Re: New Mainsails? [Re: Wouter] #112121
07/21/07 07:14 PM
07/21/07 07:14 PM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
I haven’t seen a Landenberger F16 main but both Goodall and Ashby are absolute state of the art and hassle free and therefore come highly recommended. Ashby doesn’t except credit cards however so you’ll have to find some other form of payment but it’s a beautiful cut. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Are you calling the mainsails created by the likes of Ashby, Landenberger, Glaser and Ullman "jury rigged that you'll never be happy with" ?
Just checking !
Re: New Mainsails? [Re: ] #112122
07/21/07 07:34 PM
07/21/07 07:34 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
In regard to the top batten angle. There seems to be an almost rigid reinforcing section across top of head. I have been wondering for some time why this would not be done. Does anyone know if it is just tape?
Re: New Mainsails? [Re: Buccaneer] #112123
07/23/07 10:04 AM
07/23/07 10:04 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
"...Goodall and Ashby are absolute state of the art and hassle free and therefore come highly recommended."
I fully agree; but I've inspected and sailed against a new Glaser main and I will say it is definitely on par!
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: New Mainsails? [Re: ejpoulsen] #112124
07/25/07 04:07 AM
07/25/07 04:07 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Great and did they change the luff rope or do you still need to install a halyard to get it up the mast? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: New Mainsails? [Re: Buccaneer] #112125
07/26/07 10:46 PM
07/26/07 10:46 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
On my Taipan #297 w/ goodall and ashby mains--no halyard.
On Taipan F16 #300 w/ glaser main--no halyard.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: New Mainsails? [Re: ejpoulsen] #112126
07/27/07 03:14 AM
07/27/07 03:14 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
This is a simple change. Just take out the old bolt rope and replace with hydrolic tubing.
Re: New Mainsails? [Re: warbird] #112127
07/27/07 03:32 AM
07/27/07 03:32 AM
How many people can do this at home and how much does it cost to have it done ?
Not to mention the fact that a larger portion of the sailors choose to have the "old" setup when given a choice.
The only "advantage" of the hydrolic tubing it "not having a halyard". Its largest drawback is "not having a halyard" and the fact that it is much harder to fit to a normal size sail bag.
In the way of aerodynamic (performance) it is a non issue.
In the way of weight difference it is a 225 grams (1/2 lbs) issue; as per 18 meter of 4 mm dyneema.
In the way of tipweight, the 8.5 meter halyard still running up inside the sailtrack when the mainsail is hoisted contributes a staggering 57 grams of tipweight (1/8 lbs). This on a class minimum of 6 kg which is 106 times as much. So the difference in tip weight is less then 1 %
Maybe there is an advantage of having the top of the sail run level with the top of the mast. Too bad that this same feature can be had with a halyard system as well. Some F16's already have such a setup, see the pictures for clearification.
So the question becomes, is there any real advantage of having a push up mainsail ?
Re: New Mainsails? [Re: Wouter] #112128
07/27/07 04:23 AM
07/27/07 04:23 AM
taipanfc Offline
taipanfc  Offline
Wouter [/quote]
Absolutely, it looks good to non cat sailors who wonder how you are going to get your sail up the mast.
Plus I find the push up sails easier to get down.
Another advantage (which Wouter sees as disadvantage) is that the tube doesn't allow you to roll up the sail too tight. Rolling too tight really doesn't help the sail I think longevity wise.
Re: New Mainsails? [Re: taipanfc] #112129
07/27/07 07:50 AM
07/27/07 07:50 AM
Seems like it would take longer to put the sail up with a "push-up" sail. It comes down fine with the halyard set up. When I ordered my new main there was the option of a "push up" style but I didn't give it much thought. I can't see how it could make any difference in sailing performance. I have never used a push up main so I can't say for sure but it can't be significantly easier to deal with than a small lightweight halyard. Besides, if you have mast up (very secure) storage you can use the halyard to tie to the end of your boom to keep it up and keep the mainsheet blocks extended so it doesn't get kinked, etc.
p.s. new Glaser main (white) and spin (orange) should be here today!!
Re: New Mainsails? [Re: PTP] #112130
07/27/07 12:45 PM
07/27/07 12:45 PM
PICTURES, or it didn't happen !
Re: New Mainsails? [Re: Wouter] #112131
07/27/07 01:08 PM
07/27/07 01:08 PM
Just got it and put the battens in. Babysitter on the way over so I can go give it a try!
BTW, got the spin and main. Is there a reason I would get spreader patches (separate 8in diameter circular fabric with sticky back) with them? It seems to have come with the main actually.
P.s. probably deserves its own thread but leech telltales at the top of the sail? On my Ullman I think I have them finally figured out and how to really make them work and the boat feels faster when I get the twist right. I think that answers my question, but what do people think about them? The Glaser doesn't have them but I could obviously put them on.
