| mast rake #108356 05/26/07 06:16 PM 05/26/07 06:16 PM |
Posts: 4 Netherlands | On mast rake:
1. how do you determine whether you have found the right balance between more mast rake (allowing to point higher?) and less (allowing to move more forward so to get the transom higher up without getting - too much - weather helm?) 2. I sail a Capricorn and with my new crew have just shifted to a small set (combined 133 kg). With the smaller jib (and spi) up, does this mean that we should sail with less rake (compared with those who sail with the bigger/normal set) as there is less sail area in front of the mast? 3. AHPC instructions say that Capricorn is sailed with more mast rake than other F18s, but is this indeed the experience of Capricorn sailors? 4. does one play around with rake depending on wind force (I hope not) or should rig tension variation be enough to find the right setup depending on how hard it is blowing that day?
This is getting a bit of a headache for me; any help is much appreciated.
Capricorn F18
Nacra 5.5sl
1 registered members (FredL),
309
guests, and 23
