| Re: JPOR
[Re: scooby_simon]
#108701 06/03/07 04:46 PM 06/03/07 04:46 PM |
Posts: 3,348 | The boats on trailers with masts DOWN were fine. They all had sail boxes and were pretty heavy. A Capricorn with MAST UP, on a heavy trailer was fine.
A H-16, with mast up, on the trailer was fine.
My boat, mast UP was tied to the trailer and flipped anyway, trailer and all. My rigging hung-up on the trailer of the Capricorn parked next to me. My boat suffered no damage, neither did the Cap. My trailer does not have a sailbox. I have intentionally tried to keep my trailering weight down.
I will add a sail box to my trailer, with very little consideration of weight and keep some tie down anchors in it. My preference will be to keep the boat on the trailer with mast down.
Thanks Jennifer, Fred, Bryan, Chuck, Mavis, David, Kathy, Paul and Terry. I hope I haven't forgotten anyone. It took all those folks plus Matt, Tim and me a couple of hours to police up all the bits and untangle all the spahetti. | | | Re: JPOR
[Re: fin.]
#108702 06/03/07 04:58 PM 06/03/07 04:58 PM |
Posts: 3,528 Looking for a Job, I got credi... | The boats on trailers with masts DOWN were fine. They all had sail boxes and were pretty heavy. A Capricorn with MAST UP, on a heavy trailer was fine.
I will add a sail box to my trailer, with very little consideration of weight and keep some tie down anchors in it. My preference will be to keep the boat on the trailer with mast down. Was it tied down on both sides ? I always try and tie my boat down both sides if I can. So <boat trailer><BOAT><car or other trailer> and then use the trap wires with ropes on to tie the boat down; this stops it blowing over. If at all possible I will also try and tie it to something to stop it going forwards or backwards.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: JPOR
[Re: fin.]
#108704 06/03/07 06:02 PM 06/03/07 06:02 PM |
Posts: 3,528 Looking for a Job, I got credi... | My boat was secured to the trailer at four points, i.e. fore and aft on each hull. Holey moley and it still blew away ! Was can you work out if the mast powered up and caused it to go over ?
[Re: scooby_simon]
#108707 06/03/07 07:50 PM 06/03/07 07:50 PM |
Posts: 6,049 Sebring, Florida. | I think the wing mast had a lot to do with the Blades going over while the Hobie 16 stayed upright, of course the lighter weight of the Blade didn't help hold it down, but once the wind changed direction and got to the 'wrong' side of the mast, there is quite a bit of wing area up there for it to act on. It appeared that my boat flew about 30 feet backwards and landed on the starboard bow.
Blade F16 #777
| | | Re: JPOR
[Re: scooby_simon]
#108708 06/04/07 04:10 AM 06/04/07 04:10 AM |
Posts: 9,582 North-West Europe | Yep, boat is tied down here as well.
When I'm at a regatta venue that is not my homeport then sometimes I make sure that another F16 sailors places his trailer next to mine with enough spec between them to place both our boats. We then use the trapeze wires and the trailers to pin our boats to the trailers when the masts are stepped. We survived some good winds that way. And it removes the requirement to dig. Quick and effective.
But indeed F16's must never be left unattended or untied when their masts are stepped (or even the sails are hoisted). These boats are light enough to by thrown about even by modest gusts.
I learned my lesson as well, luckily no damage.
When I'm on a sail away to a neighbouring club to do some races there then I tip my boat over intentionally when I'm on the beach and getting a drink. I forgot to do that one time and a very modest gust flipped it when I was some 200 mtr away. The rig narrowly missed a pedestrian. Additionally I ALWAYS unhook my mainsail when I'm on the beach.
Again, these boats are just too light to take chances with.
| | | Re: JPOR
[Re: Timbo]
#108709 06/04/07 04:19 AM 06/04/07 04:19 AM |
Another trick is to use a section of 1x2 timber, say 2 feet. Dig a hole (2 feet deep), tie a piece of line the to middle of it and place the timber horizontally in the hole and close it. You will need tons of kg to pull that ground achor out by force. But when digging it up you just dig a narrow hole and lift it out by one end.
Best to place both such ground anchors to each side of the boat and tie the line off to the sidestays. This is how we all do it here in the boat parking and we have very soft sand as well. We survived all storms to date.
| | | Re: JPOR
[Re: Timbo]
#108710 06/04/07 04:25 AM 06/04/07 04:25 AM |
Yep, that wingmast can generate quite alot of power on its own. Remember that their is 1.5 sq. mtr. of area in the mast and it is a (symmetrical) WING shape. Almost like a helicopter rotor blade.
I always secure my mast rotation in addition to tying the boat down. If I don't then the mast will go look for angle with the optimal power ratio and shake my boat about. With a secured mast rotation the chance are that the angle it wrong and a stalled flow goes across the mast reducing the force generated.
