Re: traveler [Re: Jake] #101875
03/29/07 08:14 AM
03/29/07 08:14 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
One the N20 1:1 is fine, just awarkward that the cleat moves with the traveler car.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: traveler [Re: Chris9] #101876
03/29/07 08:47 AM
03/29/07 08:47 AM
Most of us have changed that back to mounting the cleat in the center of the rear beam. I did on both the 20 and the F18 (I had one old 6.0 casting mount I used on the F18 and bought a Kevlar composite center mount from Layline for the 20)....and it's actually 2:1.
Re: traveler [Re: Jake] #101877
03/29/07 09:47 AM
03/29/07 09:47 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
yeah planned todo that this spring, but will have to wait for summer. With the cleat in the center its 2:1, but when the cleat is on the car its 1:1 isn't?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: traveler [Re: Chris9] #101878
03/29/07 10:19 AM
03/29/07 10:19 AM
it's still 2:1 even though the cleat is on the car, you still have to pull in 2' of line to move the traveler 1'.
Re: traveler [Re: Jake] #101879
03/29/07 12:31 PM
03/29/07 12:31 PM
Sure, it's really simple.
Run the line through the eyestrap. tie a simple square knot in the very end of the line (just on the line itself). Then tie another simple square knot around the eyestrap. That's it. I wouldn't believe that it would be easy to undo, but I've helped David de-rig the boat twice now and both times it was extremely easy to remove both square knots even after sailing in some substantial breeze.
Long tails though huh? I just did mine on new V2 and not sure I want to redo it but then again the line is pretty damn long.
Re: traveler [Re: PTP] #101880
03/29/07 01:06 PM
03/29/07 01:06 PM
yeah, but to take full advantage of having a split tail, the split must enter the rollers on the traveler and end just before the cleat when centered.
Re: traveler [Re: Jake] #101881
03/29/07 01:17 PM
03/29/07 01:17 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Tanks! I R idiot.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: traveler [Re: Jake] #101882
03/29/07 01:32 PM
03/29/07 01:32 PM
Makes sense, I find it hard to tie them correctly so that happens. I think I will redo it tonight when I am ignoring the idiots that come see me at 3am for stupid crap <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Oh and while we are on the subject and deviating from the original post... what type of lock stitch or method do you use (or whoever may have done your split tail) to lock the point at which the core comes out of the tail? I do the standard whiplock in/out x3 but also run the core back through the cover once. I tried the heat shrink tubing- bad idea, doesn't thread up the car very well at all.
1 registered members (FredL), 343 guests, and 59 spiders.
