| T500 a different point of view #107448 05/16/07 08:53 AM 05/16/07 08:53 AM |
Posts: 3,348 | Hope I'm not over stepping my bounds, but you gotta go here: http://www.teamseacats.com/ and read about ". . . briney death" under the heading potpourri of the sea . | | | Re: T500 a different point of view
[Re: MauganN20]
#107452 05/16/07 09:44 AM 05/16/07 09:44 AM |
Posts: 5,590 Naples, FL | It should also be good to know that the reason you're not winning everything ISN'T because of the boat! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
[Re: MauganN20]
#107454 05/16/07 09:57 AM 05/16/07 09:57 AM |
Posts: 5,590 Naples, FL | Well, I've been called a "waste of a pair of pants", too. Guess I could crew for you then. Team "Waste of Carbon"
[Re: ncik]
#107457 05/16/07 06:15 PM 05/16/07 06:15 PM |
Posts: 2,921 Michigan | they are put through lines wrapped that are wrapped around the chicken line. They put the ball into the line and that acts to keep them stable out on the wire and not washed off the boat. The chicken line runs from the transom to the bow tang then under the tramp attached to a bungee. The lines are attached to the chicken line by a prusik knot that tightens under pressure but can be slid around when it is loose. I did it this way for a race last year on my 6.0 and it saved me and Robi's butt. I am not sure what the intellectual lineage of that set up is but I got the info from Jake.
[Re: ncik]
#107458 05/16/07 07:05 PM 05/16/07 07:05 PM |
Posts: 3,293 Long Beach, California | Jake would tell you that;
"Those are anti-bingbongs adapted to an anti-whoopsie application."
He is an engineer, afterall. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: John Williams]
#107459 05/16/07 08:51 PM 05/16/07 08:51 PM |
Joined: Feb 2005 Posts: 4,118 Northfield Mn Karl_Brogger
Posts: 4,118 Northfield Mn | Maybe this should go in the "Why?" thread, but I just watched a bunch of the videos from the start. Wow. I ain't man enough. I'm not going to say they're crazy or anything along that nature. If I wanted to go sailing that day, and I pulled up to a beach that looked like that I would go "nope". Get back in the truck and go home. That is some seriously fubar-ed surf. Beyond my skills.
[Re: ncik]
#107463 05/20/07 03:42 AM 05/20/07 03:42 AM |
Posts: 12,310 South Carolina | So they're just attachments for connecting to the chicken line, that aren't hooks. ok, cool. Hooks are bad on boats where bodies are likely to be flung around. Climbing-style Carabiners (sp?) are easier to use but they will slap the hull potentially leaving damage. The system that we use takes a little getting used to, but once you are used to it, getting clicked in is pretty easy. The bozo-ball anti-whoopsie arrangement is a David Lennard creation.
Jake Kohl | | |
687
guests, and 126
