| Re: H18 main beam bolts torque?
[Re: DHO]
#112341 07/25/07 09:02 AM 07/25/07 09:02 AM |
Posts: 778 Houston | The question is: What is the torque value for beam bolts?. The answer is:
I have never seen a torque value for beam bolts. I always guessed that because the condition of boats vary wildy, nobody wants to be responsible for you stripping the threads on an old corroded boat.
That said, a standard practice for 1/4" bolts threading into aluminum is 5-10 ft-lbs. This is for new clean threads. Not dirty corroded threads. For a normal boat, I consider 5 ft-lbs a maximum.
FYI the 5-10 ft-lbs is from a aircraft practice. The rest of the practice says "don't thread steel bolts directly into al in a saltwater environment".
In reality, apply anti-seize for al/steel to the bolts and threads. Clean the threads every couple of years, with a tap. Just get the bolts snug and check them frequently and keep a heli-coil kit for Al/steel handy. Pep Boys sells a good SS heli-coil kit for head bolts going into aluminum motorcycle blocks.
[Re: jollyrodgers]
#112343 07/25/07 01:03 PM 07/25/07 01:03 PM |
Posts: 606 League City, TX | the answer to your question is in the length of the allen wrench that comes with the boat. hand tighten the bolts with that wrench. you can measure your diagonals as you tighten the bolts down, but i think the platform just bolts together in 1 configuration with not much adjustment if the diagonal measurements are not equal. your results may be different though. Diagonal measurements do not reveal toe out/toe in. Only side to side measurements will do that. | | | Re: H18 main beam bolts torque?
[Re: Dlennard]
#112344 07/25/07 01:44 PM 07/25/07 01:44 PM |
Posts: 778 Houston | All the bolts and bolting bars I have seen on the 18 were all SS. I always thought mine were aluminum and treated them as such. I have never seen what is inside an TheMightyHobie18 hull. | | |
2,454
guests, and 353
