| Siezed Beam Bolts #113204 08/01/07 08:25 AM 08/01/07 08:25 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum OP
Posts: 556 Somers, Westernport Bay, Victo... | Whilst trying to remove my trampoline found that the beam bolts were siezed to the tube spacers. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> I can turn the bolts but can't remove them. The tubes were a snug fit to the bolts when I installed them last time so I guess it's another good lesson; a loose fit is best.
Does anyone know what I can soak the joints in to free them up ?
Peter
Mosquito 1814 Macka Mozzie
| | | Re: Siezed Beam Bolts
[Re: Darryn]
#113207 08/02/07 04:46 AM 08/02/07 04:46 AM |
Posts: 556 Somers, Westernport Bay, Victo... | Thanks guys,
I hadn't thought about using a chisel but it may be the only option left if the kero etc. doesn't work.
With the beam off and placed on a suitable solid surface I tried to belt the bolt back out and it did move but it also deformed the top surface of the beam around the bolt. Hey presto, one stuffed beam <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> The inner bolts will be even harder to get to with kero etc. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> The rear beam I may be able to save since I used cap screws on the inner fastening points and only bolts through the beam on the outer fastening points.
Peter
[Re: Peter_Foulsum]
#113208 08/20/07 05:37 PM 08/20/07 05:37 PM |
Posts: 205 Melb. Aust | Hi Peter,
How did you go with your beams? Could you save the rear one?
Trevor
Mozzie 1828 ' ' Sugarloaf Sailing Club Melbourne
[Re: Trevor]
#113209 08/21/07 07:24 AM 08/21/07 07:24 AM |
Posts: 556 Somers, Westernport Bay, Victo... | Trevor,
Even though I soaked the beam in kerosene overnight the bolts are still stuck fast to the spacers. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
I even tried the cold chisel but all it did was put a small groove in the aluminium. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> I really didn't want to chisel too hard in case I started to elongate the beam holes.
The rear beam is still OK but I don't know for how long. Luckily the inner fasteners are cap screws located on the lower face so it's only the outer bolts I have to work on.
If I apply localized heat to the spacer maybe that would work otherwise I might have to get the hacksaw blade out and cut through the bolt at the inside. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> Maybe I should invest in a flame torch and give it to myself for fathers day <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Peter
[Re: Trevor]
#113210 10/07/07 07:44 AM 10/07/07 07:44 AM |
Bought myself a chefs gas burner and tried to heat the spacers. It didn't work. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Bought myself a Dremmel multipurpose drill with cutting attachments. It worked a treat. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> Cut straight through the spacers inside the beam and allowed me to easily remove the bolts. Took me about half an hour to do both bolts.
Now to put the beast back together for the new season. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" />
Peter
311
guests, and 55
