Page 2 of 3 1 2 3
Re: What experience yielded the highest "pucker factor [Re: ncik] #108606
05/31/07 12:20 PM
05/31/07 12:20 PM
Lake Norman, NC
Special_Treat_P182 Offline
Lake Norman, NC
'ncik',
"I hate to ask the question, but who was on the others port side?"
I'm not sure I understand your question. We were both on the wire on the port hull and the Bayliner came at us from a 90-degree angle from directly downwind. We couldn't see it through the mainsail. Starboard tack/port tack - didn't matter, we had the right of way over a powerboat.
Re: link for EMT scissors, only six bucks [Re: Special_Treat_P182] #108607
05/31/07 06:10 PM
05/31/07 06:10 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Thank you 'Doug.' Thanks for bringing this tool to the surface for us. Is it true that:
They'll cut through a trapeze wire like a hot knife through butter.
?? Are you talking about trap WIRES?
GARY
Santa Monica Bay
Re: link for EMT scissors, only six bucks [Re: hobiegary] #108608
05/31/07 06:48 PM
05/31/07 06:48 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Barging into the men's room at GYC and seeing Tikip......
Re: link for EMT scissors, only six bucks [Re: tshan] #108609
05/31/07 07:03 PM
05/31/07 07:03 PM
You just wait. . .!
Re: link for EMT scissors, only six bucks [Re: fin.] #108610
05/31/07 07:10 PM
05/31/07 07:10 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
You KNOW it was just a joke. Sailing with TBack was much more scary............
<img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
He would probably never sail with me again.
Re: link for EMT scissors, only six bucks [Re: tshan] #108611
05/31/07 07:14 PM
05/31/07 07:14 PM
Yes I know it's a joke, but you're right. T is Terribly freightening! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: What experience yielded the highest "pucker factor [Re: Special_Treat_P182] #108612
05/31/07 07:15 PM
05/31/07 07:15 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
'ncik',
This is a good question for me AND it will show my ignorance. Do sailboats ALWAYS have the right of way over power boats? or do standard "rules of the road" (not racing rules) override the sail power versus motor power in some occasions?
Example: if this collision occured between two power boats, the boat to the port side of the other is responsible for giving way, right??
Re: What experience yielded the highest "pucker factor [Re: tshan] #108613
05/31/07 07:43 PM
05/31/07 07:43 PM
ncik Offline
ncik  Offline
The rules of the road are that you should give way to anything on your starboard side; whether racing, power, sail, drifting...anything.
But generally speaking, depending on the manouevrability of the vessels, power boats tend to keep clear of sailing boats...but you shouldn't rely on this general rule as the consequences can be tragic.
Re: What experience yielded the highest "pucker factor [Re: tshan] #108614
05/31/07 08:03 PM
05/31/07 08:03 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Down our way passing rule applies to sailboats. Sailboats must take care and give way to ferries and motor vessels unable to manouver easily.
This is an example of a good time to give way to a motor vessel. : )
While the rule goes the way of the sailors it is always a good idea to be paranoid. If a vessel is a long way away when you set up your run but MIGHT be able to reach you and run you down any boatie, sail or motor should presume the other guy is an idiot and presume he is behind the sail. As sailors we must look out for our own safety and understand that the sail with no window is a blind spot that is our responsiblity.
Sad thing is that on the water bigger and dumber are dangerous and idoits almost always think autohelm is a licence not to pay attention.
Right and wrong has nothing to do with it.
As an example I always slow through a green light at an intersection, because somewhere out there is a red light runner with my name on it.
Re: What experience yielded the highest "pucker factor [Re: warbird] #108615
05/31/07 08:18 PM
05/31/07 08:18 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
I agree and always try to stay clear of any traffic while cruising. I may push it a little further if racing, but usually opt to tack/gybe away before quarters get tight (especially when dealing with boats plowing through the middle of a race course - "ohh, look at that pretty buoy - wonder what that means???").
So... in open water, the TheMightyHobie18 in this story should have given way to the power boat? Assuming sailing upwind, trapped out on the port side... Sorry to be such a moron, but I;d rather not replicate the "pucker factor".
right of way from the US Coast Guard [Re: tshan] #108616
05/31/07 08:31 PM
05/31/07 08:31 PM
Lake Norman, NC
Lake Norman, NC
Except where Rules 9, 10, and 13 otherwise require:
(a) A power-driven vessel underway shall keep out of the way of:
1. a vessel not under command;
2. a vessel restricted in her ability to maneuver;
3. a vessel engaged in fishing;
4. a sailing vessel.
(b) A sailing vessel underway shall keep out of the way of:
3. a vessel engaged in fishing.
