| Rules question #106044 05/06/07 08:12 AM 05/06/07 08:12 AM |
Joined: Dec 2006 Posts: 16 Jacksonville, FL BGolum OP
Posts: 16 Jacksonville, FL | Hi all, I've mostly been crew on monoslugs for my racing career. Since purchasing my Hobie 18 a few years ago I've been trying to better understand the rules. Last night I was reading the US Sailing Casebook 2006 and came across Case 11 on page 63 and it's been bothering me. Since I haven't been a skipper for very long I could be mistaken, but I totally disagree with the decision of this case. Based on my knowledge I believe PW has no rights in the situation and should have tacked. To do anything else was a violation of the rules by PW. I've never heard of another boat being called an obstruction. I'd like to hear your thoughts? Brian | | | Re: Rules question
[Re: BGolum]
#106045 05/06/07 09:30 AM 05/06/07 09:30 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I am definitely not a rules expert, so it bothers me, too, because I have been in a very similar situation where I was PL. PW was yelling at me for room to pass behind the starboard boat. I'm thinking, "What the heck is that about?", because PW had plenty of room to tack to avoid the starboard boat.
In my case, PW also had plenty of room to pass behind the starboard boat anyway, so did not need to yell at me for room. However, it has been bothering me ever since, because I just didn't understand the hail by PW. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
It might make some sense if there were another boat close above PW making it impossible for PW to tack (in which case I would think that "other boat" to windward would actually be the "obstruction), but that was not the case in either situation.
Maybe somebody can explain this to us. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> | | | Re: Rules question
[Re: George_Malloch]
#106054 05/06/07 12:52 PM 05/06/07 12:52 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | There are two different situations here. The one in the ISAF precedent which Brian raised originally where PL doesn't need to tack or alter course to avoid S but PW does - and where PW can demand water from PL to allow him to cross behind S. The other situation is where PL does have to do something to avoid S and can either bear away behind S (and must still give PW room to do the same) or can choose to hail PW for room to tack - in which case PW must give PL room to tack. PL does not have to bear away behind S even if PW wants to go that way. The second scenario makes sense. The first one sounds like unwarranted charity. BW got hmself into that situation, and he should get himself out by tacking. It's not like he doesn't have any option. What is scary about this whole thing is that the obstruction definition seems to be saying that all this is happening within one boat length of the "obstruction." I don't think that is even realistic for Optis, much less for catamarans. (Or maybe I am not understanding that part of the definition, since apparently I don't understand much about anything.) <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
| | | Re: Rules question
[Re: Mary]
#106055 05/06/07 02:15 PM 05/06/07 02:15 PM |
Posts: 12,310 South Carolina | What it's telling you is that you cannot use other boats as a "pick" (common, but not always legal, basketball / football maneuver). It makes sense to me. It would be a dangerous to boat S if you were allowed to do so.
Jake Kohl | | | Re: Rules question
[Re: Dan_Delave]
#106060 05/06/07 11:03 PM 05/06/07 11:03 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I'm glad that I now understand that rule, because if I am PL I will know why PW is yelling at me. And if I am ever PW, it is nice to know that I have the option of asking for room to go behind S.
But in the illustrated case, I think that for PW to try to, at that point, bear off on a reach and go behind S would be the most dangerous scenario, especially for catamarans. If you are talking safety, the safest thing for PW to do at that point is to tack -- especially, of course, in heavy air.
I know, I'm a wimp. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
P.S. I still don't understand the part about being one boat length away from the obstruction. Maybe somebody can explain that. | | | Re: Rules question
#106061 05/07/07 12:24 AM 05/07/07 12:24 AM |
Posts: 11 | P.S. I still don't understand the part about being one boat length away from the obstruction. Maybe somebody can explain that. [/quote]
I think it is a matter of relative size. For instance, if you are 10 mi away from a small island, a small change in course will allow you to miss it, but because when you are one boat length away, you can't miss it without substantially altering your course, the island is an obstruction. By the same logic, a lobster buoy will not be an obstruction, because when you are one boat length away, it will only take a small alteration in course to miss it. That is how I would read it.
From definitions section of RRS:
"Obstruction An object that a boat could not pass without changing course substantially, if she were sailing directly towards it and one of her hull lengths from it. An object that can be safely passed on only one side and an area so designated by the sailing instructions are also obstructions. However, a boat racing is not an obstruction to other boats unless they are required to keep clear of her, give her room or, if rule 21 applies, avoid her."
As the inside boat PW is entitled to room to pass the obstruction in terms of rule 18.2. [/quote] | | | Re: Rules question
[Re: sbp19]
#106062 05/07/07 12:59 AM 05/07/07 12:59 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | "Obstruction An object that a boat could not pass without changing course substantially, if she were sailing directly towards it and one of her hull lengths from it. If an obstruction does not become an "Obstruction" under the rules until you are one boat length away from it and realize you cannot avoid it, that is a little late to take evasive action; isn't it? I'm just wondering how that definition works in conjunction with the rule being discussed. | | |
2,819
guests, and 106
