maintenance #101494
03/25/07 10:02 AM
03/25/07 10:02 AM
G
gilad Offline OP
gilad  Offline OP
G
A problem that I have while I checked the boat (H16) is when I shake the boat side to side I can see some loosens in the connections between the hulls to the trampoline joints.
Does somebody have an idea how can I fix that? Tanks in advance
Gilad
Re: maintenance [Re: gilad] #101495
03/25/07 10:42 AM
03/25/07 10:42 AM
Eastern Massachusetts
swanbike57 Offline
swanbike57  Offline
The best way to fix this is to take these connections apart, clean them, and reassemble, packing the loosened joints with WEST system epoxy thickened with their high density filler. This is not a quick easy solution but it gives really high quality results.
Re: maintenance [Re: gilad] #101496
03/25/07 01:40 PM
03/25/07 01:40 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
If you don't want to make the connection permanent, cut an aluminum can into strips and use them as shims between the pylons and corner castings.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: maintenance [Re: hobie1616] #101497
03/25/07 10:54 PM
03/25/07 10:54 PM
I prefer the aluminum can method, but epoxy will make a quieter fit. Some day you might have to pull a hull off and the epoxy makes that very difficult. I think it does an effective job of ending the squeeks, which drive me crazy if there isn't enoungh wind to distract me.
Re: maintenance [Re: Karl_Brogger] #101498
03/26/07 11:35 AM
03/26/07 11:35 AM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
I second the shim idea. Yes, the glue is a solid fix, but anything permanant can come back to bite you. There really shouldn't be any squeaking with the shims in place. If there is add more shims to tighten up the joint.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
0 registered members (), 10,539 guests, and 357 spiders.
