Stealth F16 555 #103332
04/09/07 08:46 AM
04/09/07 08:46 AM
Mark P Offline OP
Mark P  Offline OP
First sail today!! very light winds but feels really light and fast.
MP*MULTIHULLS
Re: Stealth F16 555 [Re: Mark P] #103333
04/09/07 08:50 AM
04/09/07 08:50 AM
Mark P Offline OP
Mark P  Offline OP
here's a shot showing the tack line release trigger. The spi downhaul is fed through the small steel loop then to the pulley, when the tension is taken up on the downhaul it releases the spinlock cleet fiited under the tramp on the front beam.
MP*MULTIHULLS
Re: Stealth F16 555 [Re: Mark P] #103334
04/09/07 08:53 AM
04/09/07 08:53 AM
Mark P Offline OP
Mark P  Offline OP
sexy spinnaker fairlead track
MP*MULTIHULLS
Re: Stealth F16 555 [Re: Mark P] #103335
04/09/07 08:55 AM
04/09/07 08:55 AM
Mark P Offline OP
Mark P  Offline OP
Dry land sailing
MP*MULTIHULLS
Re: Stealth F16 555 [Re: Mark P] #103336
04/09/07 09:09 AM
04/09/07 09:09 AM
Mark P Offline OP
Mark P  Offline OP
Panoramic view
MP*MULTIHULLS
Re: Stealth F16 555 [Re: Mark P] #103337
04/09/07 09:18 AM
04/09/07 09:18 AM
sexiness!
Re: Stealth F16 555 [Re: Robi] #103338
04/09/07 12:04 PM
04/09/07 12:04 PM
Scotland
George_Malloch Offline
Scotland
The tide goes out a long way doesn't it....
Stealth www.peyc.org.uk
Re: Stealth F16 555 [Re: George_Malloch] #103339
04/09/07 12:37 PM
04/09/07 12:37 PM
Mark P Offline OP
Mark P  Offline OP
Sure does but how was I expected to sail and take decent photos. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
MP*MULTIHULLS
Re: Stealth F16 555 [Re: Mark P] #103340
04/09/07 01:18 PM
04/09/07 01:18 PM
41.32 N, 81.35 W
Stuart_Douglas Offline
41.32 N, 81.35 W
Nice!
With that sail number, you should christen her "Impreza"
Re: Stealth F16 555 [Re: Stuart_Douglas] #103341
04/09/07 01:26 PM
04/09/07 01:26 PM
Nice!
Or Scooby <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Looks good Mark.
Are you going to have another block (or blocks) on the front beam for the kite sheet to turn thru before going aft again?
Like the idea of the kite bag going on top of the front beam, might copy that when I'm sailing single handed.
Re: Stealth F16 555 [Re: scooby_simon] #103342
04/09/07 02:25 PM
04/09/07 02:25 PM
Mark P Offline OP
Mark P  Offline OP
At present I'm sticking with just the one block. It was a bit difficult today to grip the sheets but that was mainly due to them being brand new, I'm sure that once they've worn in a bit there shouldn't be any problems. Too many blocks takes away any feeling and gybing slickness can also suffer. As for the snuffer end position it certainly cuts down on the downhaul friction which can be caused by coming up through a grommet in the tramp.
555 is one stiff baby and feels a load lighter than "Little Feat" I did have a little more weather helm than I would normally like but apart from that and a few little tweaks with the downhaul loops on the kite everything surpassed my expectations I can't wait to sail her again in a breeze. Which hopefully will be next Sunday.
MP*MULTIHULLS
Re: Stealth F16 555 [Re: scooby_simon] #103343
04/09/07 02:29 PM
04/09/07 02:29 PM
I was thinking about copying the above-tram snuffer bag end for doublehanding as well. Any reason not to do so for doublehanding vs. singlehanding?
The spi fairlead looks good, another thing to think about for us. The tramp "hooks" or rings on Marks boat was nice. But why do the sailmaker still use the web loops on the tramp instead of sewing metal rings into the loops or using the glass rod system?
Another small thing while I am drooling over the pics. Why are the chainplates om the outside? It's no big deal, but personally I think the boat looks better with the chainplates on the inside.
Is that you holding the spi sheet Mark? Always nice to be able to put a face to the personalities on catsailor.com. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Congratulations on the new pretty Mark!
Re: Stealth F16 555 [Re: Rolf_Nilsen] #103344
04/09/07 03:05 PM
04/09/07 03:05 PM
Be interested to find out your mast rake (and assuming the mast foot is in the same place as we have different beams) as I'm not sure how much weather helm is "right" as the 17 had almost none, but my 16 appears to go well with a fair bit), I believe we have the same mainsail.
Been OK with gybing so far as I have 2 ratchamatics and so they run free as soon as the tension is off.
The aft end of the bag will get in the way of the self tacker.
Re: Stealth F16 555 [Re: scooby_simon] #103345
04/09/07 03:10 PM
04/09/07 03:10 PM
I think there might be room for it on our boat, but it's something to check/test. I like both the looks and the simplicity.
Re: Stealth F16 555 [Re: Mark P] #103346
04/09/07 03:11 PM
04/09/07 03:11 PM
I'll be looking forward to seeing you and your new boat at the Zandvoort event.
Mind you everyone seems to be getting new boats to do this event !
Re: Stealth F16 555 [Re: Mark P] #103347
04/09/07 05:18 PM
04/09/07 05:18 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Looks great, Mark. Very interesting setup you've got on the kite with the tack release thing. Does that pull the top of a spinlock? Or something else? Looking forward to seeing it in action...
You not coming to Datchet, then? If you come to Datchet you've got an excuse to sail on Saturday too <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Stealth F16 555 [Re: pdwarren] #103348
04/10/07 01:18 AM
04/10/07 01:18 AM
Mark P Offline OP
Mark P  Offline OP
In the photo of the Spi fairlead you'll notice a yellow line, that is the spi tack line. Once the tack has been deployed the spinnlock cleat jams automatically due to the pressure. I drilled a 2mm hole through the top of the spinnlock cleat for the trigger line attachment and added the loop on the other end which the spi downhaul line is led through.
It is harder to set up than the single line system and needs quite a bit of tweaking to get just right but the Spi hoist is so much quicker and (easier) than the single line the extra hassle seems worth it.
As for Datchet I would love to attend but I wouldn't be able to afford the divorce settlement.
MP*MULTIHULLS
Re: Stealth F16 555 [Re: Mark P] #103349
04/10/07 02:45 AM
04/10/07 02:45 AM
Bjärred, Sweden
Pontus_Lofgren Offline
Bjärred, Sweden
The boat looks really good. I hope you will send some more pics later, it is always nice to see details of the different F16´s.
Ps Once again, thanks a lot for the illustrations of the jib set up.
Stealth F16 NED 535
Re: Stealth F16 555 [Re: Mark P] #103350
04/10/07 03:55 AM
04/10/07 03:55 AM
Can you post more pictures of this system ? I still don't really get how it works. I thought it was still a single line system.
Re: Stealth F16 555 [Re: scooby_simon] #103351
04/10/07 04:27 AM
04/10/07 04:27 AM
waynemarlow Offline
waynemarlow  Offline
I ran my kitebag on top of the tramp for a while and works really good until you turn the boat over on its side with the spinnaker out. It was really difficuly getting around to the up side of the tramp to recover the spinnaker without fully turtleing the boat. At least with the bag on the under side you can reach the recovery rope whilst preventing the boat from fully turning over. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
0 registered members (), 19,857 guests, and 1,091 spiders.
15 hours ago
