| Re: Oz Vic F16 Challenge
[Re: Tim_Mozzie]
#107280 06/18/07 02:32 PM 06/18/07 02:32 PM |
Posts: 3,528 Looking for a Job, I got credi... | Hi Darryn
I agree most H16s we come across seem slower than Mosquitoes but I have seen some in VIC that destroy the best Mosquitoes in winds above 15 knots. They need the breeze to do it so who knows what the handicap difference should be on average. VYC is supposed to be a comparison between "well sailed" boats of each class, so the slow ones are not supposed to figure in the setting of the handicap.
The other interesting thing is the way cats are always rated faster than sloops on SCHRS. In the VYC system I've never seen this happen. Maricats, Taipans and Mozzies (in SA) all have sloops rated faster than cats.
Anyone - are there any SCHRS numbers for Taipan 4.9s? Get me the rating points and I'll calculate an approximate rating
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Oz Vic F16 Challenge
[Re: scooby_simon]
#107281 06/19/07 01:46 AM 06/19/07 01:46 AM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | Hi Simon
I've extracted these numbers from the Taipan 4.9 rules and the AHPC site. They're probably about as accurate as the Mozzie figures I gave you! Of course the Taipans have now changed their mainsail and I'm pretty sure these areas came from the old rules but lets not confuse things.
1, No of crew cat 1, sloop 2 2, No of crew on Trap cat 1, sloop 2 3, Min Weight of the boat incl sails etc in KG - cat 97kg, sloop 102kg 4, Overall length - 4.95m 5, Max Beam - 2.34m 6, Max mainsail and mast area combined - 1.28sqm + 13.7sqm 7, Vertical luff length of sail (luff len will do) - 8.05m 8, Jib Area - 4.2sqm 9, Vertical luff of the jib (Luff will do) - 5.04m 10, max allowed Spi area - 17.5sqm 11, Max authorised board area - 0.215sqm 12, Max allowed depth below the hull - 0.65m
Tim Shepperd Mosquito 1775 Karma Cat
[Re: Tim_Mozzie]
#107282 06/19/07 02:10 AM 06/19/07 02:10 AM |
Posts: 3,528 Looking for a Job, I got credi... | Hi Simon
1, No of crew cat 1, sloop 2 2, No of crew on Trap cat 1, sloop 2 3, Min Weight of the boat incl sails etc in KG - cat 97kg, sloop 102kg 4, Overall length - 4.95m 5, Max Beam - 2.34m 6, Max mainsail and mast area combined - 1.28sqm + 13.7sqm 7, Vertical luff length of sail (luff len will do) - 8.05m 8, Jib Area - 4.2sqm 9, Vertical luff of the jib (Luff will do) - 5.04m 10, max allowed Spi area - 17.5sqm 11, Max authorised board area - 0.215sqm 12, Max allowed depth below the hull - 0.65m OK< I'll try and do this tonight (just off out to The City). Or you can do it yourself by downloading the clac routing from the ratings page on the SCHRS website www.schrs.com
[Re: Tim_Mozzie]
#107283 06/19/07 03:06 AM 06/19/07 03:06 AM |
Posts: 9,582 North-West Europe | Corrections Taipan specs : 6, Max mainsail and mast area combined - 1.28sqm + 13.7sqm
Is wrong the real area is 1.40 sq. for mast and 14.58 combined mainsail+mast. At least that is what Texel has measured in the past. 11, Max authorised board area - 0.215sqm 12, Max allowed depth below the hull - 0.65m
Since many years the Taipan are using smaller boards then allowed in the class rules. The AHPC boards area protruding 0.55 mtr below the keel line and have a width of 0.290 mtr. Their area per board is therefor 0.1595 sq. mtr. As you can see (Buccaneer) the current Taipan boards are significantly smaller then the very original ones late 80's. Of course the new F16 boards (not used by taipans yet) are another extention of this trend. Wouter
[Re: Wouter]
#107284 06/19/07 04:37 AM 06/19/07 04:37 AM |
Posts: 1,479 Thailand | No, YOU don't understand Bob, because you have absolutely no frigging idea of how much time, testing and on the water validation went into those new "neophyte F16 builders" boards. Which, by the way, really aren't very new.
