| Re: P-19 roller furling and jib halyard conversion
[Re: peter]
#104728 04/25/07 11:24 PM 04/25/07 11:24 PM | Anonymous
| Anonymous
Unregistered | Peter: I got a system like what Murray's sells for the Hobie with the bridle pole and the 18" track and the Hexarachet blocks, then had a custom reacher cut. It is 78 sq ft. The boat FLYS. Let me know if you have any questions? http://www.thebeachcats.com/modules.php?...=view_album.phpDoug Snell 832 533 4506 dsnell4 at houston dot rr dot com | | | Re: P-19 roller furling and jib halyard conversion
[Re: ]
#104729 04/26/07 08:04 AM 04/26/07 08:04 AM |
Posts: 829 Charleston, SC | Doug, you really got a reacher put on your H17? When did that happen? How come you haven't mentioned that before?
Trey
[Re: NCSUtrey]
#104730 04/26/07 01:20 PM 04/26/07 01:20 PM | Anonymous
| Anonymous
Unregistered | Doug, you really got a reacher put on your H17? When did that happen? How come you haven't mentioned that before? Trey: Got one after I added Sport setup. Stack jib did NOT work at all. Check the above link for pics and modifications. How did TackTic work? Doug | | | Re: P-19 roller furling and jib halyard conversion
[Re: peter]
#104733 04/26/07 06:06 PM 04/26/07 06:06 PM | Anonymous
| Anonymous
Unregistered | My reacher has a zipper. Forestay has a pulley that pulls the reacher up. There is a wire forestay. Some of the old jibs had a built in forestay, zipper is better.
[Re: ]
#104734 04/26/07 09:12 PM 04/26/07 09:12 PM |
Posts: 264 Long Island, NY | I have the MX sails. I altered the typical ring setup to one that allows me to adjust the luff tension while under sail. In addition to a sheave up top on the pigtail I added one at the bottom where the forestay meets the jib-pole. From there the jib halyard goes thru a 3:1 purchase before going to a jam cleat on the main beam. The line that goes to the main beam is separate from the excess line that is leftover after the jib has been raised. I connect these with tiny shackles that require a slotted screwdriver to tighten and loosen. You have to have a steady hand if it's blowing when you are trying to set sail. Otherwise it works great. I'll send photos when I get my boat rigged this month if you are interested. Greg
G Gove
Blade #728
Long Island, New Yawk
[Re: gregP19]
#104735 04/26/07 10:18 PM 04/26/07 10:18 PM |
Posts: 41 los angeles | I'd be interested. My P19 had the jib pole setup for the MX jib when I bought it in November, but the boat only came with the standard jib, so I simply removed the poles. I've still got them, and can put them back on in 5 minutes or so. Your system sounds great, and I'm thinking there probably is a way to do something similar with the standard jib and furler, although the furler adds an extra complication to the mix.
20,198
guests, and 971
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online21,917 2 hours ago | | |
