| Re: How's my trim *DELETED*
[Re: Tornado]
#111848 07/16/07 01:35 PM 07/16/07 01:35 PM |
Posts: 2,921 Michigan | | | | Re: How's my trim
[Re: Rolf_Nilsen]
#111850 07/16/07 03:07 PM 07/16/07 03:07 PM |
Joined: Jul 2001 Posts: 1,200 Vancouver, BC Tornado OP
Posts: 1,200 Vancouver, BC | The pics are from the Frenchy's Rum Run...one long close reach out to Anacapa island and back. So, I'm wanting feed back on how the sails look for such a heading. From my eye, they seemed good...better than my old alu rig setup. Leech looks quite vertical aqnd draft seems pretty even. Try this link to the original sized pics...you can see the tell tales nicely: Sail Trim Why do you ask? Are you thinking about the reach from A mark to the offset? I can not see the telltales, so it's hard to say. If you were double trapped when going upwind (8 knots and you are a heavy team? probably not?) you would probably need one on trapeze going from A to offset. We let out a bit on the jib, mainsheet, downhaul and rotation when going from a beat to a close reach. I expect our trim looks much like yours, but we also play the travellers to make the leech telltales fly as well as possible if there is time. From A to offset there is usually not time for much fine tuning, just enough to let out on the mainsheet as the crew goes in and readies the spi.
| | | Re: How's my trim
[Re: warbird]
#111853 07/16/07 05:30 PM 07/16/07 05:30 PM |
Posts: 3,528 Looking for a Job, I got credi... | Difficult to comment on twist without seeing tell-tails.
But as you say you are tight reaching, I would say more mast rotation - i.e. spanner pointing along the front beam and let the outhaul off a fair bit. In light wind you want some shape at the bottom of the sail.
F16 - GBR 553 - SOLD I also talk sport here | | |
657
guests, and 140
