I just received my new Harken 10:1 system. Last night I sat down and tried to run the sheet through it. After several attempts, I got it to look like it might be right. Does anyone have a diagram of the correct way to run the sheets through the blocks? I checked the Harken website, and it only shows 8:1. I even bumped into a friend of mine who works for Harken last night to ask him the correct way. He had no clue.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one
Even with my 8:1 mainsheet, when fully tensioned, the boom displayed an annoying upward flex in it. I can only imagine what the 10:1 blocks will do.
Is there any particular reason that the sheet point is behind the clew of the main? Does it help keep the roach/square top tight?
Having it that far back certainly seems to stress the boom moreso than I would have thought. But I guess that's part of the design, too...?
You have to have the mainsheet at a slight leaning angle so it applies some compression on the boom to push the mast and keep it rotated. Several I20's came out where the mainsheets attached with a strop to the mains and you couldn't keep the masts rotated.
With 8:1 I have made the observation that my boom, when double trapped and sheeted in hard, as in real hard, the boom looks like is going fail.
Recently, I tried to incorporate a double ratchamatic into my mainsheet system by mounting another boom bail say 2" forward of the other bail. When I tried it on a light air night the mast wouldn't rotate enough. Anybody wantt a double ratchamatic?
You have to have the mainsheet at a slight leaning angle so it applies some compression on the boom to push the mast and keep it rotated. [/quote]
And by that I presume the designers anticipated that sort of load? I guess by switching to a 10:1 mainsheet, you're not actually increasing the load, just the amount of force needed by the crew to apply that load, correct?
I mean, "block to block" is X Newtons of force on the sail/boom, regardless of whether you use an 8:1 or 10:1 setup, right?
So, how do the boomless sails manage to keep the mast rotated?
Re: 10:1
#108109 05/23/0710:49 AM05/23/0710:49 AM
They are manually rotated by attaching a rotation arm to the front of the mast, the rotation is held in place with line and a cleat. It has to be reset everytime you tack. Simple system but a pain in the butt. But, then again... it is the crews problem.
"Do or do not. There is no try." - Yoda "Excuses are the tools of the weak and incompetent" - Two sista's I overheard in the hall "You don't have to be a brain surgeon to be a complete idiot, but it helps"
The 10:1 harken block that came with my Infusion had a double block attached to the becket above the cam cleat right out of the bag, and that is how a ran the line with the top block 90 degrees to the bottom. Seemed like it would work good sitting on the couch. I soon found that the double attached to the cam cleat becket didn't pull on the top block evenly causing it to twist and the lines to override.
Fortunately, the boat Mischa raced at NAF18 last year no belongs to someone in the same club. So with that as a model, the double block is attached to the top becket of the lower blocks, not the cam cleat becket. The line is dead ended to a becket on the double. Surprisingly there is plenty of room in there. That my story.
Here's what we ended up with, and it works well, no binding. The trick in figuring it out was to make sure that the loads were centered in both blocks, otherwise lines would jump the sheaves. When I wne to do this the pics that were on the forum before couldn't be accessed (haven't looked again since), so this was a trial and error routine, but it didn't take long. The pics probably don't show it too well, though. And, yes, I need to clean out my garage... <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
i'm running 42' total length with a 10' taper. This is on a 9:1 setup, traveler line is separate. I didn't want a longer taper because I wanted the cover to be on the line where it runs through the ratchet (more holding power). These lengths seem about right, but I haven't been out when it is nuking so I may be wishing to be have another 5' or so to ease. I think Sailmax sells 'em premade at the length you have but I think this includes traveler line. also do a search, i think this has been discussed a number of times before.
