| proper mast setup/block placement #107660 05/17/07 08:40 PM 05/17/07 08:40 PM |
Posts: 126 | Hey guys, I took my new 5.0 out for the first time this past weekend, and couldn't exactly find out how to have a pulley system for both the down haul and the jib. I've attached some pictures, if someone can please explain to me in detail how to do it, that'd be great. Also, if you could tell me some ways to improve things, as well as the best way to deal with the remains of the main halyard and also any things I could add, that'd be great. I'm open to any and ALL suggestions! Pictures are up at http://www.lapiter.com/nacraissues/I just took them and it was getting dark. | | | Re: proper mast setup/block placement
[Re: johnny872005]
#107661 05/17/07 10:06 PM 05/17/07 10:06 PM | Anonymous
| Anonymous
Unregistered | Feras:
It looks like it is somewhat like my 4.3. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> We will try to figure it out Sunday. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> You need to get rid on the dogbones for the trap system. They will knock your teeth out. Get some of the one that look like a circle with line thru the middle. That is what we all use.
Doug | | | Re: proper mast setup/block placement
[Re: johnny872005]
#107662 05/17/07 10:27 PM 05/17/07 10:27 PM |
Posts: 6,049 Sebring, Florida. | You are missing a few blocks for your jib halyard and down haul, and a few stoppers for the traps, but with a few minutes and a couple of blocks you can straighten that out.
Jib first, there should be a block with beckett just like on that one trap wire, tied to the end of the jib halyard, and you run the line off the beckett through the block on the mast, then back up through the block on the halyard, then to that cleat you have the black line set in.
Downhaul, you should have a small double block which you can attach to your main at the tack, with a beckett, and you run the line from the beckett down to that little block on the mast, up through one side of the double on the tack, down through the block on the other side of the mast, up through the other side of the double, then down to that cleat on the mast.
Traps, first off, get the bungie cord off the metal ring, tie a small loop in the end of each red trap line, and clip the bungie cord to that loop, adjust lenght of tail to keep them snug when nobody is using them. You need another stopper on that one that doesn't have one.
OR...Take your boat to a regatta, buy a case of beer on the way, find someone with lots of spare parts, trade him the beer for the parts and have him rig it for you, then sail it! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Blade F16 #777
[Re: ]
#107664 05/18/07 02:51 AM 05/18/07 02:51 AM |
Posts: 9,582 North-West Europe | Not really, plenty of people use the dogbones, some of use even passionate dislike the ones "that look like a circle with line thru the middle" It all comes down in how how you rig c.q. setup the system. Wouter
[Re: Wouter]
#107665 05/18/07 06:41 AM 05/18/07 06:41 AM |
Posts: 1,382 Essex, UK | I absolutely HATE the ones that 'look like a circle with a line through'.
They're standard on the Hobie and they are one of my pet moans. I use the Ronstan dogbones 'cos they're brilliant and I've had them (or very similar) on every boat I've had in the last 35 odd years.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: proper mast setup/block placement
[Re: Jalani]
#107666 05/18/07 09:50 AM 05/18/07 09:50 AM | Anonymous
| Anonymous
Unregistered | I love the J & H handles. Easy to hook up too. Once you have chipped your tooth on a metal dogbones popping back at you, you will see why.
[Re: ]
#107668 05/18/07 03:01 PM 05/18/07 03:01 PM |
Posts: 1,203 uk | J&H handles have a life span. they will eventually corrode and break. If something has the potential to break - don't use it. Dogbones every time for me.
2,869
guests, and 168
