Adjustable Jib Halyard #105323
04/29/07 07:53 PM
04/29/07 07:53 PM
Sail Sand Point, Seattle
mike220 Offline OP
mike220  Offline OP
Does anyone know if the jib halyard can be set up to be adjustable from the tramp?
Hobie Tiger with jib furler.
I can lead the jib halyard down thru the furler to a block then back to the tramp.
If I do this and tie the block to the spin pole, will that put the tension for the halyard in the wrong place?
Thanks
Mike Hensel
Hobie Tiger
Re: Adjustable Jib Halyard [Re: mike220] #105324
05/08/07 10:55 AM
05/08/07 10:55 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Yes it can. You have a furler so I will go there. When you look at the furler from the top you will see that there is a hole through the top. It may only take a very thin line but you can put something there. After you tie the thin line to the tack of the jib then trough that hole you have to figure out a turning block system to get it to the bridle tang at the hull. From there back to a cleat on the crossbar. If this does not make sense I will try to draw it for you.
Later,
Dan
0 registered members (), 273 guests, and 54 spiders.
