Hobie 16 Single handed righting??? #104574
04/24/07 08:34 PM
04/24/07 08:34 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
Can a sailor weighing 178lbs. and 5'11" tall right a Hobie 16' easily using the "Power Pole" system???
I do quite a bit of solo sailing and have on occasion pushed the light air Wild thing by being up by the mast, with my shoulder under the boom, then Oooops there it Is!
It would be great to be able to put her back on her feet with-out havin assistance.
Any pole users out there?
Thanks! Scott
Re: Hobie 16 Single handed righting??? [Re: root] #104575
04/24/07 09:42 PM
04/24/07 09:42 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I am not sure about the 16 but I home built a righting pole for my Nacra 5.2 and I can right it at 160lbs. But in light wind it takes a while, but in heavy wind I have actually righted it without the pole and one time I was still in the water.
Re: Hobie 16 Single handed righting??? [Re: gree2056] #104576
04/25/07 10:08 AM
04/25/07 10:08 AM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
gree2056
Do you have any pictures of how you did the base etc.???
I have a carbon 2-piece windsurfing mast that might be just the ticket for the pole. I only have rubber U-joint mast feet tho. and it looks like the mechanical universal base would be better.
Scott
Re: Hobie 16 Single handed righting??? [Re: root] #104577
04/25/07 10:12 AM
04/25/07 10:12 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I don't have any already taken and the digital camera is with my dad in Alaska, but I can try and get some with a disposable sometime soon.
The carbon mast should work well, I used an old pole vault pole that had been broken.
Re: Hobie 16 Single handed righting??? [Re: gree2056] #104578
04/26/07 04:28 PM
04/26/07 04:28 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
Might anyone have any other equipment suggestions that will work for a 178lb. solo sailor in righting the 16'???
Thanks!
Scott
Re: Hobie 16 Single handed righting??? [Re: root] #104579
04/26/07 04:50 PM
04/26/07 04:50 PM
A couple of black trash bags filled with water. Several guys do it.
Re: Hobie 16 Single handed righting??? [Re: fin.] #104580
04/26/07 05:59 PM
04/26/07 05:59 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
How dust thou use this Ghetto method??
Does one fill them by pulling them thru the water then tie the bags together, then sling them over one's shoulder then stretch out holding on to the righting line??
Sounds like I would need a couple of wk's in the gym before trying this out!
Re: Hobie 16 Single handed righting??? [Re: fin.] #104581
04/26/07 08:17 PM
04/26/07 08:17 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
Could you please explain the steps. I'm all about ghetto sailing. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Rob V. Nacra 5.2 Panama City
Re: Hobie 16 Single handed righting??? [Re: root] #104582
04/26/07 08:28 PM
04/26/07 08:28 PM
I don't. Tback and Tshan use it. At 178lb and 5' 11" you wouldn't need much, 10-20 lbs.
I think Tback (only say him do it once) doubles a bag, fills it about 1/3 full and just rests it in his lap.
You should be able to reach them on the F16 forum.
Re: Hobie 16 Single handed righting??? [Re: Redtwin] #104583
04/26/07 09:10 PM
04/26/07 09:10 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
ATRS = Alabama Trash Righting System.
I carry two 33 gallon (extra heavy duty) trash bags in my tramp (one is a spare in case the first bursts or tears). If the wind is really blowing I don't need it... but lighter winds I can just lift the mast tip clear of the water but not right the boat...
... this is when the ATRS comes in handy (note author of this system is none other than tshan). I pull a bag out and while trapped using the righting line, I fill the bag with water (not too much or it will burst) and lift it onto my lap. The boat almost instantly comes up right--depending on weight of the skipper.
Double handed no ATRS system necessary.
USA 777
0 registered members (), 2,651 guests, and 342 spiders.
