| Repair hull Stealth F16 #105286 04/29/07 04:26 PM 04/29/07 04:26 PM |
Joined: Jan 2006 Posts: 23 Bjärred, Sweden Pontus_Lofgren OP
Posts: 23 Bjärred, Sweden | I noticed a very small hole in my boat, what would you recommend that I fix this with? Gelcoat?
Stealth F16
NED 535
| | | Re: Repair hull Stealth F16
[Re: Pontus_Lofgren]
#105287 04/29/07 04:51 PM 04/29/07 04:51 PM |
Posts: 1,246 Orlando, FL | is it thru the figerglass? or simply a ding in the gelcoat?
USA 777
[Re: tback]
#105288 04/29/07 05:01 PM 04/29/07 05:01 PM |
Posts: 23 Bjärred, Sweden | The first white layer (gelcoat?) is gone, I can see the foam inside. The hole is about 1 cm.
Stealth F16
NED 535
#105289 04/29/07 05:05 PM 04/29/07 05:05 PM |
Posts: 1,246 Orlando, FL | Read thru THIS post and see if some of your questions get answered. And this one for a general discussion of fiberglass repair.
USA 777
#105291 04/29/07 05:11 PM 04/29/07 05:11 PM |
Posts: 2,921 Michigan | Grind it out a little. Let it dry completely. Put tape around the hole leaving the hole exposed and maybe 3/8 inch surrounding it. For 1 cm I would use epoxy with some chopped glass in it with some structural filler. Then sand and re-gelcoat or use my version of gelcoat- 98 cent gloss white spray paint after you take off the tape to blend it. OR.. use marine-tex. You could use marine tex but 1 cm may be getting up there in size for it. easy to use, easy to sand. Hard to mix right in small amounts though. btw.. didn't read the link given.. so I apologize if this is redundant.
These things are very person dependent. One guy i know who has built boats would recommend grinding out A LOT of the surrounding glass and foam then re-layering cloth, etc. I think that is excessive unless it is a high stress area.
[Re: fin.]
#105294 04/29/07 06:44 PM 04/29/07 06:44 PM |
Posts: 2,921 Michigan | Anyone having any luck getting the exact gelcoat tint? gotta call the manufacturer for that I believe. | | | Re: Repair hull Stealth F16
[Re: fin.]
#105296 04/29/07 08:24 PM 04/29/07 08:24 PM |
Posts: 1,246 Orlando, FL | Pete,
I've been mixing some acrylic tint (I can't remember the color for the moment) with white gelcoat. I mix a small batch and dab some on the hull. If the color isn't right I wipe it off and add another drop of tint (do this before adding the hardener). Repeat until you get the desired color.
You can get pretty close.
USA 777
[Re: tback]
#105297 04/29/07 08:32 PM 04/29/07 08:32 PM |
Posts: 3,348 | It is also possible to "blend" the color. spray each coat over an increasingly large area until the color difference is minimized. Easier to say than do.
T: I haven't done any of this in over ten years. I'd appreciate knowing which specific materials you're using, if you have a chance.
thanks,
[Re: fin.]
#105298 04/29/07 09:06 PM 04/29/07 09:06 PM |
Posts: 1,246 Orlando, FL | I'll look what tint I have when I'm over to the condo' next ... (I think it is Raw Ciena)... anyway our boats are the same shade (I think) and I'm getting ready to do some daggerboard repair ... so I'll mix up a little batch for you.
USA 777
361
guests, and 45
