Blade 002 #104894
04/26/07 06:51 AM
04/26/07 06:51 AM
Central Coast NSW Australia
TonyJ Offline OP
TonyJ  Offline OP
Hay folks
A quick up-date on 002's progress.
My project lives at work and I try to spend approximately 2 hours every Tuesday & Thursday afternoon. Except for the last month. I must thank Phill who comes up and helps out when he gets a chance.
I would like to congratulate all the people working on their home builds and renovations. You have to love a class that allows for everything from full spec productions boats to people cutting and shutting A’s and mosquitos to the DYI home builds, and even then their experimenting with different production methods.
This photo shows the hulls standing up next to racks of core-cell.
All the rear deck supports are in and shaped, and the fairing process has started. I have used S Fair 600. Its easy to use, just mix 50 - 50 Hardener & Resin, apply, and it will set over night.
The deck supports have been fitted with Spa bond 345 slow. It is a dual cartridge that is squeezed into a mix head and applied as if you were using a silicone gun.
Teach them how to think. Not what to think. Aus Blade 002
Re: Blade 002 [Re: TonyJ] #104895
04/26/07 07:02 AM
04/26/07 07:02 AM
TonyJ Offline OP
TonyJ  Offline OP
In this photo the bow is taking shape.
Re: Blade 002 [Re: TonyJ] #104896
04/26/07 07:10 AM
04/26/07 07:10 AM
TonyJ Offline OP
TonyJ  Offline OP
A little dusty after some sanding, but a shot from the transom showing the rear deck supports.
Re: Blade 002 [Re: TonyJ] #104897
04/26/07 07:14 AM
04/26/07 07:14 AM
TonyJ Offline OP
TonyJ  Offline OP
1st round of fairing and ready to start sanding. It gives a good view of just how flat the hulls are on the Blades.
Re: Blade 002 [Re: TonyJ] #104898
04/26/07 09:35 AM
04/26/07 09:35 AM
why the ribbing?
Re: Blade 002 [Re: PTP] #104899
04/26/07 03:49 PM
04/26/07 03:49 PM
TonyJ Offline OP
TonyJ  Offline OP
If you have applied any bog to a car you will know that it's impossible to get the surface spot on first go.
The same applies here, you use a long sanding board and sand until the high spots of the keel jus start to appear. Do this to the entire length that has been faired. You will notice that you still high and low spots. In some cases I will hit glass and still have low spots. At least now the low spots won't be as low as when I started. Repeat the process, but this time I won't need to apply as much. If Iam lucky it should be just how the plans say after two goes. If Iam really fussy, I might spray a very fine mist of black paint over the fairing and lightly sand, any paint that disappears is a high spot, so I either sand some more or fill the low spots. It will depend weather the high spot is glass, if so I will have no option but to do some more filling.
I weighed the port hull yesterday and it came in at 22.8 kilograms. So with a bit more fairing to go, a little glass around the bow , the deck to be added and then the paint, Iam hopeful it will weigh in at 26 kilograms.
This photo shows pallet strapping holding the hull to a saw horse while I work on it.
Re: Blade 002 [Re: TonyJ] #104900
04/26/07 05:54 PM
04/26/07 05:54 PM
ncik Offline
ncik  Offline
Nice!
I'm going to try to fair a slightly different way. Using a long (1-2m) aluminium batten with about 3 ppl along it bending it against the hull. Only do one sweep at a time on a particular area so you don't stuff up the previous sweep. Cover the whole area you want to fair then sand. Repeat until you're happy with the fairness. I've seen this done on larger boats and it works well. I'll let you know how it goes.
Re: Blade 002 [Re: ncik] #104901
04/26/07 10:01 PM
04/26/07 10:01 PM
Ft. Pierce, Fl. USA
Seeker Online content
Seeker  Online Content
Ft. Pierce, Fl. USA
You guys ought to look into some sprayable faring compound...Awlgrip makes some great product.
Bob
Re: Blade 002 [Re: Seeker] #104902
04/27/07 12:42 AM
04/27/07 12:42 AM
ncik Offline
ncik  Offline
From talking with professional fairers, (expensive) spray bog is used after using (cheap) microballons and epoxy fairing compounds applied with a batten.
Re: Blade 002 [Re: ncik] #104903
04/30/07 03:55 AM
04/30/07 03:55 AM
TonyJ Offline OP
TonyJ  Offline OP
Sanding the Fairing.
What long board should I use ?
Re: Blade 002 [Re: TonyJ] #104904
04/30/07 04:08 AM
04/30/07 04:08 AM
TonyJ Offline OP
TonyJ  Offline OP
I tried to get some good photos of my sanding effort today. But the light doesn’t do it justice.