Re: New Mainsails? [Re: PTP] #112132
07/27/07 04:55 PM
07/27/07 04:55 PM
"Is there a reason I would get spreader patches (separate 8in diameter circular fabric with sticky back) with them? It seems to have come with the main actually."
Probably to be stuck over batten pocket where side stay rubs when main is let out.
Re: New Mainsails? [Re: phill] #112133
07/27/07 06:44 PM
07/27/07 06:44 PM
If so, why not tape then? Why circles?
Re: New Mainsails? [Re: PTP] #112134
07/27/07 07:17 PM
07/27/07 07:17 PM
K
KMarshack Offline
KMarshack  Offline
K
Place them on the main where otherwise the spreadder tips may poke a hole in the main. Possibly only happens if you jibe and forget to uncleat the positive mast rotation.
Ken
Re: New Mainsails? [Re: KMarshack] #112135
07/27/07 07:24 PM
07/27/07 07:24 PM
Ken
but the blade has a rotation limiter. I have a hard time thinking the spreaders tips will ever touch the main. Who knows.. I wrote to them about it.
I did put some rotation inducers on the HT for the RTI but the blades mast rotates pretty well so I am not too concerned.
Re: New Mainsails? [Re: Wouter] #112136
07/27/07 07:31 PM
07/27/07 07:31 PM
Ok. no pics of the spin. I did put it up on the beach briefly to make sure the lines were done correctly but too much wind to take a pic of it. However, here is the new main.
Seems clearly a different cut than the Ullman, but you can't see it in the pic obviously. The head is bigger and it seems flatter. I did use 2 stiffer battens in #2 and 3 which definately made the top flatter (than the Ullman at least, I didn't try both sets of battens).
The sail seems very fast upwind. I was holding off a 2-up jav2 HT although they were pointing slightly higher than me. The downwind part needs to be investigated a little more. I think the sheeting angle looks good but my boat has two eyes - one a foot or so in front of the "standard" eyes near the chainplates. Matt had it set up with the rachets on the front for the Ullman spin I have. I used that for the new spin and although it looked right I think I need to try the aft ones. The spin is less sensitive than the Ullman. You have to be careful with the Ullman. A slight curl turns into a big one quickly. The Glaser is a little more forgiving. Another issue is the luff seemed too tight on the Glaser spin with the way I have the pole set for the ullman. Seemed to do better with letting the halyard down about 6-8 inches.
Sorry the pic is too big. I don't know how to dumb it down or I would have put it in the body.
P.s. when are they going to invent something better to make the windows out of? I actually had them reduce the size of the window from 3 panels to 2 because they always look like crap after a short while. Makes it hard to roll the sail solo too. Really nice when new but it already has a nice little crinkle crease.
Re: New Mainsails? [Re: PTP] #112137
07/27/07 07:47 PM
07/27/07 07:47 PM
Mark P Offline
Mark P  Offline
Leech tell tales are the best when you're winning. However, the majority of us don't win.... So if I were you I would concentrate on the more important things first. ie starts, clear wind, boat handling, Then look at exact /precise tunning!!!
What's the point of having near perfect sail shape if you can't start on time, tack, gybe or mark round smoothly.
I'm sorry if I'm coming across a bit shirty but lets be fair you've got to pick up a feel for the overall boat not just pick at certain areas. What I'm trying to say (after a few drinks) is that it's a matter of feel for the WHOLE boat. Sailing is after all a form of mental masturbation.
MP*MULTIHULLS
Re: New Mainsails? [Re: PTP] #112138
07/27/07 08:02 PM
07/27/07 08:02 PM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
The halyard is there to compensate for the soft oversized luff rope! My guess is that the sail manufacturer has never used a push up main either… <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: New Mainsails? [Re: Mark P] #112139
07/27/07 08:04 PM
07/27/07 08:04 PM
I hear you. I am trying to get a feel for the whole boat and honestly it feels a little "bound up" unless the upper leech telltales are flying. However, when I went out today I didn't have too much of a problem without them.
I haven't had the patience to set up drills for myself. I get nervous using nav aids to practice roundings (crunch crunch and all). So mostly I concentrate on boat speed and have been practicing tacks and gybes. Starts are obviously very important- esp if racing in an open class where there will be plenty of bigger boats which would create bad wind for a "small" boat like mine. It is hard to get that practice without actually racing and there haven't been any races recently.
Re: New Mainsails? [Re: PTP] #112140
07/30/07 01:52 PM
07/30/07 01:52 PM
I notice you have end caps on your beams. Did they come with the boat? I need to get some - mine doesn't have any and it looks a bit untidy.
Mark.
0 registered members (), 15,014 guests, and 668 spiders.
Most Online16,046
2 hours ago