They are the result of many years sailing (10 - 15) in an internationally very competitive singlehanded class. Three guesses which class that may be.
But despite the fact you know nothing of their origin and the fact that you also make totally unfounded assumptions, you still you feel free to spout all kinds of obvious nonsense about them on this public forum.
You have a undeniable responsibility to check your facts and avoid peddling obvious falsehoods. This responsibility is even recognized in common law by the duty to avoid slander.
I can tell you again Bob, you are totally in the dark on this. And I really wouldn't say that if you even had the slightest foundation on which you could base your comments.
But added to this is the fact that your statements can even be call moronic. That is because the "new" boards are smaller then the older Taipan boards, just as the mozzie boards are. In effect these Alter Cup boards are another confirmation of what you find so interesting in the mozzie boards. But wait a minute, a few weeks ago you were claiming the new boards are all wrong ! Obviously you haven't made up your own mind on what you REALLY think is best, because you can't believe both lines of thought at the same time. Either the Taipan boards are better, but then you have to disagree with the mozzie experience. Or you find the mozzie experience valid and then have to consider the new F16 boards as superiour to the old Taipan boards.
This doesn't suprise me much however as it is was already clear that you haven't looked at the specs in detail, you just blubber off whatever comes to your mind at the time as long as it is negative to the new board designs.
But THAT, my friend, is not how we do business or hold discussions in the F16 class. Never has been and never will be.
So there is no room for disagreement without insults? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> Is that your rule? <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> For you my friend the doctor recommends more time on the water and less time getting red faced at computer. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> Happy sailing, <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Buccaneer]
#107287 06/19/07 06:50 AM 06/19/07 06:50 AM |
Bob, I like you (we go way back in the way of communication, 2000 I think) and I would gladly go for a beer with you and have a laugh. It is just that you are so far off track with your board comments, and repeately so, that it has to stop. Come back and give us your opinion when you have spend the effort to form a COHERENT opinion. Right now you have only written down certifiable nonsense that often contradicts itself.
No ill feelings outside of this particular disagreement from my side.
[Re: taipanfc]
#107288 06/19/07 06:56 AM 06/19/07 06:56 AM |
Long daggerboards (high aspect) were already persent on the Nacra Inter-18 = F18 (nacra inter 20) as early as 1995. The trend already started here with respect to high aspect daggerboards. The A's were a little late with regard to this development but have since then moved to the forefront of it.
Interestingly enough the Blade with the old boards would point a little higher to the Taipan in the 1-on-1 testing. But I do think the new design is better, although not by a huge amount.
I feel the Taipan gets a significant portion of the pointing from the hulls itself and so it could well favour the board design it has now.
It is certainly true that you don't want to lift the board to early on the Blade. But then again I only lift them on my taipan when it is howling.
[Re: Rolf_Nilsen]
#107290 06/19/07 05:15 PM 06/19/07 05:15 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | I dont know how old you are or how much computer experience you have, but.. In the early days (80s) the professional workstation displays could in some cases have strong enough emission as to make you red faced if you sat in front of it long enough <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> erm that wasn't emissions. It had more to do with frustration getting the thing to work properly. Still happens a fair bit. Tiger Mike | | | Re: Oz Vic F16 Challenge
[Re: scooby_simon]
#107291 06/19/07 08:08 PM 06/19/07 08:08 PM |
Posts: 943 East Gippsland, Australia | F16 cat 0.994 F16 sloop 1.020 Taipan cat 0.983 Taipan sloop 1.006 F18 1.005
So the Taipan is rated faster than the F16, and the cat is faster than an F18! And that's before we add the new main - maybe my numbers are not right. Doesn't make much sense otherwise.
[Re: Wouter]
#107292 06/20/07 04:08 AM 06/20/07 04:08 AM |
Joined: Feb 2006 Posts: 207 couldn't resist it Codblow
Posts: 207 couldn't resist it | No, YOU don't understand Bob, because you have absolutely no frigging idea of how much time, testing and on the water validation went into those new "neophyte F16 builders" boards. Which, by the way, really aren't very new.