Lets face it guys these boats just want to FLY !
| | | Re: JPOR
[Re: pdwarren]
#108711 06/04/07 04:59 AM 06/04/07 04:59 AM |
Posts: 3,348 | My trailer is galvanized steel and has an adjustable wheel attached to the front of the tongue, making it even heavier.
My mast rotation was NOT locked down, intentionally. I thought that was the proper technique. Jennifer Lindsey, the engineer on the spot, believes a "free" wing mast sets up an oscilation that adds to the instability. (Think about that bridge that shook itself apart in the U.S. back in the forties.) She also suggests a much wider base for the tie-downs, such as many of you have suggested.
<img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> After my boat had been righted (by Fred and Jennifer), it blew over again! Right in front of me! I did not think the wind was excessively high at that point, maybe 15-20, but the boat was not tied to the trailer. It was just sitting on the beach! IMO, if the wind is over 15, the boat needs to be tied down, or someone needs to be sitting on it. Even while rigging. | | | Re: JPOR
[Re: fin.]
#108712 06/04/07 05:37 AM 06/04/07 05:37 AM | Anonymous
| Anonymous
Unregistered | Hi all,
I avoided replying to this post straight away, hopeing to give time for the hurt to fade <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" />.
I too always lock my mast across, most times my boat has been left on beach rollers with mast up at different regattas. My hold down set up is to move rollers to back beam, then I fill two 20 litre drums with water (aprox. 20kgs each), either tap or what we race in <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />. Then tie the trap wires to the handles on the drums which are moulded in, the drums are placed at the side of the boat near sidestays.
Advantages, if you are going sailing there is allways stuff to put in them, light weight when travelling, doesn't matter if you are on hard ground or soft sand, if filled by tap can be used to wash down before packing up <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />. | | | Re: JPOR
[Re: fin.]
#108713 06/04/07 02:17 PM 06/04/07 02:17 PM |
Posts: 12,310 South Carolina | Those dog screw type anchors really won't hold very well in sand. We use the orange anchors that you can find at "rustic" hardware stores (like a local Ace Hardware or similar). They have a 1/2" rod in the center with a spiral plate welded to the tip (not a twisted rod). These will hold much better than those dog tie-out screws. I suppose those could be the same as the "hurricane anchors".
Jake Kohl | | | Re: JPOR
#108714 06/04/07 02:59 PM 06/04/07 02:59 PM |
Posts: 1,246 Orlando, FL | yes the same jake ... except at ACE you get more assortment of lengths...from 12" up to 4' in length.
USA 777
| | | Re: JPOR
[Re: Timbo]
#108715 06/05/07 08:48 AM 06/05/07 08:48 AM |
Posts: 396 Annapolis Md. | Tim & Matt, sorry to hear of the damage. With the A Cats I'm used to tying the boat down early and often but I've been enjoying not having to worry so much with the heavier (although slightly) and wider F-16. Looks like I need to be diligent with this boat also. I'm using the same stake as Jake with good results. We get ours at the local farm supply and they come in different lengths up to 4'. They are also available in Horse (tack) supply shops if you live in a horse type area. Ed
Still hazey after all these beers. F-16 Falcon #212
| | | Re: JPOR
[Re: LuckyDuck]
#108716 06/05/07 09:28 AM 06/05/07 09:28 AM |
Posts: 548 MERRITTISLAND, FL | Ed,
I was using 1 of those screw type anchors and it was still solidly attached to the dolphin striker with the boat upside down. It was one of the short ones, but I had dug a deep hole first, screwed it in then as far as I could go, then filled in the hole, so the top was at least 2 below the surface. I also had my heavy cat trax tied to the front of the bows to add more weight. They also were still firmly tied to the bows the next morning.
When I left for the site, the forecast was for the wind to continue to die slightly and back around more west over night. I had to completely string up the whole boat and was supposed to help with the event set-up, so was trying to get a head start on rigging for Saturday. Turned out to be a bad call. I think what really got us was that the east wind and full moon brought the tide way up. The weed line was above where we were tied down and the trailers were all partially submurged. The waves most likely shifted the boat and the wing mast took it from there.
That's what I get for trying to do things in advance; why couldn't I have procrastined as ususal (another case of positive reinforcement for a bad habit). I lucked out, other than the broken stick, there was not so much a scratch on the boat. Timbo ended up with the bad deal. | | | Re: JPOR
[Re: Matt M]
#108718 06/12/07 11:01 AM 06/12/07 11:01 AM |
Posts: 396 Annapolis Md. | We are usually working with compacted dirt up here. It looks like working with sand is a whole nother story and I appreciate all the tips providied. Again, sorry you guys (and gals) had a tough weekend of it. There are many more regattas coming up and I'm sure they will ease the pain. Ed
3,175
guests, and 228
