Spin Retrieval Patch Diagram? #112868
07/27/07 04:34 PM
07/27/07 04:34 PM
Vancouver, BC
Tornado Offline OP
Tornado  Offline OP
Vancouver, BC
Anyone got a diagram showing where to locate retrieval line patches on spinnakers? A friend is setting up a N5.2 and needs instructions for his sailmaker.
Re: Spin Retrieval Patch Diagram? [Re: Tornado] #112869
07/27/07 06:26 PM
07/27/07 06:26 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Hey, I can use this info also as I am doing the same thing.
Re: Spin Retrieval Patch Diagram? [Re: Tornado] #112870
07/28/07 10:47 AM
07/28/07 10:47 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
you need to decide how long your chute is going to be and then see how many times the sail needs to be folded to get to that length.
F18's/20's need 3 patches but you may get away with 2 on a 5.2 like a H16.
if you are greedy and have your spinny too far up the mast, you may need an extra patch to get it to fit your chute.
Re: Spin Retrieval Patch Diagram? [Re: TEAMVMG] #112871
07/28/07 09:27 PM
07/28/07 09:27 PM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
Generally three are better with the centre one at a point where lines drawn from the task, clue, and head, to the centre of the opposite side, intersect.
Top one is positioned half way between there and the head and the bottom is half way toward the tack.
There are variations but that's what worked for me.
Re: Spin Retrieval Patch Diagram? [Re: Berny] #112872
07/29/07 02:36 AM
07/29/07 02:36 AM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Make sure that the distance between the top patch and the head, and the bottom one and both tack and clew is less than the length of your snuffer, otherwise you'll end up with bits of sail hanging out the front of the snuffer. Having done this, if the distance between top and bottom patches is more than twice the length of your snuffer, you need a third.
0 registered members (), 497 guests, and 63 spiders.
