Tornado Jib sheeting points #10734
09/19/02 07:03 AM
09/19/02 07:03 AM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
Can someone post a close up or recommend a website that depicts the specifics of the Tornado transverse sheeting arrangement?
Thanx,
Eric
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Tornado Jib sheeting points [Re: arbo06] #10735
09/19/02 11:39 AM
09/19/02 11:39 AM
Houston
carlbohannon Offline
Houston
What kind of boat and what year was it rigged. Are you using a wire system or loops in your tramp? I recommend reinforcing your tramp and going to loops. Its fairly cheap and your crew will love you for it.
I can send pictures of the loop system. I also have a Marstrom wire system I can try and describe
Re: Tornado Jib sheeting points [Re: carlbohannon] #10736
09/19/02 12:23 PM
09/19/02 12:23 PM
arbo06 Offline OP
arbo06  Offline OP
I am interested in the tramp loop system, seems to be far less deck clutter that way....
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Tornado Jib sheeting points [Re: carlbohannon] #10737
09/19/02 02:55 PM
09/19/02 02:55 PM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
Hey Carl,
I'm thinking about doing the same thing. If you could send me a picture as well, that would be great. I sliced my foot open the other day on the wire block and have decided that's it on my boat. I'm thinking of just taking it to a sailmaker and having nylon strapping sewn to the tramp for reinforcement and then just lacing the tramp through the jib wire holes in the hulls.
By the way, what kind of mast rotation setup are you using??
Todd Berget
todd.berget@verizon.net
Todd Nacra 20 www.wrcra.org
Re: Tornado Jib sheeting points [Re: Todd Berget] #10738
09/20/02 01:43 AM
09/20/02 01:43 AM
NZ
simonm Offline
simonm  Offline
NZ
We had the same setup on our two Marstrom boats - now running a self tacker - I have the measurements somewhere (based on Mitch Booth and Bundock/Forbes boats) will dig them out.
You need to be very careful with the eyelets and reinforcing as there is a heap of tension on the eyelets. If you are running a boltrope track on the side of tramp (e.g. Reg White boat), then you have to spread the load so it doesn't rip the boltrope out.
sm
Simon Manning A Class NZL230.........boats are for life...
Re: Tornado Jib sheeting points [Re: simonm] #10739
09/20/02 08:32 AM
09/20/02 08:32 AM
Houston
Houston
The first tramp sheeting system I used was on a NACRA, which has a boltrope tramp. The trick is to attach the ends of the lines to the original jib attach points, the jib traveler cars.
You can also replace the boltrope with slugs which do not pull out or put slugs in the channel and use a Marstrom style tramp.
The slugs in the channel may be the strongest, fastest to install, most repairable tramp made.
Re: Tornado Jib sheeting points [Re: carlbohannon] #10740
09/20/02 04:36 PM
09/20/02 04:36 PM
arbo06 Offline OP
arbo06  Offline OP
Can anyone attach a picture of the tramp arrangement?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Tornado Jib sheeting points [Re: arbo06] #10741
09/20/02 09:46 PM
09/20/02 09:46 PM
Houston
Houston
Attached is a picture of the port jib sheet attachment.
10790-jib sheet.jpg (31 downloads)
Re: Tornado Jib sheeting points [Re: Todd Berget] #10742
09/20/02 09:48 PM
09/20/02 09:48 PM
Houston
Houston
Mast rotator
Re: Tornado Jib sheeting points [Re: carlbohannon] #10743
09/20/02 10:41 PM
09/20/02 10:41 PM
arbo06 Offline OP
arbo06  Offline OP
Thanx Carl, I really appreciate the effort.....I can see my boat in the background...
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Tornado Jib sheeting points [Re: carlbohannon] #10744
09/21/02 08:08 AM
09/21/02 08:08 AM
Long Island,NY
malc Offline
malc  Offline
Long Island,NY
Shouldn't the three points be at an angle with the fwd loop most inboard, and the aft loop most toward the hull?
Re: Tornado Jib sheeting points [Re: arbo06] #10745
09/22/02 10:29 PM
09/22/02 10:29 PM
Houston
Houston
I hope that not your boat. It has not moved in 3 years. It is not tied down and a hurricane may be headed this way. I was thinking about filling it with water and using it as a anchor.
Re: Tornado Jib sheeting points [Re: carlbohannon] #10746
09/22/02 10:57 PM
09/22/02 10:57 PM
Long Island,NY
malc Offline
malc  Offline
Long Island,NY
How far forward of the shroud are your loops?
Re: Tornado Jib sheeting points [Re: carlbohannon] #10747
09/23/02 11:07 AM
09/23/02 11:07 AM
Crofton, MD
Todd Berget Offline
Todd Berget  Offline
Crofton, MD
Thanks Carl,
Great Help. Question with the rotator setup, is that just a limiter or do you have something rigged to induce rotation??
Thanks.
Re: Tornado Jib sheeting points [Re: carlbohannon] #10748
09/23/02 09:57 PM
09/23/02 09:57 PM
arbo06 Offline OP
arbo06  Offline OP
I am thinking about adapting a similar system onto my h-20, when I get a chance I'll post a photo to get feedback from the forum citizens. I thought about tying stainless rings onto a piece of spectra and stringing it between the jib cars.(?)
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Tornado Jib sheeting points [Re: Todd Berget] #10749
09/24/02 08:29 AM
09/24/02 08:29 AM
Houston
Houston
The rotation inducer is part of the mast base. There is an arm on each side of the base connected to the opposite side of the from cross beam via a 3:1.
The neatest part of the system is the outhaul is connected to the rotation limiter. Blow the outhaul and you blow the rotation limiter. When you pull the outhaul back out, you reset the the rotation to it's previous position. When you have to pinch, ease the outhaul/rotator and it really powers up.
Re: Tornado Jib sheeting points [Re: arbo06] #10750
09/28/02 06:29 PM
09/28/02 06:29 PM
arbo06 Offline OP
arbo06  Offline OP
pic of idea
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 15,848 guests, and 372 spiders.
Yesterday at 04:54 AM