If you look close enough at the transom you can see the fairing has hardly been touched. It will need refilling. (the lowest spot on the boat) But 40cm further up glass is already showing ( a high spot) Then another low spot just before the centre board case. And then another high spot on the centre board.
It was a lot more sanding than I thought, but I got that much done in 1 ½ hours.
TJ
Re: Blade 002 [Re: TonyJ] #104905
04/30/07 04:21 AM
04/30/07 04:21 AM
Tony,
Allow me to invite you to make your own gallery in on F16 forum just like Nick has done. See these links.
Main gallery menu : http://www.formula16.org/component/option,com_gallery2/Itemid,26/lang,en/
User gallery menu : http://www.formula16.org/component/option,com_gallery2/Itemid,26/lang,en/?g2_view=core.ShowItem&g2_itemId=19
Nicks picture pages : http://www.formula16.org/component/option,com_gallery2/Itemid,26/lang,en/?g2_view=core.ShowItem&g2_itemId=3572
I know that alot of forum readers (alot of them lurkers) just love to look at building pictures and also this way you experiences will find a large audience. You can place comments with each picture. The thumbnailing and such is all done automatically. It is actually a very easy task to create and maintain such a picture page.
Re: Blade 002 [Re: Wouter] #104906
04/30/07 05:45 AM
04/30/07 05:45 AM
It would be good if Tony does start posting pics on the F16 site.
He is now working for a large global resin and laminate distributor and has picked up some interesting ideas.
His upcoming experiments may be worth watching.
Re: Blade 002 [Re: phill] #104907
05/11/07 01:54 AM
05/11/07 01:54 AM
TonyJ Offline OP
TonyJ  Offline OP
Up Date.
I have been fairing, and fairing, and fairing.
Up to 3rd layer now and looking forward to sanding it down again. Should be very close to finished, although I suspect I amy have to add a little more in two places.
Interesting to note that less than 1kg has been added to eaither hull, and that is with 3rd layer still on.
This photo is after layer 2.
TJ
Re: Blade 002 [Re: TonyJ] #104908
05/11/07 01:55 AM
05/11/07 01:55 AM
TonyJ Offline OP
TonyJ  Offline OP
Another pic
Re: Blade 002 [Re: TonyJ] #104909
05/11/07 02:09 AM
05/11/07 02:09 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I am getting very jealous of those of you who have boat that are getting closer to being finished. I can't wait to start!
Re: Blade 002 [Re: TonyJ] #104910
05/11/07 03:04 AM
05/11/07 03:04 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Tony
Can you tell us what type of filler your using? brand? I'm assuming you sell the product?
Anything else we can buy from you for this type of project?
Regards
Re: Blade 002 [Re: TonyJ] #104911
05/12/07 07:29 PM
05/12/07 07:29 PM
ncik Offline
ncik  Offline
Re: Batten and torture board length...The longer the better from what I've heard and seen.
But you obviously have to use what is practical. If you're applying and sanding yourself, then I suspect 1m is the maximum you'd be able to use effectively. I've found that with my hull shape and applying with only one person, about 60cm is the max I can use of my 1m batten.
Re: Blade 002 [Re: mattaipan] #104912
05/13/07 05:06 AM
05/13/07 05:06 AM
TonyJ Offline OP
TonyJ  Offline OP
The filler I use is S Fair 600. It is one of our products.
The company I work for is Gurit. We were called SP Systems in Australia. http://www.gurit.ch/index_en.html
We can and do supply most composite materials the marine industry needs. We supply full engineering specs, infusion materials, honeycomb products, Core-Cell foam, epoxy resins & hardeners, fibreglass, aramids, carbon fibre, pre pregs and much much more.
We can supply by the container or the meter, and ship it any where in Australia or around the world.
We have lots of boat builders come through and they all think it's a laugh Iam building a timber boat surrounded by high tech heaven.
I apply the flat coats with the litte bit of red plastic. The stripes are applied with a home made piece of angle with notches cut out of it.
TJ
TJ
Re: Blade 002 [Re: TonyJ] #104913
05/13/07 05:12 AM
05/13/07 05:12 AM
TonyJ Offline OP
TonyJ  Offline OP
Ok I got my photos mixed up.
The previous photo is the long sanding board I use to do most of the sanding. Aprox 1.5 mts long, seems to work well.
This photo is fo the S fair. It is a little blury because I can see an insect the view finder, but I cant find the insect.
TJ
1 registered members (Seeker), 465 guests, and 294 spiders.
