| Re: F16 AGM items for Zandvoort 2007
[Re: ncik]
#107401 05/23/07 02:35 AM 05/23/07 02:35 AM |
Posts: 3,528 Looking for a Job, I got credi... | But cats already are being twisted significantly under the rig loads. Off the top of my head, I think the T-foil would only reduce the twisting loads or maybe reverse them a little in special cases (high angles of attack on the foil).
What size foils are we talking about here. If you're talking about say 400mm * 150mm, you'd probably only get about 40kg of up/down force at an efficient angle of attack that doesn't create too much drag. If you want anymore force you're talking about foils on each rudder the equivalent of the total area under a moth (700*150 and 600*130 -ish)! They're gonna be very big, feasible but big. And I believe the foils are included in the beam measurement of the F16, so they will likely have to be L-foils, not T's, which will be even trickier because of the structural issues.
Just quickly read the rules again, I'm not sure if the centreboards or rudders are now included in the beam measurement. It says "overall beam" which I take to mean beam of the boat when taking everything into account in its normal position...can anyone clarify?
I'm need to think about these rudder foils some more... Rudder ends or T foils are not included in the beam measurement.I've not done detailed calcs, but if you are saying we can get 40kg per foil, then that is an extra person for virtually no drag. Makes it sound like a no brainer that every one must have them, or we ban them ?
F16 - GBR 553 - SOLD I also talk sport here | | | Re: F16 AGM items for Zandvoort 2007
[Re: scooby_simon]
#107402 05/23/07 08:16 AM 05/23/07 08:16 AM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | Thanks for the clarification. This is good because T-foils are much easier to build strong enough.
I was about to blow up about my guesses being used as facts but decided to do the calcs instead...lucky...my calcs indicate that a force of about 90kg with a 0.05m^2 foil may be achieved with about 2kg of drag at 20 knots. It's all rough numbers anyway because boats will pitch and heave which will change angles of attack constantly.
I personally think it is going to be exciting being in a class that has this sort of development. I will certainly participate...if it doesn't get banned...
You still haven't explained why you are promoting a banning of rudder foils because of the cost, but then you are promoting a rule which will make expensive carbon masts more favourable, in terms of performance and safety apparently, against the cheaper alternative...?
As I said previously, the rules are good as they are, for the moment. Those that want to develop can do so with very little risk of blowing away those ppl that want to buy a production boat off the shelf. I think it is a good balance at the moment.
If someone doesn't want to be part of a restricted development class, there are other classes more suited to their tastes. | | | Re: F16 AGM items for Zandvoort 2007
[Re: Rolf_Nilsen]
#107404 05/23/07 09:24 AM 05/23/07 09:24 AM |
Posts: 3,528 Looking for a Job, I got credi... | You still haven't explained why you are promoting a banning of rudder foils because of the cost, but then you are promoting a rule which will make expensive carbon masts more favourable, in terms of performance and safety apparently, against the cheaper alternative...?
I'm proposing to propose (if that makes any sense) to allow carbon masts to be built down to a level at which they can be built. John P has already confimed that his masts are built to design and not to a weight and so I believe that his masts may need correctors to measure. He has stared that he believes his masts are more than strong enough to withsatnd the loads. Has anyone asked John to quote for a Carbon masts only and compared this with an appropiate Alu section? I'm simply sayinmg that the tip weight rule limits who can sail the boat (yes they can carry righting bags or pole, but would someone want to ?) I propose to ban variable trim T foils because I believe they will make all current boats obsolete.
[Re: davidtugwell]
#107405 05/23/07 10:31 AM 05/23/07 10:31 AM |
Posts: 130 CA | Foiling is not how it seems . It is the leeward hull that rises on a Ketterman Trifoiler, not the windward. Nope. On the trifoiler, both windward and leeward foils seek a fixed depth, thanks to the forward "sensors." In lighter winds, both foils generate positive lift. In high winds that would otherwise capsize the Trifoiler, the windward foil generates negative lift to seek the target depth. The drawing you have added would lift the stern and bury the nose on the windward hull and the opposite on the leeward. The vertical coupling is meant to be cable, which cannot push, and therefore cannot cause the foil to generate positive lift and bury bows. The feedback system therefore generates only negative lift and cannot lift the sterns. Adjusted properly, it would only increase negative lift (and drag) once the corresponding hull lifts clear of the water, since there is no point in the foil increasing downward lift when the hull is still in the water! The traditional T-foil property of generating negative lift as bows dive should be maintained in this system not by the feedback system, but by limitting the rotational travel of the horizontal foils. Such as system would always hold the sterns down at least as well as traditional T foils (and better when the windward hull rises). A valid concern about the system is that that the additional righting moment would mean one could sail much hotter and faster downwind in high wind, but in doing so you risk stalling the windward foil and pitchpoling suddenly at speed. (But this is somewhat true of T-foils in general, I theorize: once the windward one clears the water it suddenly stops down-lifting, and the hull pops and the bows bury.) | | | Re: F16 AGM items for Zandvoort 2007
[Re: Glenn_Brown]
#107407 05/23/07 04:06 PM 05/23/07 04:06 PM |
Posts: 61 |
Have a read of the tri foiler manual. I put the link on the last posting. In it Ketterman explains why the leeward foil rises. You will find it interesting. Or maybe have a go on a tri foiler! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Stealth F16 The Black Pig
[Re: Darryl_Barrett]
#107410 05/23/07 10:33 PM 05/23/07 10:33 PM |
Posts: 951 Brisbane, Queensland, Australi... | Disclaimer: The numbers I generated for T-foil lift are very quick and theoretical based on a set of lift and drag coefficients for a slightly incorrect reynolds number (about twice as much as it should be), so they are technically wrong. I believe the drag only takes into account induced drag; no friction, aspect ratio, etc. drag. It is true, practical foil design is fairly different to theoretical design.
The foil I had in mind was 500mm * 100mm. My mate has a higher aspect ratio foil (about 800 * 75mm) on his moth and I'm not a fan of them for boats, too much fluctuation in angle of attack (due to varying speed, yawing, pitching), which high aspect boards don't like in general. They tend to stall at lower angles of attack than lower aspect ratio foils. | | | Re: F16 AGM items for Zandvoort 2007
[Re: davidtugwell]
#107412 05/24/07 11:15 AM 05/24/07 11:15 AM |
Posts: 130 CA | Have a read of the tri foiler manual. I put the link on the last posting. In it Ketterman explains why the leeward foil rises. My assertion that the windward foil can generate negative lift in high wind is based on a vector diagram drawn by Mr. Ketterman himself, which I saw years ago. Nothing in the tri foiler manual contradicts this. | | |
703
guests, and 510
