16 Downhaul #113107
07/30/07 06:36 PM
07/30/07 06:36 PM
daveh Offline OP
daveh  Offline OP
How does everyone connect the downhaul to the base of the mast?
Re: 16 Downhaul [Re: daveh] #113108
07/30/07 08:03 PM
07/30/07 08:03 PM
The 6:1 downhaul is attached with the same little piece of stamped stainless steel that's on top of the main traveller.
Check this out: 6:1 Downhaul Guide
Re: 16 Downhaul [Re: daveh] #113109
07/30/07 08:47 PM
07/30/07 08:47 PM
I think it is called a deck plate.
Re: 16 Downhaul [Re: daveh] #113110
08/02/07 04:39 PM
08/02/07 04:39 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
remember to tie it to the mast base with a piece of strong line to stop it sliding up the track
Re: 16 Downhaul [Re: TEAMVMG] #113111
08/02/07 05:22 PM
08/02/07 05:22 PM
California
mmiller Offline
mmiller  Offline
California
No need to tie it in place, there is a cleaner way. File a small notch in the mast track at the top edge of the fitting. Bend the top of the fitting ever so slightly to engage the notch. Tighten the heck out of the screws and square nuts.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: 16 Downhaul [Re: TEAMVMG] #113112
08/03/07 06:48 AM
08/03/07 06:48 AM
Virginia USA
CMerrell Offline
CMerrell  Offline
Virginia USA
I replaced the square nuts with SS wing nuts which do a better job of jamming into the luff track. No problems, yet.
0 registered members (), 436 guests, and 37 spiders.
