Kickup T foil rudder #106508
05/09/07 06:43 AM
05/09/07 06:43 AM
Brighton, UK
grob Offline OP
grob  Offline OP
Brighton, UK
What do people think of this kickup T foil rudder setup?
The system is very simple. The T-foil is attached to the bottom of the main rudder blade, and is allowed to pivot freely. Referring to the sectioned plot below, the T-foil is also attached to the rudder box via a line that runs through the rudder blade. When the rudder blade is in the vertical deployed position the line pulls the T-foil tight against the bottom of the rudder blade holding it in a horizontal sailing position. When the rudder blade is released to swing to the horizontal position the T-foil is also automatically released.
Although this is currently shown on a Dotan stock (as this is what I use) it can be retrofitted to any existing kickup rudder system.
Gareth
Re: Kickup T foil rudder [Re: grob] #106509
05/09/07 07:34 AM
05/09/07 07:34 AM
Not enough distance difference as a result of the pivoting to pull the T-foil in tight.
The radius from the fullcrum to the point where the line enteres the rudder boards is too short.
Maybe have a pully on the stern and a clear on the rearbeam so the skipper can activate and deactivate the T-foil ? (an idea I had for the F12) But still have the problem of the line stretching resulting is a flapping T-foil possibly damaging the rudder board itself.
Re: Kickup T foil rudder [Re: grob] #106510
05/09/07 07:46 AM
05/09/07 07:46 AM
Interesting thought. I would first be concerned about flutter of the foil if it kicks up while the boat is moving at any decent speed...that is, unless you built in some imbalance stability into the foil - but that would result in undesirable drag during normal attitude. I know first hand that control surface flutter can be violent and result in the death of a model airplane!
The geometry between the pivots and the line seems to be a bit off - but that might actually take care of the potential for flutter if it can be arranged put the foil at a slight bit of a "down plane" attitude when it is released.
Re: Kickup T foil rudder [Re: Jake] #106511
05/09/07 08:04 AM
05/09/07 08:04 AM
Why not just improve the lifting mechanisim on the present casette type T foil rudders? Personaly I like the idea of only having half the rudder, or less, down when coming in to or departing the beach. You will still have a lighter helm than with a kicked up rudder, which can be hard to steer in big wind and waves. And it would seem the casette type system would be lighter, less moving parts to break, etc.
Could someone who uses the present T foil rudders please post a close up picture of the headstock and the rudder in both the up and down possition, and tell us how it works? Thanks.
Re: Kickup T foil rudder [Re: grob] #106512
05/09/07 08:12 AM
05/09/07 08:12 AM
Lake Norman, NC
Special_Treat_P182 Offline
Lake Norman, NC
I'm curious... Why foil the rudder? We're not talking about foiling the entire boat to raise it out of the water, just the rudder. What does creating lift on the rudder accomplish other than raising the transom a bit? I don't see it as improving helm performance or balance. So if you want to raise the stern, why not simply move crew forward? At least on my Prindle, if the crew is near the front crossbar, I can raise the stern quite a bit.
It just seems as though it's a complicated design which introduces another point of failure (and expensive failure at that) for very little gain or at least a gain that be gotten from simply repositioning the crew on the boat.
Re: Kickup T foil rudder [Re: Special_Treat_P182] #106513
05/09/07 08:24 AM
05/09/07 08:24 AM
Its supposed to keep boats with not enough bouyancy up front from pitchpoling.
As the muscle car guys say, in my opinion,
"There's no replacement for displacement (in the bows)"
Re: Kickup T foil rudder [Re: MauganN20] #106514
05/09/07 08:30 AM
05/09/07 08:30 AM
Lake Norman, NC
Lake Norman, NC
So again, is this an overly-complicated solution to a rare problem? I know of Hobie and Prindle 16's that were more prone to pitchpoling, but most modern cats aren't. I installed the cheap anti-pitchpoling foils on the bows of my old Hobie-16 and they seemed to work very well for a hundred bucks. Afer that pitchpoling the 16 required a serious mistake on my part.
Re: Kickup T foil rudder [Re: grob] #106515
05/09/07 08:48 AM
05/09/07 08:48 AM
Chicago, IL
Krisu13 Offline
Krisu13  Offline
Chicago, IL
If you are not going to do any backward sailing - just eliminate the line going through rudder blade.
