| Re: Nacra center support tube, keep or toss???
[Re: tomthouse]
#108196 05/23/07 07:24 PM 05/23/07 07:24 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | IMHO I would keep the bar in place. It took some getting used to, but I have learned to like the bar. It has prevented several capsizes. On the other hand, if you really want to get rid of it, many 5.2 owner do. You will have to add throughbolts to the front (main) beam straps. The only reason for the bar is to keep the front beam from rotating under load. I know there are a couple of current or previous 5.2 sailors who have removed the beam. You would have to ask them how many bolts and what size to put through the mainbeam straps. I still vote for keeping it. It's just a way of your boat showing how much it loves you by bruising your knees and shins. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> Rob V.
Nacra 5.2
Panama City | | | Re: Nacra center support tube, keep or toss???
[Re: tomthouse]
#108198 05/23/07 09:17 PM 05/23/07 09:17 PM |
Posts: 179 dallas tx | I have a 5.2 also that I restored. I removed the center bar so that I would not get use to it in case I moved to another kind of cat. No other cat has one. The people that have not removed the bar loves it. They get use to using it and I did not want to get into that habit. If you do remove it all you have to do is put a couple of rivets into each of the front bar hold down straps. I removed the front bar mount but left the rear bar mount. I do have a habit of putting my foot on that to steady my self. If you click on th it will take you to other pics of the 5.2 ![[Linked Image]](http://inlinethumb18.webshots.com/5905/2049396670101263734S425x425Q85.jpg) | | | Re: Nacra center support tube, keep or toss???
[Re: airborne]
#108199 05/23/07 10:16 PM 05/23/07 10:16 PM |
Posts: 902 Norman,OK | I love my center bar, when you lift the hull really high just goofing around you can just stand on it. Granted it is probably a disadvantage at times but I would hate to be without it.
448
guests, and 272