You bring a tear to my glass eye Wouter ,for someone so pedantic you should consider what you type before you send it . Frigging : frig • verb (frigged, frigging) vulgar slang 1 have sexual intercourse with. 2 masturbate. — ORIGIN originally in sense move restlessly, later rub, chafe: of unknown origin. Perform another search of the Compact Oxford English Dictionary Is this your intention ? <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> In this part of the world "feking" is becoming a more accepted word for the one you so unskillfully avoid Keep it up , someone has too <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> | | | Re: Oz Vic F16 Challenge
[Re: Tim_Mozzie]
#107293 06/20/07 12:59 PM 06/20/07 12:59 PM |
Posts: 3,528 Looking for a Job, I got credi... | F16 cat 0.994 F16 sloop 1.020 Taipan cat 0.983 Taipan sloop 1.006 F18 1.005
So the Taipan is rated faster than the F16, and the cat is faster than an F18! And that's before we add the new main - maybe my numbers are not right. Doesn't make much sense otherwise. I used wouters mainsail + mast measurement
Lighter boat, similar size sails. IMO should be faster.
[Re: scooby_simon]
#107294 06/23/07 05:54 PM 06/23/07 05:54 PM |
Posts: 943 East Gippsland, Australia | Lighter boat, similar size sails. IMO should be faster. Or, put another way - shorter, narrower, smaller sails, 20 yo design and only 7kg lighter - how could it possibly be as fast? ![[Linked Image]](http://www.catsailor.com/forums/images/graemlins/smile.gif) As for a cat rigged Taipan being rated faster than an F18 - I know which one I'd choose in a boat for boat race. It makes me think the SCHRS is weighted very favourably for the bigger cats. Or is it just heavier cats? In the Mozzies we have a "heavyweight" division for older boats, where the minimum weight is an extra 10kg. How do the Mosquito numbers come out with 10kg of extra weight added? I'd be interested to see the difference.
[Re: Tim_Mozzie]
#107295 06/23/07 06:18 PM 06/23/07 06:18 PM |
Posts: 3,528 Looking for a Job, I got credi... | Lighter boat, similar size sails. IMO should be faster. Or, put another way - shorter, narrower, smaller sails, 20 yo design and only 7kg lighter - how could it possibly be as fast? ![[Linked Image]](http://www.catsailor.com/forums/images/graemlins/smile.gif) As for a cat rigged Taipan being rated faster than an F18 - I know which one I'd choose in a boat for boat race. It makes me think the SCHRS is weighted very favourably for the bigger cats. Or is it just heavier cats? In the Mozzies we have a "heavyweight" division for older boats, where the minimum weight is an extra 10kg. How do the Mosquito numbers come out with 10kg of extra weight added? I'd be interested to see the difference. Tim, we don't have much data coming from Aus, if you have results in a sailwave format, please send them to me and I'll store them up for later test fleet races. I also need as much info about the course as possible, tide state and direction, if it turned during the race and at what time (if available), wind speed, sea state and some idea of the level of skill across the fleet. This may sound like a lot of info, but it's usefull as we can then try and iron out any strange results (consider a w/l race, one lap light wind with strong tide). We would expect an A class to do well in this race as they do have very good performance upwind and in this race the boats would spend a longer time sailing upwind on the race. As for numbers, download the utility from here and have a play with it yourself !
