Removing Daggerboard "Slop" #112141
07/20/07 11:43 AM
07/20/07 11:43 AM
_flatlander_ Offline OP
After repairing the leak in the dagger trunk, I'm now ready to replace the worn "spacer". I'll call it a spacer because it isn't carpet and I can't identify the material. BTW, the carpet at the top of the trunk is still good and holds the boards in any postition nicely.
This spacer started two inches from the back, wrapping to the rear and forward two inches. It appears to be a sticky back close cell foam tape with a slick outer surface. It was not strong enough to withstand the rearward pressure of the board or the friction of raising and lowering the board, which wore through it completely. We then hit something causing the leak.
My question is actually two fold. I think a cushion of sorts is good idea for the rear of the trunk, carpet (or?) that can be replaced periodically. Anyone using something of a more permanent nature to shim up the sides of the boards? Was suggested to use furniture glides?
Thanks
Re: Removing Daggerboard "Slop" [Re: _flatlander_] #112142
07/20/07 11:51 AM
07/20/07 11:51 AM
California
mmiller Offline
mmiller  Offline
California
The item is shown in the Hobie catalog as #40309001 Daggerboard well neoprene kit (in stock). Comes with some super glue to stick it in.
This was used to help limit chipping of the board's trailing edge more than anything else, so I would stick with something with cushion.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Removing Daggerboard "Slop" [Re: _flatlander_] #112143
07/20/07 11:59 AM
07/20/07 11:59 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
On my Nacra 6.0 I used dinghy centreboard tape. It was black and was very slick with a self adhesive on the one side.
Re: Removing Daggerboard "Slop" [Re: mmiller] #112144
07/20/07 12:07 PM
07/20/07 12:07 PM
Matt, so this is the short piece as I described?
Re: Removing Daggerboard "Slop" [Re: pitchpoledave] #112145
07/20/07 12:37 PM
07/20/07 12:37 PM
Thanks Dave,
A "dinghy centerboard tape" search led me to all kinds of links including a discussion on gelcoating a piece of 3mm dyneema to the rear of the trunk. Don't plan on standing the 20 on her sterns anytime soon! <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Looks like "Jap" (Japanese Glide) tape will do the trick as well.
Maybe I was waaaay overthinking this but isn't there a possibility of the board "hunting" from side to side in light winds?
Re: Removing Daggerboard "Slop" [Re: _flatlander_] #112146
07/20/07 05:59 PM
07/20/07 05:59 PM
California
mmiller Offline
mmiller  Offline
California
Yes, the kit is the short white rubber strip. I think enough for both trunks.
1/8" thick
1/2" wide
6" of material included, so two 3" strips.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Removing Daggerboard "Slop" [Re: mmiller] #112147
07/20/07 08:43 PM
07/20/07 08:43 PM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
I use 20mm Velcro self adhesive tape, the wooly side not the hooks.
Be careful though because when the load/rearward pressure is put on the case, as opposed to the hull, it can split the case.
Bern
