| Beach Rub Mark repair #109434 06/12/07 04:02 AM 06/12/07 04:02 AM |
Posts: 9 Sarasota, FL | Looking for some input on this one. Just picked up an older 18' cat and other than some beach rub on the bottom of the hulls she is in great shape. She is not even rigged right now so I will be able to turn her upside down fairly easily and get the boat on some foam or cushions to sit for a while. What has everyone had the most success with for the rub lines. We are talking about 2'-3' sections of the bottom of the hull being worn down to bare fiberglass. I was thinking of using 4"-6" wide tape fiberglass cloth or even springing for the kevlar cloth for a little upgraded rub resistance. Any thoughts from you guys and ladies out there who have done this already?
Hobie TF#166 Hobie 17SE# Gibbs Shark#?? Sail#US 56
| | | Re: Beach Rub Mark repair
[Re: Cleric]
#109435 06/12/07 09:08 AM 06/12/07 09:08 AM |
Posts: 833 St. Louis, MO, | Sounds like a good plan. Fibreglass tape and gelcoat. Do not use Kevlar on it. Kevlar is terrible to repair and sand.
Mike Hill N20 #1005
[Re: Mike Hill]
#109436 06/12/07 02:21 PM 06/12/07 02:21 PM |
Posts: 9 Sarasota, FL | I appreciate the reply. Did not know if putting a little Kevlar cloth in there would make it last a little longer between times of fixing it. I take it you speak from experience <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
[Re: warbird]
#109438 06/13/07 03:36 PM 06/13/07 03:36 PM |
Posts: 9 Sarasota, FL | warbird I mainly am used to using West Systems for all my epoxy resin needs. Usually to strengthen the resin I add some of the structural fillers that they have. Is this along the lines of what you are talking about? I have had quite a successful amount of repairs done with this mixture and have been happy so far. I am just looking to put something on there that will last for a while. Of course I know that it will last longest by not dragging it on the sand <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
[Re: warbird]
#109441 06/14/07 11:29 AM 06/14/07 11:29 AM |
Posts: 9 Sarasota, FL | Thanks for the help. I really like the idea of the repair using the thickened epoxy. This is not a structural repair really just a build up for the bottom. What is everyones feeling about gel coating this? I do not keep it in the moored or docked. She comes out everytime when I am done with the days sailing fun. I could mix in some of the pigment into the epoxy, they have a white pigment but I would almost like to leave it be for full strength. Any opinions? Thanks!
[Re: Chris9]
#109446 06/14/07 04:32 PM 06/14/07 04:32 PM |
Posts: 9 Sarasota, FL | My next question is then, what type of gel-coat do you guys recommend? And being a gel-coat newbie what is the best way to apply it? Thanks again guys, I really appreciate this help <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
[Re: Cleric]
#109447 06/14/07 04:43 PM 06/14/07 04:43 PM |
Posts: 833 St. Louis, MO, | Standard West Marine Gelcoat. Get some Acetone too. You might need some styrene to thin it a little to spray it. Practice on a piece of wood. Here's a list:
1. Spray bottle 2. Mold Release 3. Gelcoat 4. 3 mil plastic sheeting 5. Tape. 6. Color agent for gelcoat if needed. 7. Preval sprayer (available at West Marine) 8. Acetone to clean the sprayer.
Turn it upside down Sand it to get a smooth finish 100-220 grit. Tape it off with the plastic and tape that you don't want sprayed. Overlap a little. Spray it with possibly a little styrene to thin it. Spray 3 coats about 20 minutes apart. After the last coat sits for about 15 minutes spray the whole thing with Mold release. Let it sit for 24 hours. Wash off the mold release and start sanding. Start with 220 and work your way to 600 or so wet with a long board. You can finish with a 3M product. I forget the name.
Mike Hill
Mike Hill N20 #1005
517
guests, and 100
