Re: Flex [Re: ncik] #111361
07/13/07 09:38 PM
07/13/07 09:38 PM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
On the topic of stiffness, what sort of deflection are ppl getting in their main beam under full rig tension? And, what deflection are ppl getting in their bows (transversely) under full rig tension?
I found it difficult to maintain rig tension on my ply mozzie because there was heaps of deflection in both of these. I managed to increase the dolphin striker tension which helped reduce the main beam deflection.
The mossie uses a small [55mm?] square section for the front and rear beam which in itself isn't very stiff.
Re: Flex [Re: Berny] #111362
07/13/07 10:37 PM
07/13/07 10:37 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
35mm for my Mozzie using the method previously mentioned. No rig, platform weight 55kg.
Approx 50 by 40, 3mm thick beam for Mozzy depending on
which beam is used.
Darryn
1782
Re: Flex [Re: Berny] #111363
07/13/07 10:37 PM
07/13/07 10:37 PM
Or you can replace them with nylon lock bolts, and do not worry about them working there way loose ever again. Does not mean you should not check every so often.
Re: Flex [Re: Robi] #111364
07/13/07 11:13 PM
07/13/07 11:13 PM
Wrong Robi. Same principle applies. I have never had any other nuts then nylon lock nuts. The only difference is that they work themselves loose a little slower.
Re: Flex [Re: Wouter] #111365
07/13/07 11:22 PM
07/13/07 11:22 PM
Darryn Offline
Darryn  Offline
The nyloc nuts dont undo, it is the beam landings collapsing, bolts stretching and beam compressing that causes them to loosen.
Darryn
Re: Flex [Re: Wouter] #111366
07/13/07 11:28 PM
07/13/07 11:28 PM
Wrong WOUTER! I am an aviation mechanic and we use nylon lock nuts for a [censored] reason. They are not supposed to work there way loose. You are using the wrong nuts then. Purchase quality stuff, not junk and you wont have problems.
Did you not read my entire post! Just because you have nylon nuts does not mean you should not check them.
Re: Flex [Re: Robi] #111367
07/14/07 02:43 AM
07/14/07 02:43 AM
CA
Glenn_Brown Offline
Glenn_Brown  Offline
CA
Wrong WOUTER! [...] we use nylon lock nuts for a [censored] reason. [...] Did you not read my entire post!
Dude, Wouter said "nylon lock bolts".
Stones and glass houses,
--Glenn
Re: Flex [Re: Darryn] #111368
07/14/07 06:06 AM
07/14/07 06:06 AM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
which beam is used.
Darryn
1782
Oh, Ok. 50 x 40 rhs, Not a good torsion member. Certainly not as stiff as a tube and the bigger tube diameter the better.
Tightening the dolphin striker doesn't contribute to stiffness.
Re: Flex [Re: Berny] #111369
07/14/07 06:24 AM
07/14/07 06:24 AM
Darryn Offline
Darryn  Offline
Cheap though, $45 a beam and 35mm flex was less then most of the other cats mentioned.
Have you measured the flex on your 14ft cat?
Darryn
1782
Re: Flex [Re: Darryn] #111370
07/14/07 09:08 AM
07/14/07 09:08 AM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
Darryn
1782
Not accurately but I've recently made a new front beam from an un-milled mast section and it seems much stiffer than it was.
I will do a measurement shortly just for interest sake.
0 registered members (), 336 guests, and 43 spiders.
