| Re: Nacra 5.0 keel vs daggerboard
[Re: johnny872005]
#102031 03/29/07 09:15 PM 03/29/07 09:15 PM |
Posts: 6,049 Sebring, Florida. | The daggerboards are more work, and you had better get them pulled up before you hit the beach at speed, BUT, they do make the boat steer quicker, tack much quicker and point higher, so there's the tradeoff. That is why you see most of the new racing boats have daggerboards, while the older style "fun" cats don't. I think you will like the difference and remember, you can always pull them up half way if it is blowing hard.
Blade F16 #777
[Re: Timbo]
#102032 03/29/07 09:21 PM 03/29/07 09:21 PM |
Posts: 902 Norman,OK | I think you might be the same guy as I have been talking to on the Hobie web site but I am not sure. I am sure you will like the 5.0!
[Re: johnny872005]
#102034 03/29/07 10:04 PM 03/29/07 10:04 PM |
Posts: 902 Norman,OK | Yeah, I think the correct term is Skegs... but I could be very very wrong. I think the 5.0 is basically the same boat as the 5.2 just without the daggerboards and with skegs.
I forgot to mention that you can almost not pitchpole the 5.2 and I would imagine the 5.0 would be the same. I can drive my bows to the front crossbar and the boat will pop up and just keep running.
[Re: johnny872005]
#102037 03/29/07 10:15 PM 03/29/07 10:15 PM |
Posts: 6,049 Sebring, Florida. | Yes Johnny, you are correct. But I thought he was asking about daggerboards vs. Hobie 16 and I thought maybe he meant the 5.2, not the 5.0.
I have sailed a 5.0 (with Erez and Izzy in Tel Aviv) and it does indeed have skegs, not dagger boards, and it was great fun! But the differences between daggers or no-daggers is what I was trying to explain. Thanks for clearing it up though.
Blade F16 #777
[Re: johnny872005]
#102039 03/29/07 11:40 PM 03/29/07 11:40 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Ok guys, I'm looking to upgrade to a Nacra 5.0. My current boat is a Hobie 16 My question is, what are the actual differences between keels and daggerboards? What are the pros and cons of one or the other? Thanks The 5.0 is such a fun boat--get it and enjoy. The "skeg keel" of the 5.0 offers reasonable performance without the worries of boards when sailing on and off the beach or in shallow water. I loved sailing mine in the surf too. Also, if you sail the 5.0 upwind with the bows pretty low in the water you'll be able to point very well.
[Re: Darryl_Barrett]
#102043 03/30/07 05:49 AM 03/30/07 05:49 AM |
Posts: 1,479 Thailand | The 5.0 handles much better in the surf then the H16. Sure more buoyancy for one thing but I believe the keels just handle better. No problem with the 5.0 nose diving it’s got good handling characteristics but it’s harder to tack and is therefore not as “loose in the juice” as one with boards. Kind of like the differences between a long-board vs. short-board in surfing. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
[Re: johnny872005]
#102044 03/30/07 11:33 AM 03/30/07 11:33 AM |
Posts: 1,037 Central California | Darryl, I never said the hobie is a better surf cat? Also, I didnt understand what you meant by "Anyone who “surfs” a cat in a shore break either has more money than you can shake a stick at or is fairly silly or both)" ?
Just that cats should be used for sailing and not surfing?
When I mentioned surf previously, I meant sailing through the surf to get deeper. I enjoy "surfing" cats. The H16 and H14 (w/jib) are easier to manuever in surf (short boards) than the N5.0 (long board) because they have more rocker, less buoyancy, and are more sensitive to weight placement--all reasons they are inferior to the N5.0 for general rec sailing. Anyway, the N5.0 is a lot of fun to surf. I've never lost a rig surfing my cat, but I did see my buddy toast his H14 rig in the surf once.
#102047 03/30/07 09:22 PM 03/30/07 09:22 PM |
Posts: 1,479 Thailand | Yes the banana shape will turn easier, but it’s a trade off, practical application has proven to me that too much rocker and you get rocking horse effect and a propensity to nose dive (both not an advantage in waves). <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
[Re: avalondarlyn]
#102048 04/04/07 11:26 AM 04/04/07 11:26 AM |
Posts: 1,037 Central California | As a longtime surfer and sailor, I've had skegs and I've had keels. But I must say that when I had my 5.0 I had a "skeg keel."
484
guests, and 106