[Re: scooby_simon]
#107296 06/23/07 06:31 PM 06/23/07 06:31 PM |
Posts: 943 East Gippsland, Australia | download the utility from here and have a play with it yourself ! I just did! 10kg didn't make as much difference as I expected. I'll just have to sail faster I guess, if weighing the boat down won't do it. ![[Linked Image]](http://www.catsailor.com/forums/images/graemlins/smile.gif)
[Re: scooby_simon]
#107297 06/24/07 04:48 AM 06/24/07 04:48 AM |
Posts: 9,582 North-West Europe | I think Simon has made a few typo's in the calculations and that is the cause of the weird rating numbers. If I punch in the specs of the Taipan 4.9 (NO SPI !) into the schrs calculator (off the www.schrs.com website) then I find : Taipan 4.9 sloop no spi = 1.055 Taipan 4.9 cat no spi = 1.058 With spinnakers we get Taipan 4.9 sloop + spi = 1.025 Taipan 4.9 cat + spi = 1.008 As you see these numbers are very close to the ones for the F16's F16 2-up = 1.020 F16 1-up = 0.994 (Texel has F16 2-up = 102, F16 1-up = 101) Specs used for the Taipan (real measurements) : mainsail + mast : 14.58 mainsail luff : 8.03 mtr jib 4.08 sq. mtr. jib luff : 4.85 mtr. weight ready to sail : 102 kg length : 4.95 mtr. width : 2.34 mtr. board area : 0.160 board depth : 0.550 Wouter
[Re: Wouter]
#107298 06/24/07 06:27 AM 06/24/07 06:27 AM |
Posts: 3,528 Looking for a Job, I got credi... | I think Simon has made a few typo's in the calculations and that is the cause of the weird rating numbers. If I punch in the specs of the Taipan 4.9 (NO SPI !) into the schrs calculator (off the www.schrs.com website) then I find : Taipan 4.9 sloop no spi = 1.055 Taipan 4.9 cat no spi = 1.058 With spinnakers we get Taipan 4.9 sloop + spi = 1.025 Taipan 4.9 cat + spi = 1.008 As you see these numbers are very close to the ones for the F16's F16 2-up = 1.020 F16 1-up = 0.994 (Texel has F16 2-up = 102, F16 1-up = 101) Specs used for the Taipan (real measurements) : mainsail + mast : 14.58 mainsail luff : 8.03 mtr jib 4.08 sq. mtr. jib luff : 4.85 mtr. weight ready to sail : 102 kg length : 4.95 mtr. width : 2.34 mtr. board area : 0.160 board depth : 0.550 Wouter Wouter, what do you get with aspect ratio 4.5 on the plates. (IIRC i ised area .223 and depth 1m (just to get 4.5 aspect ratio)) If you re-read my post I said I used max plate ratio as people were arguing about actual plate sizes.
[Re: scooby_simon]
#107299 06/24/07 08:18 AM 06/24/07 08:18 AM |
Posts: 9,582 North-West Europe | (IIRC i ised area .223 and depth 1m (just to get 4.5 aspect ratio)) If you re-read my post I said I used max plate ratio as people were arguing about actual plate sizes
Yes, but since then people have intepreted your rating numbers as being for the standard Taipan 4.9; of which they have a feel for actually performance. Either way, a larger misunderstanding is perpetuated. Also Is a rediculous set of specs for Taipan or F16 boards. It will make the boat bad behaved and mostly likely significantly slower in all conditions as the board will not be operating at the optimal angle of attack. (best lift to drag ratio). from very earlier onwards (I think a year after the design waslaunched) the Taipan boards were made narrower and maybe also shorter. Since then the board area (per board) = 0.290 * 0.55 = 0.1595 and the wetted depth is 0.550 mtr. This has not changed since then. The max specs given in the Taipan class rules are useless as no-one is even getting close to those. If more then 10 boats out of 325 build still sail with the old original daggerboards then I would be surprised. Also 1 mtr long boards (as in wetted length) are unrealistic For Taipan's and F16's. For reasons of optimal lift to drag ratios you'll need a minimal angle of attack and this requirement limits the boards area for these boats to 0.185 sq. mtr. or less (preferably slightly less). In order for such a board to be 1 mtr long it needs to be 185 mm wide or less. This is too little to make the board both strong and stiff enough. So this board can not be build in an economic viable way. Of course, a custom board can but you'll be pouring that full of carbon cloth to get at the required specs. Commercial builders however won't take these risks for their production boats, especially not when such boards are not really attractive because of the ease of stalling them or "tripping" over them. Both well proven disadvantages of very long/high aspect boards. So up till now all builders are converging on F16 boards that are around 0.75 mtr long and on average just under 0.200 mtr wide. Resulting in rougly 0.150 sq.mtr. area and averaged aspect ratio's of 4. I think your own boards, Simon, are the only exception to this rule at this time. Wouter
2,564
guests, and 634
