Re: 10:1 [Re: TampaN20] #108120
05/25/07 07:02 AM
05/25/07 07:02 AM
I'll measure ours this weekend. We ended up cutting several feet off the tapered end to get it so that the cover was still in the cleat at maximum mast rake.
Re: 10:1 [Re: Jake] #108121
05/25/07 11:03 AM
05/25/07 11:03 AM
And what is "maximum mast rake" for you?
Re: 10:1 [Re: waterbug_wpb] #108122
05/25/07 10:45 PM
05/25/07 10:45 PM
trap line extended to the forestay bridle tang, then to the bottom rudder gudgeon....think that works out to just shy of 1/2 way down a horizontal rudder.
Re: 10:1 [Re: David Ingram] #108123
05/26/07 01:22 AM
05/26/07 01:22 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Not really how it works.
The mast rotation upwind is set by the position of the inhaul and the downhaul and how tight the mainsheet is. So going about requires no particular alteration.
The rotation tang is set when running down wind and that is not really needed unless there is little wind to make the mast rotate. At that point, yes it is a PIA to remember.
Re: 10:1 Yo Jake. [Re: warbird] #108124
05/29/07 04:22 PM
05/29/07 04:22 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
So did ya get a chance to measure that mainsheet???
Isak Dinesen
E. B. White
Re: 10:1 [Re: TampaN20] #108125
05/29/07 06:44 PM
05/29/07 06:44 PM
Warsaw, IN
F18MattJ Offline
F18MattJ  Offline
Warsaw, IN
We run 30 feet of main w/ a 8:1 and a saparate traveler line on our Capricorn F18.
Matt
Re: 10:1 Yo Jake. [Re: Team_Cat_Fever] #108126
05/29/07 07:08 PM
05/29/07 07:08 PM
86" of taper followed by 44' of covered sheet (including the combined split-tail traveler line). The mainsheet might still be a little longish...definitely long if all I was doing was buoys ... but those death reaching days in distance racing can sometimes require a LOT of sheet.
Re: 10:1 Yo Jake. [Re: Jake] #108127
05/31/07 08:35 PM
05/31/07 08:35 PM
Hey Jake,
Thanks. Did ya find that the extra purchase made up for the extra trimming required because of it.I was talking to a friend who said they had to re-adjust they're trim timing on the puffs because of it. Kinda got me wondering.
Thanks again for the lengths.
Todd
Isak Dinesen
E. B. White
Re: 10:1 Yo Jake. [Re: Team_Cat_Fever] #108128
05/31/07 10:04 PM
05/31/07 10:04 PM
Honestly, I'm not sold on it...granted, I haven't been the bastard sawing on it in a while...but still.
With the 8:1, you can let an arm's length out and it accomplishes a lot of recovery. With the 10:1, we found that you had to let more than that out leaving yourself having to double hand it back it after a big ease. I'm getting back on the front of an I20 later this year and plan on trying both to really figure it out...but I'm still leaning to the 8:1 and a strong crew for now.
Re: 10:1 Yo Jake. [Re: Jake] #108129
06/01/07 08:39 AM
06/01/07 08:39 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
My boat came with the 10:1 and I switched back to the 8:1. I like the 8:1 better and I think it's really about the same to pull in or out.
Mike Hill
www.stlouiscats.com
Mike Hill
N20 #1005
Re: 10:1 Yo Jake. [Re: Jake] #108130
06/01/07 08:46 AM
06/01/07 08:46 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Ditto...
Re: 10:1 Yo Jake. [Re: Keith] #108131
06/01/07 09:14 AM
06/01/07 09:14 AM
I like 10:1... I like it a lot. 'course my last two boats had 4:1 (Wave) and 6:1 (4.3).
[Linked Image] [Linked Image]
Re: 10:1 Yo Jake. [Re: John Williams] #108132
06/01/07 10:22 AM
06/01/07 10:22 AM
that said, I DO like the 10:1 on an F18 and have found that I can accomplish the ease with one arm while driving. Compared to the I20, there's not quite as much sail up top that needs to twist off on a big ease.
Re: 10:1 Yo Jake. [Re: Jake] #108133
06/01/07 11:06 AM
06/01/07 11:06 AM
so...wait... you like the 10:1 on the 18, but the 8:1 on the 20? I'm not seeing the logic here....
Re: 10:1 Yo Jake. [Re: waterbug_wpb] #108134
06/01/07 12:12 PM
06/01/07 12:12 PM
10:1 is definitely easier to tug on. However, the I20 requires more sheet motion than the F18 when easing in a gust to keep the boat moving well. On the F18, you can let out an arm's length (or maybe one wrap) on your hand to ease enough with 10:1. On the 20, however, with that monster sail and 10:1, you have to let out just a little more sheet such that you have to do one hand-over-hand to get it back to good trim once the gust is gone. With the 8:1 on the 20, you can do it with one arm pull, avoiding the slow hand-over-hand and have more effect on the sail trim. Yes, the 8:1 is harder to pull, but it's more costly time-wise to pull the extra sheet required by the 10:1 (and is usually the crew's problem anyway ;-)). This is purely my opinion but I've heard it echoed on the beach by several other teams.
1 registered members (basket.case), 474 guests, and 38 spiders.
