sta/master turnbuckles #111919
07/17/07 12:31 PM
07/17/07 12:31 PM
TampaN20 Offline OP
TampaN20  Offline OP
Has anyone tried using these for the shrouds, instead of the regular chainplates.
http://www.pyacht.net/cgi-local/SoftCart.exe/online-store/scstore/h-stamaster.htm?E+scstore
Re: sta/master turnbuckles [Re: TampaN20] #111920
07/17/07 12:47 PM
07/17/07 12:47 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Yes,
We use the 432 model on our Hobie Tiger side shrouds. They work well - very easy to get consistent tension readings. We tape them up before sailing in case the retaining clip comes off the nut (which could allow the nut to work loose and drop the rig).
Chris.
Re: sta/master turnbuckles [Re: flumpmaster] #111921
07/17/07 12:50 PM
07/17/07 12:50 PM
southern Ontario
Twister Offline
Twister  Offline
southern Ontario
I have used them lots on a Star, and thought about using them on my F18, but have not tried them. It is nice to take a turn on or off of the shrouds in the star as wind or wave conditions change. It would be nice to be able to do that on the F18 sometimes.
Ryan
Dart 18 #4860
Re: sta/master turnbuckles [Re: Twister] #111922
07/17/07 01:01 PM
07/17/07 01:01 PM
They are stock on my Blade; I like them. They can vibrate loose during trailering, so secure them with tape or take them off and stow.
Re: sta/master turnbuckles [Re: TampaN20] #111923
07/17/07 01:41 PM
07/17/07 01:41 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Use them on the Tornado. I like them.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: sta/master turnbuckles [Re: TampaN20] #111924
07/17/07 01:51 PM
07/17/07 01:51 PM
I have them too but I think they need to be covered with shroud adjuster covers after taping them. Someone who crewed for me once slid forward when we buried the bow and really scraped his leg pretty badly on the teeth of the stay master.
Re: sta/master turnbuckles [Re: TampaN20] #111925
07/17/07 04:13 PM
07/17/07 04:13 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Stock on the Infusion - Good kit
Re: sta/master turnbuckles [Re: TEAMVMG] #111926
07/17/07 05:23 PM
07/17/07 05:23 PM
TampaN20 Offline OP
TampaN20  Offline OP
Which are stock on the infusion, 432 or 532?
Re: sta/master turnbuckles [Re: PTP] #111927
07/17/07 10:14 PM
07/17/07 10:14 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Good point - we put covers over ours to prevent this happening. The regular boots didn't fit so we slit them open and fitted them slit forwards, taping them up each time.
Chris.
Re: sta/master turnbuckles [Re: TampaN20] #111928
07/18/07 05:36 AM
07/18/07 05:36 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
432's on the Infusion.
Why do people always laugh when I tell them that my Infusion has got STAIRMASTERS fitted?
paul
Re: sta/master turnbuckles [Re: TEAMVMG] #111929
07/18/07 06:27 AM
07/18/07 06:27 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Also what is generally stock on the Taipan 4.9, a couple of the top cat rigged guys have one on the forestay as well.
Re: sta/master turnbuckles [Re: TEAMVMG] #111930
07/18/07 07:20 AM
07/18/07 07:20 AM
G
GBR6 Offline
GBR6  Offline
G
'cos you look like you need them! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Adrian.
Re: sta/master turnbuckles [Re: flumpmaster] #111931
07/18/07 11:16 AM
07/18/07 11:16 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I have a set of covers from a set of shrouds with StaMasters I purchased off Charlie Ogletree some years back. The covers are just short lengths of PVC plastic pipe with a top cap fitted. These just slide over the StaMasters before attaching to boat.They act a bit like rollers if lines pass over them.
Mike.
Chris.
Mike Dobbs
Re: sta/master turnbuckles [Re: TEAMVMG] #111932
07/18/07 11:31 AM
07/18/07 11:31 AM
I
Ians Offline
Ians  Offline
I
Does anyone know if these are class legal on the Hobie 20?
Re: sta/master turnbuckles [Re: Ians] #111933
07/18/07 12:45 PM
07/18/07 12:45 PM
In the IHCA Rule Book under General Rules, 15.2
"Shrourds and forestays shall connect to the HOBIE CAT CO. supplied shroud adjusters."
Ian, I'll agree they're cool, but...
You, sir, don't need an advantage <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: sta/master turnbuckles [Re: _flatlander_] #111934
07/18/07 05:37 PM
07/18/07 05:37 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Besides the coolness factor these shroud are a lot safer than standard shroud adjusters. They can be adjusted on the water without fear of dropping the pin and (or) dismasting. It also eliminates a clevis pin which can work free and lead to dismasting. In the fleet of monohulls I race in everyone has switched over to these.
Re: sta/master turnbuckles [Re: TampaN20] #111935
07/18/07 08:52 PM
07/18/07 08:52 PM
Stock on the Capricorn - as others have said, tape the retainers once adjusted, and use shroud boots to cover the threads. F18 rules say they cannot be adjusted while racing, but ok to adjust between races. If you are racing HCA regattas, they're not allowed at all - but someone would be digging pretty deep when filing a protest on something like that. If you race mostly HCA races, I wouldn't put them on. If you're recreational or Portsmouth, I think you'll very much like the convenience. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: sta/master turnbuckles [Re: wildtsail] #111936
07/18/07 10:23 PM
07/18/07 10:23 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Well actually I hold the record around here for dismasting TWICE in the same race because those things slipped. The teeth were worn. So yes you can definitely dismast with them.
Re: sta/master turnbuckles [Re: pitchpoledave] #111937
07/19/07 08:54 AM
07/19/07 08:54 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Acid Test -- Do you still use them (new ones of course <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />)?
USA 777
Re: sta/master turnbuckles [Re: tback] #111938
07/19/07 09:40 AM
07/19/07 09:40 AM
Toronto, Ontario
Toronto, Ontario
no.
1 registered members (Talus1), 680 guests, and 163 spiders.
Posts267,056
