| 10:1 Mainsheet and cordage #104470 04/23/07 12:07 PM 04/23/07 12:07 PM |
Posts: 1,459 Annapolis,MD | Ok, did a little searching and still feel like asking...
We're going to the 10:1 mainsheet system on the N-20. So it's time for a new mainsheet as well. It sounds to me like the Swiftcord/Salsa/Conception type line is a great way to go (just did the spin sheets with that, with a Vectran tail). So, the questions are:
What length is appropriate for the 10:1 system on the N-20 (say whether you are including the traveler line with that measurement)?
What thickness is working well for people? Obviously the trade off between running through the blocks and hand comfort, but what are folks using and does it work well?
Are people using this line for the whole length through the blocks, or splicing it something else like Vectran for the run through the blocks? Anybody seen any issue (other than cost) for running the whole system with it?
Time's running thin, don't have too much more time for experimentation. Thanks for the info ahead of time! | | | Re: 10:1 Mainsheet and cordage
[Re: Keith]
#104471 04/23/07 12:33 PM 04/23/07 12:33 PM |
Posts: 2,921 Michigan | Plain vectran (like vectrus) is relatively cheap but you can't hold onto it. Tapering is the way to go (figure you know what this is.. but it is stripping the cover off the core and burying it so it has a nice taper and runs through blocks perfectly. you end up with a smaller diameter, slippery high tech core going through the blocks). Lines like Marlow V2 (may be discontinued) have a vectran core which can be tapered. For some reason, the taper doesn't look as nice with the vectran core as it does with a dyneems core (marlow D2- which I think may have been discontinued as well). I did a taper on the same diameter V2 and D2 and the D2 lookes much better... BUT... not talking about looks. I think the problem with the salsa/conceptions stuff is that it can't be tapered (maybe I am wrong here, but it is listed as a single braid) so you are stuck with the whole diameter running through everything. 5/16 I think is the ideal size and shouldn't be a problem with a 10:1 purchase system. You could be the first on the block with the new Paraloc line (check out aps.com) which looks interesting but isn't taperable either. I would go with 5/16 D2 (if you can find it still) with a taper. Can't help with the length though.. sorry, but on my boat with 9:1 blocks and using the tail as the trav line, I use 45 feet and it seems a little long. I would start with 50-55 (???) for your boat and decrease from there. If you can't find the D2, warpspeed would be perfect and is very easily tapered. One thing that I think I will try in the future is use some vectran but either have someone (aps, trey, etc) put a cover ON it or do it myself. hope I didn't confuse you or anything.. lines can get complicated.
[Re: mikekrantz]
#104473 04/23/07 01:28 PM 04/23/07 01:28 PM |
Posts: 2,921 Michigan | My preferred solution is to start with a 5/16" Robline Racing Sheet (can also use Salsa, Buzz, or Conception), and brummel splice it to 3/16" spectra. It takes more time to get the splice right, but gives you a soft handling line with a durable 12-strand product in the blocks.
is there a diagram anywhere as to how to do that splice? | | | Re: 10:1 Mainsheet and cordage
[Re: mikekrantz]
#104474 04/23/07 02:23 PM 04/23/07 02:23 PM |
Posts: 1,459 Annapolis,MD | My preferred solution is to start with a 5/16" Robline Racing Sheet (can also use Salsa, Buzz, or Conception), and brummel splice it to 3/16" spectra. It takes more time to get the splice right, but gives you a soft handling line with a durable 12-strand product in the blocks. With all the drag of a 10:1 system, this route makes the most efficient use of the blocks, especially in light to moderate air.
Thanks! One question - The 51 feet overall includes the traveler line, correct? Do you splice something on to do the split tail for that?
[Re: Todd Berget]
#104481 04/24/07 10:19 AM 04/24/07 10:19 AM |
Posts: 5,590 Naples, FL | You are not using a continuous line from mainsheet to traveler? Do you prefer this for some reason?
I've had trouble keeping track of two separate lines (mainsheet/traveler) during crash tacks/gybes, and thought it was more convenient to have one single line for both.
I'd like your thoughts on the two-line setup.
386
guests, and 47
