Battens #101071
03/20/07 06:17 PM
03/20/07 06:17 PM
Orlando, FL
tback Offline OP
tback  Offline OP
Orlando, FL
Anyone have suggestions on replacing battens?
I have Bluestreak battens and have 2 that have splintered.
My question(s) are:
* Should I replace ALL battens or just the two?
* Do I go back to the sail manufacturer (Red Head) to get the right draft cut into the battens?
* Buy them directly from Permex Products or a distributor?
* Perhaps there is a different batten manufacturer that others would recommend?
What about batten strength for cat vs sloop?
I think I read in an "ancient" post about putting x-stiff battens in the top two batten pockets for cat rigged sailing.
USA 777
Re: Battens [Re: tback] #101072
03/21/07 06:31 AM
03/21/07 06:31 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi All
I don't remember who told me this or maybe I read it somewhere, but if your replacing more than one batten, do them all, and not to put used battens in a new sail. New Sail=New Battens.
Regards
Re: Battens [Re: mattaipan] #101073
03/21/07 05:52 PM
03/21/07 05:52 PM
ncik Offline
ncik  Offline
Sounds a bit suss to me. If an old batten is the same stiffness as a new batten, they are essentially the same.
Re: Battens [Re: ncik] #101074
03/22/07 01:24 AM
03/22/07 01:24 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Yes but a new batten would be stiffer than the others, because it hasn't been curved 500 times like the rest of them, I think thats where the comment is coming from.
Regards
Re: Battens [Re: mattaipan] #101075
03/22/07 01:57 AM
03/22/07 01:57 AM
ncik Offline
ncik  Offline
I'm going to do an experiment. Measure the battens now (fairly new) then measure them in a year or so.
I expect that cheaper standard polyester glass battens like mine will lose stiffness over time, while more expensive carbon epoxy foam sandwich battens will hold their stiffness longer.
0 registered members (), 433 guests, and 132 spiders.
