| Re: Sail Windows
[Re: C2 Mike]
#102706 04/03/07 05:24 PM 04/03/07 05:24 PM |
Posts: 2,921 Michigan | I use the window in the main to find the lay line for the bottom mark quite often. If the bottom mark is past the back of the sail we have gone way too far and probably won't make it with the kite up.
Tiger Mike I am having trouble with that issue- overstand and then I find myself going uphill to the C mark!!!! not very efficient. Thats a good idea though. | | | Re: Sail Windows
[Re: srm]
#102707 04/03/07 07:49 PM 04/03/07 07:49 PM |
Posts: 12,310 South Carolina | I think I would sorely miss them if they weren't there...kinda one of those taken for granted things. No, you can't see through them terribly well but you can see shapes.
Jake Kohl | | | Re: Sail Windows
[Re: PTP]
#102708 04/03/07 08:04 PM 04/03/07 08:04 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | I use the window in the main to find the lay line for the bottom mark quite often. If the bottom mark is past the back of the sail we have gone way too far and probably won't make it with the kite up.
Tiger Mike I am having trouble with that issue- overstand and then I find myself going uphill to the C mark!!!! not very efficient. Thats a good idea though. I try to take note of what works and doesn't work for different wind/sea conditions as that does change our angle down wind. Not totally accurate but using the different letters as "brake markers" depending on the conditions seems to get me pretty close. Anything more than 90 deg (which ends up in the blind spot usually is inefficient (for light winds) or just means I won't make the mark if it's honking. Tiger Mike | | |
545
guests, and 38
