/07 01:19 PM
To me it just looks like they have found a loophole -- can't use more battens, so just sew more "reinforcement" strips on the sail instead. Interesting idea.
Re: What have Ullman done here? [Re: Mary] #100680
03/16/07 01:26 PM
03/16/07 01:26 PM
I dont think the battens are regulated under the F-16 rules, are they?
Re: What have Ullman done here? [Re: Mary] #100681
03/16/07 01:35 PM
03/16/07 01:35 PM
I don't know about the F16 rules, but it sure would be a good loophole under some class rules.
Maybe battens will someday be obsolete if they can just sew in reinforcing that does the same job as battens. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Re: What have Ullman done here? [Re: Mary] #100682
03/16/07 02:37 PM
03/16/07 02:37 PM
If you can come up with a layout of reinforcing that will match the performance of a fully battened sail, apply for a patent <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I dont think you will tough, the battens are needed to keep the shape in the sail and work somewhat under compression. Without them the shape will be difficult to control and excessive roach and square tops would have to go.
Re: What have Ullman done here? [Re: Rolf_Nilsen] #100683
03/16/07 05:07 PM
03/16/07 05:07 PM
Rolf,
But if a class is limited to X number of battens, and you would like to have another batten here or there to supplement and stiffen certain parts of the sail, this looks like a good way to accomplish that without violating the rules.
P.S. Depends on what the definition is of "batten."
Re: What have Ullman done here? [Re: Mary] #100684
03/16/07 07:39 PM
03/16/07 07:39 PM
Mark P Offline
Mark P  Offline
Does it matter? sail, sail and sail some more and I still don't think you'd notice a difference between U,Sails. G, sails or probably the fastest F16 sails, Landenberger. In my humble unbiased opinion. (Wouter) and enjoy the attachment.
MP*MULTIHULLS
Re: What have Ullman done here? [Re: Mark P] #100685
03/17/07 05:18 AM
03/17/07 05:18 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
That looks like a nice spot for a sail, Mark <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I have to say that I experience a lot of the same symptoms as Wouter describes about the Ullman sails. 1-up it's quick, but it doesn't point. Whenever we're sailing together, Mark, if I try and point where you point I just don't go.
Sailed 2-up: yes, twin trapezing is rare. I'd expect it to be more powered up. There are definitely some issues with the jib which I'm still working on. It's easy to get obsessed with the finer points of tuning a sail, but if you're looking at a sail and thinking "that looks like s**t" there's probably room for improvement.
Re: What have Ullman done here? [Re: Mark P] #100686
03/17/07 03:11 PM
03/17/07 03:11 PM
waynemarlow Offline
waynemarlow  Offline
Just about to order a new sail and I'm wondering whether to go US, Aus, Far East, rather than European sails which have become very expensive in my view, any thoughts guys and girls about some of the smaller manufacturers such as Randy Smythe and what did you pay for your sail ( recent prices please ) <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: What have Ullman done here? [Re: waynemarlow] #100687
03/17/07 03:52 PM
03/17/07 03:52 PM
There is only one way to get it just like you want it.. Build it yourself <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Seriously, I find the prices in Aus good. You want to buy the sail from a sailmaker who knows the boats, rigs and sailing techniques. You probably also want him to tailor it somewhat for your conditions. This means you can not just go to any sailmaker and expect a good sail. I dont know any sailmakers who qualify in the far east, but there are several in Aus and the US.
What is Ashby charging for an F-16 main these days? Glaser lists US$1300 on his site for a main, but I dont know how current that price is. Landenbergers site is just re-done and dont list F-16 sails at all.
Re: What have Ullman done here? [Re: pdwarren] #100688
03/17/07 03:59 PM
03/17/07 03:59 PM
Mark P Offline
Mark P  Offline
I think your mast rotation has a lot to do with your upwind performance. At Grafham I thought you had the edge on me in pointing/speed ability but prior to that I felt more confident in my own boats performance. I put this down to your mast rotation being better tuned bearing in mind you have a wing mast compared to my standard section. So in summary I believe that if you have a wing mast you have to play the rotation a lot more than the standard section. The good 'A' Class sailors and some F18 Sailors are getting this additional tunning down to a fine art and I suppose it wont be long before the F16's follow suit. Although, for me it just seems like you can gain as much as you lose by having the rotation just right or badly wrong.
MP*MULTIHULLS
Re: What have Ullman done here? [Re: Mark P] #100689
03/17/07 05:22 PM
03/17/07 05:22 PM
Adelaide South Australia
ratherbsailing Offline
Ashby mainsail is aus$1550.00 plus battens aus$330.00. I agree with rolf build your own then you get what you want sail makers will sell you the panels if you ask i use the demo version of pro sail design then take to my local sailmaker put in the detaile to his computer he charges me for the cloth and a cutiing fee i take home and put together photo is of the f18 sail i made. Yes this is Blade Mk1 f18
Taipan (not finished yet)
question for Wouter [Re: Wouter] #100690
03/17/07 08:05 PM
03/17/07 08:05 PM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
...Pretty much the leech load on a large squaretop sail is about 400 kg. If all of that or most of it is taken up by the batten then you would simply push the batten through its cap on the luff and jam it into the luff rope and sail track...
I do not understand the forces on a batten that would push it through its cap. It seems like that would require a force parallel to the long axis of the batten. Would you elaborate on the physics of this statement?
Re: What have Ullman done here? [Re: waynemarlow] #100691
03/18/07 04:59 AM
03/18/07 04:59 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
I'm quite interested in getting a set of Glaser sails. The exchange rate makes it quite attractive: jib, main and battens for just over £1k. Not sure what'd cost to get it here, though.
Re: question for Wouter [Re: GeoffS] #100692
03/18/07 06:06 PM
03/18/07 06:06 PM
ncik Offline
ncik  Offline
The strip is not stiff in bending or compression, only tension. Therefore it is not a batten, it is soft like the surrounding sail.
It take the tension rather than the surrounding clothe so the clothe doesn't stretch.
To understand the forces on the top batten, imagine there is no clothe; only the batten and leech tape (including the top leech tape). Then pull down on the trailing edge leech tape and you will see the batten is compressed.
So instead of this force travelling around the leech tape and compressing the top batten (which will push depth into this part of the sail), it is predominantly bypassed along the reinforcement that is shown in the photo, leaving the top batten with its pre-compression only.
Re: question for Ncik [Re: ncik] #100693
03/18/07 06:36 PM
03/18/07 06:36 PM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
Thank you. I get it now. I had never appreciated the fact that a square top sail's leech is like a bow string.
0 registered members (), 248 guests, and 81 spiders.
Posts267,056
