| Re: Action pics
[Re: Gilo]
#107187 05/15/07 03:26 PM 05/15/07 03:26 PM |
Posts: 1,382 Essex, UK | That spin luff looks a little tight to me....
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Action pics
[Re: Gilo]
#107188 05/15/07 03:48 PM 05/15/07 03:48 PM |
Posts: 2,584 +31NL | Hi everyone,
These are our first action pics. I don't know if you can really see the shape of the spi but we tend to loose places going downwind. These pics are taking with 2/3 beaufort. Any comments?
Regards, Gill IMHO the spi looks fine, its just collapsing but thats pretty normal. I cant tell from the pictures but was the traveller centered and the mainsheet tight? Have you tried sailing with the crew on the leeward hull, with the skipper sitting far forward? (Near, or in front of the boards(Depending on your weight)). | | | Re: Action pics
[Re: Rolf_Nilsen]
#107190 05/15/07 05:19 PM 05/15/07 05:19 PM |
Posts: 3,528 Looking for a Job, I got credi... | Id say the shape of the Spi looks OK.
However, you don't have the windward hull flying quite high enough;
I'd always say 3 inches too high is better then 3 inches in the water !
As Rolf asks who are you loosing out to ?
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Action pics
[Re: Gilo]
#107191 05/15/07 06:05 PM 05/15/07 06:05 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | HEAT IT UP HEAT IT UP HEAT IT UP. That's all I have to say.
| | | Re: Action pics
[Re: Tony_F18]
#107193 05/15/07 07:02 PM 05/15/07 07:02 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | Hi everyone,
Regards, Gill IMHO the spi looks fine, its just collapsing but thats pretty normal. I cant tell from the pictures but was the traveller centered and the mainsheet tight? Have you tried sailing with the crew on the leeward hull, with the skipper sitting far forward? (Near, or in front of the boards(Depending on your weight)). Technique technique technique which = practice practice practice. The spi looks fine to me. The better guys are able to work the waves and take every opportunity to steer down wind a foot or two each time without loosing any speed. Tiger Mike | | | Re: Action pics
[Re: C2 Mike]
#107194 05/15/07 07:26 PM 05/15/07 07:26 PM |
Joined: Sep 2005 Posts: 16 Pensacola Beach, Fl. CaptainKirk
Posts: 16 Pensacola Beach, Fl. | Pole needs some prebend in it, it looks from the pic to be way to straight and if anything bent up abit. Then adjust the luff tension my adjusting the halyard length. Thats what we do on the F 18 and the N 20. Capt. Kirk
OLD DOG
| | | Re: Action pics
[Re: ncik]
#107197 05/16/07 07:23 AM 05/16/07 07:23 AM |
Posts: 3,528 Looking for a Job, I got credi... | 100% drop the halyard to de power and flatten; just try it on land - it's so obvious its great <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Gilo]
#107200 05/16/07 03:42 PM 05/16/07 03:42 PM |
Posts: 465 Oxford, UK | Is pre-bend so important? Now the boom is straight and not under very much tension. I always thought, that when you pull the mainsheet, there will be extra tension on the boom, which should be enough....
Pre-bend on the spinnaker pole is important to avoid breaking the pole, and to keep it fixed. With some pre-bend, the loads from the kite put the pole into compression and the tip of the pole is well braced. Paul
2,455
guests, and 294