US Coast Guard Navigation Center
So we in a sailboat have the right of way under ANY tack against a maneuverable powerboat under way. YES, I agree that it doesn't mean we should always assume that stupid poweboaters will give way. In fact, I assume just the opposite. But you can't avoid what you can't see. If it were another sailing vessel, since we were on port tack, we would have had to give way. But we would have seen it at some point. It's not like Danny wasn't looking downwind under the boom at ALL! The Bayliner was traveling at close to 40mph when it hit us. It came up on us so fast and so sudden there was no way we could've avoided or even maneuvered the Hobie fast enough to get out of the way.
Re: right of way from the US Coast Guard [Re: Special_Treat_P182] #108617
05/31/07 08:58 PM
05/31/07 08:58 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
I was not trying to assess blame. I sail in a tea pot most of the time; however, I do venture to the open water a couple of times a year and would like to understand as best I can. Obviously, a boat going twice+ your speed is going to surprise anyone (closing speeds become a big factor). I did not mean to condemn your and Danny's efforts to sail safely.
You guys probably felt like the Snipes and Lasers that I share a race course with. They used to try their monohull tactics on me, but now they just let me go -as I'll be gone shortly.
Re: right of way from the US Coast Guard [Re: Special_Treat_P182] #108618
06/01/07 03:50 AM
06/01/07 03:50 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I was not apportioning blame either. But I stand by what I said. If you have a blind spot on any point of sail take care because there ye be monsters. arrrrgh.
I mean, are you saying you still have no window and presume you are safe? Surely there is a lesson in your experience for all of us??
Re: What experience yielded the highest "pucker fa [Re: tshan] #108619
06/01/07 08:27 AM
06/01/07 08:27 AM
Appleton, WI
blockp Offline
blockp  Offline
Appleton, WI
All very true, but... I have the right of way when I'm walking across the street too, but I still look for traffic before crossing <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Makes me crazy when driving near a school and kids won't even look for traffic, so many of them just put their head down and walk across the street <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
Whenever possible, I avoid other boaters paths. Whether driving my sailboat, ski boat, john boat or canoe. I try not to even let it be a question as to who has the right of way.
Re: right of way from the US Coast Guard [Re: Special_Treat_P182] #108620
06/01/07 08:44 AM
06/01/07 08:44 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
A couple of things to add to the discussion (not necessarily to this particular accident):
Any boat overtaking another has to keep clear. Sail or power.
The fishing boat thing listed above is a narrow definition the mostly covers commercial type operations. Bobby Joe trawling for rockfish doesn't count, although he might disagree.
As the privileged vessel in crossing situations, you have a responsibility to make it easier for the other boat to maneuver away. And this generally means you need to hold course for as long as possible. Of course, this needs to be balanced against picking a bail-out point to avoid collision if it comes to that.
Re: right of way from the US Coast Guard [Re: tshan] #108621
06/01/07 09:05 AM
06/01/07 09:05 AM
Lake Norman, NC
Lake Norman, NC
I never got the impression that you were condemning our ability to safely sail. And I didn't feel insulted in any way.
Re: right of way from the US Coast Guard [Re: warbird] #108622
06/01/07 09:11 AM
06/01/07 09:11 AM
Lake Norman, NC
Lake Norman, NC
Dan learned his lesson and the "new" Hobie 18 came with a mainsail with a window in it. I still have my factory windowless main, but I am mindful when I sail to know what's downwind of me as much as possible. When the day comes that I replace it, it will be a sail that eliminates blind spots.
Again, I agree. We may not have been at fault in the actual collission. But we were at fault for even allowing it to happen. I'm a "defensive sailor". I have to be. Lake Norman, NC can get pretty crowded with powerboaters on the weekends and some of those yahoos are usually drinking.
So I would rather be alive and give up the right of way than dead with a tombstone inscription that reads, "it wasn't his fault."
Re: right of way from the US Coast Guard [Re: Special_Treat_P182] #108623
06/01/07 09:16 AM
06/01/07 09:16 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
That's what my mother used to say was the difference between being "right" and "dead right"!
Re: link for EMT scissors, only six bucks [Re: tshan] #108624
06/01/07 09:44 AM
06/01/07 09:44 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
tshan,
When you say: "scary", I'm sure you meant "scary FAST" ... because we were S C A R Y F A S T (when not stuffing the bows in the blow!!).
I'll sail with you anytime (skipper or crew)...come on down this weekend!
t.
USA 777
Re: right of way from the US Coast Guard [Re: Keith] #108625
06/01/07 09:52 AM
06/01/07 09:52 AM
Appleton, WI
blockp Offline
blockp  Offline
Appleton, WI
That's one of my favorite lines.
We have a local radio personality that jokes about the fact that she's been in 9 accidents in her life, and always justifies it with "none of them have been my fault".
Riiiiigggghhhht. Sometimes you're just in the wrong place at the wrong time, but _9_ times!
Page 2 of 3 1 2 3
1 registered members (Damon Linkous), 2,534 guests, and 340 spiders.
