| Re: p16 standing rigging
[Re: dave taylor]
#11265 10/03/02 09:37 AM 10/03/02 09:37 AM |
Posts: 2,844 42.904444 N; 88.008586 W | If you can get a halyard ring there then it may work as a 1 piece forestay.
HOWEVER, you could not roller furl the jib, etc.
I'd set it up just like the stock set-up, easier in the long run. If the shackle is worn, just replace it, this is not a high wear item.
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#11266 10/03/02 11:00 AM 10/03/02 11:00 AM |
Posts: 171 Tampa, FL | i have a roller furler that i designed that works great. the whole forestay from the bridle to the top of the upper forestay at the mast turns. this includes the upper forestay. check out www.mech-solutions.com/dave/furling.htm i was just thinking that if i had a 1 piece forestay, there would not be a chance at all of the shackle coming apart. i was thinking about a wire from the bridle to the mast tang and down a few inches to a loop for the halyard with a sleeve on the forestay with a loop fof the halyard ring. i attached a really crude drawing. the red boxes are nico press sleeves. the blue thing is the ring that the hook at the head of the sail hooks to. | | |
465
guests, and 30
