roller furler #101063
03/20/07 03:25 PM
03/20/07 03:25 PM
binga Offline OP
binga  Offline OP
I am new to the forum and I bought kilkennys USA300. I am interested in putting a furler on the Taipan 4.9 jib. Not sure it is necessary to use a Capricorn furler or maybe the harken furler they use on a hooter? Furlers I have used on dinghys have the forestay sewn in the jib. How would work for a jib that is raised up and down with a halyard with a zipper pocket? Anyone done this? Thanks
Re: roller furler [Re: binga] #101064
03/20/07 03:32 PM
03/20/07 03:32 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Should work fine - I used to sail a Tiger with a furler and that had a zipper pocket. The only issue is with battens in the jib. I don't know if the Taipan has any, but I think all the new F16 sails do.
Re: roller furler [Re: pdwarren] #101065
03/20/07 09:12 PM
03/20/07 09:12 PM
binga Offline OP
binga  Offline OP
Do you use a top swivel on the halyard? How do you incorporate the bottom furler with the forestay?
Re: roller furler [Re: binga] #101066
03/21/07 03:10 AM
03/21/07 03:10 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Yes swivels at the top. However I would suppose you'd still need to be on the beach for the tuning differences (i.e. sloop vs. cat rigged). <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: roller furler [Re: binga] #101067
03/21/07 06:42 AM
03/21/07 06:42 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
The bottom furler forms part of the forestay: attaches to the bridles underneath, and above attaches to one of those plate things with lots of holes in it (sorry, don't know the correct name). The forestay attaches to this, the multiple holes allowing you to adjust mast rake. The tack of the jib then attaches to this plate with a shackle, so the whole lot rotates when you furl it.
Re: roller furler [Re: pdwarren] #101068
03/21/07 08:22 AM
03/21/07 08:22 AM
binga Offline OP
binga  Offline OP
Does the top swivel attach to the forestay? So the forestay complete turns? And the halyard goes along for the ride? Eventhough both are inside the zippered pocket?Thanks Andrew
Re: roller furler [Re: binga] #101069
03/21/07 08:30 AM
03/21/07 08:30 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Yes - have a look at http://www.hobiecat.com/support/pdfs/tigerassy.pdf
With the F18 class dumping the requirement for furlers, you should be able to pick up some second hand bits fairly easily.
Re: roller furler [Re: pdwarren] #101070
03/21/07 09:41 AM
03/21/07 09:41 AM
binga Offline OP
binga  Offline OP
That was perfect. Thank you so much for your help. If your ever across the pond near northern New Mexico let me know. My wife and I would love to go sailing with you. Thanks Andrew.
0 registered members (), 2,643 guests, and 351 spiders.
