| Re: Righting a Hobie 16
[Re: Skipshot]
#109380 09/15/07 11:19 PM 09/15/07 11:19 PM |
Posts: 5 | I may not be the world's best hobie 16 sailor, but I've flipped the damn thing over so many times, I know a thing or two about righting it.
I find 'playing anchor' works better than trying to swim the boat into position, I often just have my crew hold the righting line to stop the boat from turtling , while I either move forward to bring the tramp up and weather-vane, or I just jump in the water at the bows, and kick moderately against the wind and waves, essentially 'playing anchor' and really just letting the elements push the rest of the boat downwind faster than the part I'm holding onto - I find this tends to work really well.
In winds below about 18kts, it's enough just to get broadside and everything uncleated, in winds above this - ( I recently righted easily on a first try in ~30 kts, shocked me how easy it was) you HAVE to get in a close reach/haul position before attempting to right, no matter how much you uncleat.
In high wind and waves, I find there's no point in even trying to bring the boat up unless you have it in close reach/haul position, it'll just blow over the other way no matter what you do; and loosing energy righting a hobie can get dangerous (especially if a nasty lee shore with rocks is getting closer and closer).
Another trick I find, and I don't know how kosher this is, is I actually use the painter a lot as a righting line; I'll often have my crew grab the main line, while I throw the painter above the hull over my head, just behind the bow tramp post, I find this lets me dance forward on the hull to both help weather vane, and to help pull the boat up.
Anyway, hope this helps Charlie | | | Re: Righting a Hobie 16
[Re: hrtsailor]
#109382 09/16/07 09:27 AM 09/16/07 09:27 AM |
Posts: 902 Norman,OK | The mast into the wind works in light stuff, but as the wind picks up I find the best way to right the boat is hulls directly into the wind. That way when it comes up it doesn't go over the other way.
[Re: eclecto]
#109384 09/16/07 12:07 PM 09/16/07 12:07 PM |
Posts: 182 Coopersburg, PA | In high wind and waves, I find there's no point in even trying to bring the boat up unless you have it in close reach/haul position, it'll just blow over the other way no matter what you do; and loosing energy righting a hobie can get dangerous (especially if a nasty lee shore with rocks is getting closer and closer). I always turn the boat with the mast pointed into the wind when righting, even with heavy waves and wind. The trick to not having the boat blow over again once you right it this way, is to have your crew put all their weight on the righting line, and as you both pull, the masthead will slowly come out of the water. Once you see the masthead out of the water, you can be sure that the boat will be coming over very soon. At this time, I stop pulling on the righting line, and allow my crew to keep their weight on, and as the boat comes over I grab the dolphin striker bar at the front crossbar post and hold the boat. I've found that if, (in heavy winds) you and your crew both put all your weight on the righting line and let the boat come back over ontop of you both, the wind will just push her back over onto the other side, regardless of whether your sheets are cleated or uncleated. By holding the dolphin striker, the boat comes over, and i can use my weight on the opposite side to hold the boat down and prevent it from flipping over on the other side, also it is easier to get back on the boat because you can climb on as the boat is in the righting motion.
~vinny~
[Re: Vinny_M]
#109387 09/19/07 09:34 AM 09/19/07 09:34 AM |
Posts: 5 | Yeup, I do that stuff - letting go and grabbing the striker before the boat has a chance to tilt to leeward etc (maybe my timing is off?) - but I find, once the wind is over ~18 kts, forget it ... you gotta be at 45 degrees, not 90 (mast directly to wind), otherwise it doesn't matter how uncleated or how hard you hold on to windward (striker, etc), the boat just goes over again anyway.
Maybe you're doing something I'm not, but I find, if I can get the boat at 45 degrees, even in 5ft waves and 25kts, I can get the boat up and keep it up most of the time - if I'm at 90, I'm just wasting my energy bringing it up, as it's only going to go over again anyway, forcing everybody to start the whole process from the beginning: which can get dangerous as people tire out and the lee shore approaches. | | |
799
guests, and 916
