| TORNADO sectionable #109922 06/19/07 01:52 PM 06/19/07 01:52 PM |
Posts: 3 | Hi All, I'm new to this forum. I traveled a lot in a lot of forums, at the end I came into this. I think you are the right people can fix my problem. So goodbay to everybody. I want to build a cat for camping for two people and I want to be able to transport the cat on top of my car. After a lot of discussions I came up with the conclusion that I need a cat 5 meters long at least. My problem is that for italian law I cannot have more than 4 meters on top of my car. I was thinking to scaling a TORNADO down to 4 meters, but I was discouraged by the tornado-ers because of the unknown performances. So the question for you is: Could I build the 6 meters hulls for the TORNADO, then cut them in two half, installing two robust walls at the end of each half hull and assembling the two half hulls with (let's say) 8 bolts ? I know it will become heavyier but will fix my top car problem and on the sea I will sail a 6 meter cat. I don't want to build a proa, but give a look at this link http://www.instructables.com/id/ERIIBDCCOTEPUCHZ1K/?ALLSTEPSI know that proa is rough, but I can take the idea and implement something more clean and applicable to a Tornado. What do you think? I will really appreciate your feedback. NINO. | | | Re: TORNADO sectionable
[Re: torant]
#109925 06/19/07 08:21 PM 06/19/07 08:21 PM |
Posts: 1,307 Asuncion, Paraguay | I want to build a cat for camping for two people and I want to be able to transport the cat on top of my car... My problem is that for italian law I cannot have more than 4 meters on top of my car. There certainly are many ways to make a six meter cat and an eight meter mast fit within the four meter limit. In my opinion the big problem will be the time and work it will take to assemble and disassemble the contraption. The Tornado is definitely not the boat for this. It is too complex, its floats lack enough flotation to carry camping gear and it is built for speed, not to take the abuse of daily journeys and night camping. The closest match to your needs are the Supercats / ARCs. They were designed and engineered to be fast, simple, efficient and easy to assemble/disassemble. A Supercat / ARC 19, 20, 21 or 22 halved in the right place, properly engineered for re-assembly of the floats and rigged with a two part mast would probably be your best bet. If you find a used one close to home, contact the factory ( Aquarius Sail) and discuss how to cut the floats and mast to fit within the four meter limit while still keeping (or improving) the safety factors. If there are no used Supercats / ARCs in Italy, you don't need to build the entire boat. Find a suitable cat with high flotation floats, simple and easy to assemble / disassemble. When you find it, sail the boat, learn all you can about it and then discuss the best way to cut the floats and mast here, or in other fora, like the Multihull Builders Yahoo group, for example. Good luck, Luiz
Luiz
[Re: torant]
#109926 06/19/07 08:44 PM 06/19/07 08:44 PM |
Posts: 12,310 South Carolina | You know? You could hand build a trailer in less time than it would take to find a way to cut a boat in two in such a way that it can be reassembled. If you then factor in the extra time you spend setting it up and tearing it down, you'll probably find that the trailer makes a pretty fair trade-off.
Jake Kohl | | | Re: TORNADO sectionable
[Re: torant]
#109928 06/19/07 10:42 PM 06/19/07 10:42 PM |
Posts: 461 Sydney Australia | Hi All, I'm new to this forum. I traveled a lot in a lot of forums, at the end I came into this. I think you are the right people can fix my problem. So goodbay to everybody. I want to build a cat for camping for two people and I want to be able to transport the cat on top of my car. After a lot of discussions I came up with the conclusion that I need a cat 5 meters long at least. My problem is that for italian law I cannot have more than 4 meters on top of my car. I was thinking to scaling a TORNADO down to 4 meters, but I was discouraged by the tornado-ers because of the unknown performances. So the question for you is: Could I build the 6 meters hulls for the TORNADO, then cut them in two half, installing two robust walls at the end of each half hull and assembling the two half hulls with (let's say) 8 bolts ? I know it will become heavyier but will fix my top car problem and on the sea I will sail a 6 meter cat. I don't want to build a proa, but give a look at this link http://www.instructables.com/id/ERIIBDCCOTEPUCHZ1K/?ALLSTEPSI know that proa is rough, but I can take the idea and implement something more clean and applicable to a Tornado. What do you think? I will really appreciate your feedback. NINO. Here's the answer; http://www.smartkat.at/en_smartkat.html | | | Re: TORNADO sectionable
[Re: torant]
#109932 06/20/07 02:41 PM 06/20/07 02:41 PM |
Posts: 3,348 | | | | Re: TORNADO sectionable
[Re: torant]
#109933 06/20/07 02:46 PM 06/20/07 02:46 PM |
Joined: Aug 2003 Posts: 351 Santiago, Chile Andinista
Posts: 351 Santiago, Chile | NINO, with all respect and some admiration.. I think you are crazy... good luck on your project. About space for storage, I think there are still possibilies for inflatables, I´ve seen pictures of devices to adapt a cooler to the front beam. Also here is a patent for wings with volume for storage, it might be a good idea too. http://www.patentstorm.us/patents/5540168-description.htmlStoring stuff inside the hulls is not that easy anyway, normal inspection ports with sleeves do not provide a lot of volume and something bigger would require special care to make a good seal or maybe separate compartments. But my impression is that the major challenge would be to split the mast, the junction has to be strong and also the mast should be sealed, to avoid turtling. What about a sectionable trailer? | | | Re: TORNADO sectionable
[Re: torant]
#109934 06/20/07 03:08 PM 06/20/07 03:08 PM |
Posts: 1,307 Asuncion, Paraguay | A hinge in the keel will allow a halved float to fold keeel-to-keel.
Cut each float in two near the chosen bulkhead. Laminate a new bulkhead to the part left opened for watertightness and strength. Attach the two halves with a strong hinge near keel level.
Choose one of the many alternatives to lock the half floats in position at deck level. It can be done outside the float. A webbing and ratchet like that in the kayak you indicated could work. Maybe laminate a pair of "external extensions" to the bulkheads and bolt them together.
Keep dreaming.
Luiz
[Re: fin.]
#109935 06/20/07 03:32 PM 06/20/07 03:32 PM |
Posts: 1,152 tampa, fl | Hey Pete - Thanks for posting those pictures. Now I have to go home and gouge my eyes out. bleghhhhh!!!!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: TORNADO sectionable
[Re: Andinista]
#109936 06/20/07 03:53 PM 06/20/07 03:53 PM |
Posts: 12,310 South Carolina | you could put a square pocket inside a hull with a small drain tube to the outside through the side of the hull. Then the lid wouldn't need to be completely waterproof.
[Re: ksurfer2]
#109937 06/20/07 03:53 PM 06/20/07 03:53 PM |
Posts: 3,348 | Hey Pete - Thanks for posting those pictures. Now I have to go home and gouge my eyes out. bleghhhhh!!!! C'mon! They guy wants something he can: put on top of his car, carry beer and sam'iches for two days, and build at home! <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> | | | Re: TORNADO sectionable
[Re: fin.]
#109938 06/20/07 03:58 PM 06/20/07 03:58 PM |
Posts: 1,152 tampa, fl | Yeah, I get that...but the the old wrinkled guy with the string bikini in the picture! What's up with that?!?!?
[Re: ksurfer2]
#109939 06/20/07 04:01 PM 06/20/07 04:01 PM |
Posts: 3,348 | Yeah, I get that...but the the old wrinkled guy with the string bikini in the picture! What's up with that?!?!? <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> That would be James Wharram, and his son, after 50 years of sailing cats. | | |
3,076
guests, and 398
