nacra trapeze system #108182
05/23/07 02:48 PM
05/23/07 02:48 PM
johnny872005 Offline OP
Can anyone please post good pictures of a properly rigged nacra trapeze system? (with dogbone and bungie cords and all)
thanks
Re: nacra trapeze system [Re: johnny872005] #108183
05/23/07 03:18 PM
05/23/07 03:18 PM
Lake Norman, NC
Special_Treat_P182 Offline
Lake Norman, NC
Here's an image of the stock system from the Nacra manual. Bungee cords through the hull tied off in a bowline, trap lines tied to them and knotted through the adjuster block and then through the dogbones. The only "upgrade" to consider could be a "hi-lo" adjuster from pg.49 of the Murrays catalog which makes it easier to adjust the trapeze length on the fly.
Re: nacra trapeze system [Re: Special_Treat_P182] #108184
05/23/07 03:27 PM
05/23/07 03:27 PM
so I guess I tie the rope directly to the bungie cord? I'm just kind of confused how the bungie cord connects to it all.
Also, what about blocks that are on some trapeze lines?
thanks
Re: nacra trapeze system [Re: johnny872005] #108185
05/23/07 04:26 PM
05/23/07 04:26 PM
Will_R Offline
Will_R  Offline
the rope is tied to one end of the dog bone/hoop. The rope then goes through the thimble on the wire. After that, the plastic piece goes on to act as a stopper. From there, the rope ties to the bungie which goes through the tramp and over to the other side.
That make sense?
Now, some systems have more bungie under the tramp, but most don't.
Re: nacra trapeze system [Re: johnny872005] #108186
05/23/07 11:27 PM
05/23/07 11:27 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Some systems have blocks(pulleys) attached to the thimble, and the line runs thru the blk instead of the thimble. This reduces friction, maintaining upward tension on the dogbone to keep it hooked in.
Dave
0 registered members (), 791 guests, and 43 spiders.
