Aluminum vs. Stainless rivets #11286
10/04/02 10:34 AM
10/04/02 10:34 AM
Utah, USA
AlphaGJohn Offline OP
Utah, USA
I noticed someone with some experience mentioned using stainless steel rivets on conjunction with a comp tip job. How do you decide whether the application in question calls for stainless or aluminum rivets? Everything I've replaced on our ancient H14 was apparently aluminum (from how it drilled out).
Would stainless cause electrolysis problems with aluminum components (not that we're ever in anything but fresh water ourselves)?
John
John Craig Utah County, Utah '95 Hobie Wave
Re: Aluminum vs. Stainless rivets [Re: AlphaGJohn] #11287
10/04/02 11:03 AM
10/04/02 11:03 AM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Hello,
I was under the impression that all rivets on catamarans are stainless steel. I think the aluminum ones would wear rather quickly.
Jack
Re: Aluminum vs. Stainless rivets [Re: AlphaGJohn] #11288
10/08/02 07:54 PM
10/08/02 07:54 PM
Bogie Offline
Bogie  Offline
Most reliable(and safe) replacements would normally require the original monel rivet with a steel mandrel or a stainless steel rivet with a stainless steel mandrel. They pull harder, hold tighter and last much longer than aluminum. Electrolysis can be noticed more with stainless than monel, but is generally tolerated since the stainless rivets seem to pull harder than monel.
0 registered members (), 3,901 guests, and 463 spiders.
