| Re: fixing tiller arm
[Re: johnny872005]
#108233 05/24/07 12:43 PM 05/24/07 12:43 PM |
Posts: 12,310 South Carolina | Is it the old-style aluminum tiller extension? If so, put it under water and work the entire thing throughout it's range and keep locking and unlocking it. It will probably work better.
As far as it coming out, I don't recall what keeps that from happening but I seem to remember it happening to me every now and then too. You may be able to carefully squeeze the end of the outer sleeve to retain the inner part.
Or, then again, you can go buy an $18 aluminum painting extension stick and use it instead.
Jake Kohl | | | Re: fixing tiller arm
[Re: johnny872005]
#108235 05/24/07 01:16 PM 05/24/07 01:16 PM |
Posts: 12,310 South Carolina | the locking cam probably has some sand or gunk in it. If you put it under water and extend and collapse the tiller extension quickly and work the lock mechanism, it will probably clean it out.
Jake Kohl | | |
16,102
guests, and 1,036