I20
Re: Kickup T foil rudder [Re: Special_Treat_P182] #106516
05/09/07 08:55 AM
05/09/07 08:55 AM
The guys who have them like them, I think the Stealth (F16 type) has them, they say they really smooth out the ride and keep you from nose diving in a windy gibe. The Jurry is still out on wether they are "faster" or not, but swimming is slow.
Re: Kickup T foil rudder [Re: Timbo] #106517
05/09/07 08:55 AM
05/09/07 08:55 AM
I hadn't thought of that - boy that would be really nice.
Re: Kickup T foil rudder [Re: Jake] #106518
05/09/07 09:11 AM
05/09/07 09:11 AM
The German built Topcat uses a cassette system which is retained by stiff bungee so that if a down rudder hits an obstruction the rudder (and stock) kicks up. I've thought of engineering something similar for the Stealth.....
Re: Kickup T foil rudder [Re: Jalani] #106519
05/09/07 09:15 AM
05/09/07 09:15 AM
Thanks for the picture John, now, tell us about the ride with the T foils. (I know this was covered a year or so ago, any updates?)
Re: Kickup T foil rudder [Re: Timbo] #106520
05/09/07 09:20 AM
05/09/07 09:20 AM
The ride has been discussed at length, as you say, having sailed with them, I couldn't now imagine sailing without them! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Only update is the new Stealth (2006/7) T-foils are a fantastic improvement on the older ones. Small, lighter, stronger and much better engineered. Less drag IMO, but just as effective as the older, larger foils. John_P has done a really good job!
Re: Kickup T foil rudder [Re: Jalani] #106521
05/09/07 09:35 AM
05/09/07 09:35 AM
If I wanted to buy a pair to put on a US Blade, what would that cost, for the new ones? Rudders, heads, tillers and mounts?
Re: Kickup T foil rudder [Re: Timbo] #106522
05/09/07 11:45 AM
05/09/07 11:45 AM
Your best bet Tim would be to cantact John Pierce - either PM him (john p) or through the website: http://www.stealthmarine.co.uk
Re: Kickup T foil rudder [Re: Timbo] #106523
05/09/07 05:55 PM
05/09/07 05:55 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I am in this camp. I used casset type a lot as a young mono sailor and always liked them more than flip up. Once you have the travelling tuned they are fast easy and can quickly be set at several heights without losing stearage. Extra moving parts creates possiblity for gear failure. But nice images.
BTW don't hit anything if they don't flip up! (we don't have big jellies here)
Re: Kickup T foil rudder [Re: warbird] #106524
05/10/07 04:55 AM
05/10/07 04:55 AM
L
Laruffa Offline
Laruffa  Offline
L
Hi everyone,
Would like to ask you a question, after sailing 49ers I always ask the question why not!! rudders in a box system?? they have some good points 1)when you need to sail into or out of a beach with any seaway they would work well if you could just left them up to miss the bottom and still steer! 2)packing the boat for transport all you need to do is take them out and pack them into a bag like the centre boards! 3) they would never kick up under load or sailing in waters with things like jellyfish! 4)if anything fouled them like seawead you could still steer while lifting them free! 5)in conditions like high winds with flat waters you could lift them to reduce drag?? [color:"red"] [/color] disadvantages? 1)hitting a object or the bottom in shallow waters?? BUT would it be cover by the centre boards???? whats your thoughts!!!! Love allways MarkXX <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Re: Kickup T foil rudder [Re: Laruffa] #106525
05/10/07 05:08 AM
05/10/07 05:08 AM
I like them, and think kick-up rudders are a leftover from the rotating centerboard days. Today the daggerboard (unless you have skegs) will hit the ground before the rudders, so you will ruin your day anyway.
Re: Kickup T foil rudder [Re: Laruffa] #106526
05/10/07 07:28 AM
05/10/07 07:28 AM
Hi everyone,
I too like the idea of a cassette style rudder. Big jellies are not usually a risk to the structure of the boat but things like stumps or perhaps a rock outcropping might be. However, you could still have some sort of breakaway "fuse" at the gudgeon in the event you really did hit something hard.
Re: Kickup T foil rudder [Re: grob] #106527
05/10/07 09:08 AM
05/10/07 09:08 AM
Gareth,
Intersting concept.
Obviously it would need some work to refine.
Got me thinking could even replace the line with thin flat rod down the centre of the rudder.
When building the rudder a slot could be made down the centre to accomodate the rod.
Now if you can control the rod from the top you would also have the ability to adjust the angle of the
T foil while sailing.
0 registered members (), 21,264 guests, and 1,231 spiders.
Most Online23,788
Yesterday at 09:11 PM
