| New A-class with a radical bow shape #112515 07/26/07 06:21 AM 07/26/07 06:21 AM |
Posts: 545 Brighton, UK | I am no expert on the A-class but I haven't seen a bow shaped like this before. [img]http://www.boatdesign.net/forums/attachment.php?attachmentid=15049&d=1185441096[/img] [img]http://www.boatdesign.net/forums/attachment.php?attachmentid=14632&d=1183894884[/img] see http://www.boatdesign.net/forums/showthread.php?t=18037&page=2 for more details. Gareth | | | Re: New A-class with a radical bow shape
[Re: grob]
#112516 07/26/07 06:45 AM 07/26/07 06:45 AM |
Posts: 12,310 South Carolina | I hope that is not the future - It looks like a suppository.
Jake Kohl | | | Re: New A-class with a radical bow shape
[Re: grob]
#112517 07/26/07 06:58 AM 07/26/07 06:58 AM |
Posts: 1,203 uk | Return of the SIZZLER!
Is made of aluminium?
[Re: pitchpoledave]
#112519 07/26/07 07:29 AM 07/26/07 07:29 AM |
Posts: 902 Norman,OK | IT does look like a sizzler!
[Re: pitchpoledave]
#112520 07/26/07 08:09 AM 07/26/07 08:09 AM |
Posts: 778 Houston | I believe that is a custom A being built for a few people by John Lindal in (MI?). One of the guys here is getting one. I will post some pics when I see it. Is it John or or his son, Ian. Last time I saw Ian, he was talking about building a A-Cat. | | | Re: New A-class with a radical bow shape
[Re: carlbohannon]
#112521 07/26/07 08:41 AM 07/26/07 08:41 AM |
Joined: Sep 2006 Posts: 613 New Hampshire, USA windswept
Posts: 613 New Hampshire, USA | It is being built by both John and Ian Lindal. The first one is on the water now and the second should be this weekend. The construction is carbon/foam/carbon.
Tom Siders A-Cat USA-79 Tornado US775
[Re: grob]
#112522 07/26/07 08:47 AM 07/26/07 08:47 AM |
I'll give it another 5 years till they chop off the front 0.49 mtr altogether and make it a 16 footer ! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
[Re: warbird]
#112525 07/26/07 04:34 PM 07/26/07 04:34 PM |
Posts: 9,582 North-West Europe | Dolphins also speed most of their life UNDER the watersurface, instead of on the watersurface as sailboats do. Otherwise surface ships would look like submarines do and they don't. These animals must have wonderful hydrodynamic shape. I have sailed at ten knotts and had a dolphin pacing me a metre off my bow for several ks and not even look like its tail is moving.
He was riding the pressure zone of your bow wave. In effect, the portion of water directly in front of your boat moves forward with almost the same speed as the hull. The dolphin "feels" like he is just hovering in his particular volume of water while he and the volume of water are pushed along by the boats hull. Dolphin cover many many many nautical miles like in front of oceans freighters, with a minimum in effort.. Wouter
[Re: ncik]
#112527 07/26/07 07:18 PM 07/26/07 07:18 PM |
Posts: 12,310 South Carolina | In general, dolphins aren't designed to swim on the surface of the water in displacement mode either.
#112528 07/26/07 07:28 PM 07/26/07 07:28 PM |
Posts: 461 Sydney Australia | In general, dolphins aren't designed to swim on the surface of the water in displacement mode either. And....they are very difficult to steer.......... | | | Re: New A-class with a radical bow shape
[Re: Wouter]
#112532 07/27/07 08:51 AM 07/27/07 08:51 AM |
It's too light. Even with the increased rigging you would need 30-60 Lbs ballast. Seriously, look at the drawing comparing it to the Flyer. That is a very small hull volume. I am not sure you could make that concept work as an F16. After you scaled it down to 16 ft, made the hulls bigger to accomodate the increased platform and crew weight, accomodated the different center of force for the jib and spin,...... it would be a different boat. Maybe a lower volume Blade. | | | Re: New A-class with a radical bow shape
[Re: carlbohannon]
#112533 07/27/07 09:30 AM 07/27/07 09:30 AM |
Posts: 3,116 Annapolis, MD | I seem to remember a brief conversation with Lindahl and I thought he mentioned that Richard Roake had a major hand in the design. Eg... Super Lube back in the unlimited worrell 1000 days... the planing catamran hull that Randy Smythe sailed.
I could be complete wrong about this one though... would love to see some close up pictures.
The flyer hulls' take along time to adjust your down wind sailing style to.... Those things look like you are trying to sail a moth !
crac.sailregattas.com
[Re: warbird]
#112534 07/28/07 04:33 AM 07/28/07 04:33 AM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | Every sensible racing yacht looks more like a dolphin than a brick...It doesn't look that much like a dolphin anyway, I've never seen one with a sharp pointy head.
Nature has other things to contend with that also influence its design, like catching food. Not every aspect of nature can be applied to making boats go faster. Do you see dolphin nose like appendages on the front of keels? No, because it is inefficient for racing yachts, but very good for dolphins that need to catch food.
I'm all for reverse engineering nature, but common sense should be incorporated into the design process.
My personal opinion is that it could be a great light weather boat in the hands of a skilled skipper. Probably will be a handful off the wind in a blow and waves, because it has little reserve bouyancy in the bow. | | |
389
guests, and 475
