| Re: Hobie trampoline difference
[Re: Wallybear]
#110872 07/05/07 03:12 PM 07/05/07 03:12 PM |
Posts: 9,582 North-West Europe | Is there any particular reason for the difference?
No pylons is : - cheaper - stiffer - less damage/wear/leaking prone Sitting or trapezing of the hulls instead of the trampoline bars is : - more confortable - much less painful when sailing long distances Wouter
[Re: mmiller]
#110875 07/06/07 02:37 PM 07/06/07 02:37 PM |
Posts: 9,582 North-West Europe | Humm, I did sail all/both and : Your feet are above the wave action that sweeps along the hull. Less getting your legs washed out from under you.
This is far more a result of the rim on the hulls then off the raised tramp. Why do I know ? Because my Prindle had much the same feeling in this respect as the Hobie. Trapezing from the rail is drier.
Again, hull rim ! Carpet or neoprene on the rails gives better traction than most hulls. Better footing.
After a little while you could always peel the neoprene of the Hobies with you butt. Carpet ? I'm not even commenting on that. Try self adhesive embossed anti-slip vinyl tape. Keeps working even after years of UV, is smooth so won't take the skin of your limbs, and your rubber footies will stick like glue to it even when awash with water. In a cat with straight crossbars mounted directly to the hulls (not arched like the 17, 18 and Hobie 21) you will find that the boat is less comfortable to sail in rough conditions. Especially evident downwind.
But let me suffice by pointing out that even Hobie has discontinued their last curved beam catamaran several years ago. If you place a modern straight beam cat design next to a Hobie 17 or Hobie 18 you'll find that the less tall hulls of the latter boats corrects out for any curvature in the beams. Also the beams on a Prindle (straight even as far back as in 1972) are at the same height as the Hobie 16; reason ? The prindle 16 hulls are significantly taller then the Hobie. Curved beams and raised trampolines are a thing of the past. There are no advantages that can't also be had with straight beams. Wouter
[Re: Wouter]
#110876 07/06/07 05:42 PM 07/06/07 05:42 PM |
Posts: 1,252 California | Curved beams ... There are no advantages that can't also be had with straight beams.
Wouter I wouldn't say that. The curved beams are just more difficult to build and cause the builder to have a left and right deck. More expensive. They have definite advantages, but, as you said... may be a thing of the past, but due to cost issues, not advantage issues. | | | Re: Hobie trampoline difference
[Re: Hullflyer1]
#110879 07/06/07 08:04 PM 07/06/07 08:04 PM |
Posts: 393 Syracuse,N.Y | But let me suffice by pointing out that even Hobie has discontinued their last curved beam catamaran several years ago. What kind of beams do these brand new (2005 Nationals) factory supplied Hobie 16's have? ![[Linked Image]](http://www.hcana.hobieclass.com/site/hobie/hcana/downloads/2005/Ventura/Photos/27jul05/BosunChairRace10/images/IMG_9630.jpg) Still the most popular catamaran in the USA year after year based on Nationals attendance.
Pat Bisesi
Fleet 204
[Re: warbird]
#110881 07/06/07 09:24 PM 07/06/07 09:24 PM |
Posts: 1,884 Detroit, MI | When I lift even the best maintained Hobie 16 from 1 hull there is a few inches of movement before the other hull starts to raise, and in some cases many inches. Um, no. You haven't seen a well maintained Hobie 16. Go to any high-level event and those boats are stiff and solid. Oh, and Wouter - the last Hobie with curved crossbars to be discontinued was the H-17 - and that was only 6 months ago. However, as Pat pointed out, the 16 is still made with a curved front crossbar. | | | Re: Hobie trampoline difference
[Re: pbisesi]
#110883 07/07/07 05:31 AM 07/07/07 05:31 AM |
Indeed Pat,
You got me on this one !
How could I forget about the curved beams on the Hobie 16 ?!
Last of its kind though.
Nevertheless, point for you.
[Re: Karl_Brogger]
#110884 07/07/07 05:41 AM 07/07/07 05:41 AM |
Modern designs with straight beams flex only 15-20 mm when layed up on their sterns and lifted by one bow. For us American friends this is 3/5th - 4/5th of an inch (or whatever other fractions you use !). i.e. without the rig on it.
There is no way you can get down to that with a raised trampoline on pilons. Your best bed would be to weld (all) the connections together and hope the beams are stiff enough themselves.
I do know that stiff platforms ride the waves noticeably better. I had an old Prindle 16 that became soft in the beam/hull connection. At one time I decided to stiffen these up. Once again I could fix the beams tightly to the hulls. The next day I went out it felt like the boat was reborn. It felt young again, agile, it glided the waves with ease. With gusts it picked up power more quickly. I was really suprised to find how much effect bringing back platform stiffness had and it hadn't been that soft to begin with.
[Re: Wouter]
#110885 07/07/07 11:21 AM 07/07/07 11:21 AM |
Posts: 471 NC | I do know that stiff platforms ride the waves noticeably better. I had an old Prindle 16 that became soft in the beam/hull connection. At one time I decided to stiffen these up. Once again I could fix the beams tightly to the hulls. The next day I went out it felt like the boat was reborn. It felt young again, agile, it glided the waves with ease. With gusts it picked up power more quickly. I was really suprised to find how much effect bringing back platform stiffness had and it hadn't been that soft to begin with.
Over at SA they were talking about how you won Texel on that P16. Can you share some more tips on how you made that boat so fast? | | | Re: Hobie trampoline difference
[Re: drbinkle]
#110886 07/07/07 12:49 PM 07/07/07 12:49 PM |
Ohh that is very easy. I just did everything the same as the last Hobie 16 that won line-honours at Texel.
618
guests, and 65
